I cant get my cd burner to burn without skipping i slowed the burn time down didnt help & tried other cd,s bad burner ??
    Genius:
  • 3,587 Answers
Sounds like a memory allocation issue to me..
Posted on May 03, 2008
Aspire, M3410, problem with cd burner
Ive had this same thing happen to me over the years and ruined many CDs. Im not really sure why it does this unfortunately. I too have tried a few diffrent burning programs. Sometimes, however, Ive noticed tht its the same songs that mess up on each burn. Ive tried to reburn using diffrent songs and put the ones tht it skipped or were "blank" on on the new cd N it didnt work then either. The only solution I ever came up with was that it was the song itself wouldnt burn for some reason. Try redownloading the song from a diffrent site and see if the new one burns. I hope this helps some in your problem.
Jun 06, 2012 | Acer Aspire M3410-UR21P : 3.1GHz Athlon II...
It cant burn or read cd's and recently it started to damage new cds
Try to update your cdrw. If it didnt work, possible hardware failure.
Apr 06, 2011 | Teac CD-W522E (CDW522E000/10PK) CD-RW...
Trying to burn a playlist from my itunes account and get 4261 error message, what does this mean?
The ITunes error 4261 appears when attempting to burn CD's. The error code can appear for several reasons, including a faulty CD-RW, used CD's or a slow speed burner.
The error may also occur when you are trying to burn a file that has Dynamic Random Memory from ITunes & you have exceeded your permitted attempts.
The error can also happen if you are accessing the files from a different PC than where it was registered.
Try slowing your burn speed to 16x or even 12x or use Nero Express or Windows Media Player to burn your MP3 files. Other techniques for resolving this error include using new CD's & activating DLA in the Drive Properties.
I truly hope that one of these solutions clearly resolves your problem. Good luck.
Kindest regards,
Ste
Apr 01, 2010 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
My dvdr/rw wont burn dvds properly
There are many reason for this.Try following steps to look out for solution.
1>Use better quality Dvd to burn .DVDs are just a few cents worth of plastic, manufactured in massive quantities. Sometimes you end up with a bad disk or a bad batch. Try a new disk, or a whole new brand, and you may have more luck burning your DVDs
2>Dust in your DVD burner can prevent it from burning DVDs correctly. Buy a lens cleaning disk and use it in your DVD burner drive. This can clean things up and give you a clean, successful burn.
3>For better quality burn at slow speed.It’s always tempting to burn DVDs at the highest speed possible. In theory, you’ll save time and can get more DVDs burned. In practice, though, higher speeds can result in unreliable burns.
Slow things down and set your DVDs to burn at 4x or even 2x. This may eliminate errors.
I hope this will solve your problem.
Mar 22, 2010 | Computers & Internet
I keep getting skips in audio files when i play them after burning. I have tried burning both data discs (my cd players support .mp3) and Audio discs.
Try burning at a lower speed like 24x. Burning too fast is the cause of the skips, because the data cannot be transferred at a steady pace.
May 19, 2009 | LG GSA-E40L Burner
Will not mount DVD
Try another brand of DVD media. The data density on dvd's is much higher than cd's. I have not had any luck with cheap brands of dvd's. You could also try slowing down the burn speed. The cheaper dvd's may need a slower speed setting.
Are you letting the dvd burner "verify" the burn? Or are you skipping that step? Verifying the burn won't fix a bad burn, but it will let you know if the burn failed. Then you won't keep the dvd around until later, just to find out it doesn't work.
Mar 21, 2009 | Apple MacBook Pro Laptop Computer with...
Mi dvd-burner doesnt recognize blank DVDs and doesnt burn them
Sounds like bad media to me. Have you tried a more expensive blank like Memorex?
Geno
Feb 27, 2008 | Lite On LH-20A1H DVD RW Dual Layer Burner
try downloading www.slysoft.com thier Dvd player play and burns everything and you can do a trail run for 20 days or so lala linda
Oct 03, 2007 | NEC ND-3540A DVD RW Dual Layer Burner
DVD - Slow burning speeds
Unlikely that there is a problem with the drive itself, most likely cause is software settings - which burning software are you using? if it is nero 6 then once you click burn after arranging the files for burning, the burn info page should pop up. click on the burn tab and make sure that "determine maximum speed" is checked and that write speed is set to maximum. hopefully this should solve it, if not try setting write speed to one of the slower settings listed and see if you get a better result. Sometimes dvd drives can slow right down when you are trying to push them to go at maximum. if you want to check what it should be able to do, try http://www.pcpro.co.uk/reviews/87363/sony-dru820a.html also worth trying is updating the drivers http://drivers.softpedia.com/get/FIRMWARE/Sony/Sony-DRU-820A-10b.shtml to make sure you have the most recent version. Another thing worth trying if you haven't already is try a different brand or type of disc - just occasionally there can be clashes with certain types and burners - if this seems to solve it, don't throw your pack of discs away, give them to someone with a different burner. The final possibility is a power supply problem. If your PC's power supply unit has spare connectors for a drive then try a different one - possibly your supply doesn't have enough guts to run a more modern drive - take the drive out and try it in another pc with a higher power supply wattage rating. Hope this helps :)
Feb 28, 2007 | Sony DRU-820A DVD RW Dual Layer Burner
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
