posted by VIKA123 on May 03, 2008
THE TERMINAL USER SHOULD NOT ACCESS WINDOWS EXPLORE, CONTROL PANNER, DISK DRIVES HOW?
Best Solution
posted on May 06, 2008
If the users should use only one program,then it is easy.Just configure (fromTerminal Configuration Manager) every connection to start automatically the specified application.That is enough but if you want to be 100% sure try to make a new group of users(remote users).Second,make a new policy(from Active Directory Domain Properties) and apply the new policy only to the new group.The policy should restrict access to the explorer,control panel...The remote user logs in the terminal session and the new policy is applied.Good luck .
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on May 05, 2008
please define users & give him restrictions as well as rights,
make them as an standard user (dont define them as an administrators) if u have some applications which have to be use by terminal users then give them only that much of applications..
dont allow them to use anyother applications..
Suggest a new solution for this problem
Post a New problem for Microsoft Windows Server Standard
Email this problem
Email this problem
Can you Help with these Operating Systems problems?
Repair Service
Find Operating System Repairman Near You:
