Question about Sony FD Trinitron WEGA XBRKV-40XBR800 40" TV
Try to turn on but get 6 blinking standby light. it wont even turn on what do i need...a fuse maybe if so where
  • 4,889 Answers
The tv has entered protect mode due to a surge. Unplug the set for about half an hour and turn it back on. See if it does the trick. If it does not then it has probably knocked out some voltage regulator ICs that is causing the line to overload. In that case a component level fix should do the trick.
Posted on Aug 21, 2010
Aquos power light blinks once every 6 seconds
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_1_2012_2_25_44_pm.jpg
May 01, 2012 | Sharp Aquos LC37D44U 37 in. LCD HDTV
It won't turn on
hi; try to check the power cord ,
if power cord has no problem it has standby light coming from the TV
when no light or dead set. there a fuse blown on the power supply section.
if there's standby light wont start , even if you press the power button , it has a power supply failure, maybe some capacitor ha bloated or change the value, try to watch this http://www.youtube.com if you know how to solder, or even disassemble the back of LCD TV. if not try to call a repair technician. thanks ,, hope this help.........
Sep 05, 2011 | Mitsubishi LT-55265 55 in. HDTV LCD TV
Tv will not turn on red standby light blinks 6 times
tv will not turn on red standby light blinks 6, on a sony grand wega kdf-55xs955 55 in. rear projection hdtv television
Jun 19, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Standby light blinks 6 times
ur power board coverter it dead.
Need to be replace.
Aug 15, 2009 | Sony KP-57HW40 57" Rear Projection...
Turned tv on, heard a pop, no picture, standby light blinks conti
POP goes a fuse in your power supply or maybe even a capacitor you need to have this repaired unplug this immediately. Take it to a local repair shop to have it fixed.
May 03, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Red standby light light blinking
there is in-line fuse that blowes,caused by the fan vents being restricted (smoking can be a big facter) the vents should vacumed a couple times a month. you will need to have it seviced (parts and labor cost me 270$
Jan 11, 2009 | Sony KDF-E55A20 55 in. LCD Television
Akira Plasma not working anymore!
Have you gotten it fied yet? You can use a hair dryer to get it to come on.
Jan 30, 2008 | Akira EPM-420A 42 in. Plasma Television
It is fuse issue again. Go to this website and you should have solution or ask for one:
http://www.avsforum.com/avs-vb/showthread.php?t=507602
Dec 18, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
i replaced the thermal fuse on my kdf-55wf655 and still have the 6 blinking lights,,any other ideas.
Nov 03, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
i had the same problem to, i replaced the thermal fuse and everything was back to normal. Be careful if you are a gamer because both times this has happened i was playing my xbox
Nov 03, 2007 | Televison & Video
Sony FD Trinitron WEGA XBRKV-40XBR800 40" TV Logo
65 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
