I am not good with electronics. Have bought a jensen antenna for a tv - tv611 - how does the UHF n VHF wires both fix into the 300/75-ohm balun????
  • 1 more comment
  • kgair Aug 21, 2010
    Everything came in the one box - I just don't know how the wires connect to the plastic balun which then go into back of tv - do I push them into the balun - they slip out
    Sorry - I'm obviously not able to explain my problem - please do not bill me.
    The box instructions show the two wires placed on top of each other and they somehow go into balun before sticking in back of tv where antenna goes. I don't know how the wires stick into balun. Again I'm obviously not able to explain my need - it's very very basic and unfortunately I have no idea what these replies are saying. I will take back to store. Thankyou for your time. Please do not bill me.
  • 5,138 Answers
Go to walmart but UHF/VHF connector,one that you can connect both wires too and then plugs into TV.Cable IF
Posted on Aug 21, 2010
    Brigadier General:
  • 6,966 Answers
Hi and welcome to the site,
A single 300 to 75 balun would not work; instead a UHF & VHF combiner is needed. Please click here. This model accepts 300 ohms UHF and 300 ohms VHF inputs and outputs to 75 ohms.
Good luck and thank you for asking.
  • 11,800 Answers
Theoretically you don't connect both, each cable should come with its balun transformer. But if you extend the VHF dipoles the difference in native frequency will be so great that you can put the cables in parallel without any loss of signal. Just make sure the cables are in faze - left with left.
Attach tv converter box
Everything is digital now. You will need a digital converter box. You will connect an antenna to it, and then connect the box to your tv. The box will come with it's own remote. Your tv will be set to channel 3 or 4 (depending on the converter box you get), and you will control the stations with the remote that came with the converter. You can get them at any electronics store.
Jan 09, 2014 | Jensen J53-BWR 5 in. Portable Television
With or without my indoor rabbit ears, cannot get any channels below 7. the people where i got the antenna told that i could connect my roof antenna to an adapter and connect it to the antenna input on the...
Hello
You heard is correct. Your roof antenna can be connected to your TV, after connecting it to a balancing coil adapter, usually called 'Balun Adapter" which converts the impedence from 300 to 75 Ohms. It can be bought for most of the electronic shops all around. Connect the antenna wire to it and then plug it to your TV antenna in socket. The stations will be very clear, and well defined. You may have to turn the roof top antenna towards the direction of the transmitting tower to get a well defined, ghost free image. OK.
Mar 27, 2011 | Televison & Video
How does my mother hook up the antenna and get her TV to work (no cable)
First, you'll want to make sure that her antenna has a coaxial cable (one of the thick round ones) coming from the antenna. Some older ones have a flat piece of plastic with two wires sticking out. These are less efficient, but if you have one, use a balun (a vhf-uhf matching transformer) to change to coax. You can google "balun" if you don't know what one looks like. Next, you'll need a digital converter box (if you don't have one already). Connect one end of the coax cable to the antenna (or balun) and the other to the jack on the converter box labeled "ant. in." Finally, using another coax cable, connect one end to the jack on the converter box labeled "to tv" and the other end to the jack on the TV labeled "ant. in." Finally, depending on your converter box, you will probably need to "scan " for tv channels. Follow the setup instructions with the converter box to do this. If you don't have the instructions, try googling the converter box company and model number to find the users manual. I hope this helps, and good luck! Sincerely, Der Strom
Apr 09, 2010 | Sansui DTV1300 TV
I can't get FOX on my converter box--what is the channel # for FOX?
It could be your antenna. Some retailers sold consumers UHF-only outdoor antennas and not VHF/UHF combo antennas. Other outdoor antennas may not have a power boost included for the VHF antennas (rabbit ears). The new DTV signals from stations are now broadcasting in lower power signals than before June 12.
Outdoor Antenna
KMSP/FOX 9 and KARE 11 both broadcast on VHF signals. WCCO and KSTP broadcast on UHF signals. You will need a VHF/UHF outdoor antenna to pick up KMSP and KARE 11 and also get all the other channels.
Indoor Antenna
Check your antenna to make sure it's a UHF/VHF antenna. You may need an indoor antenna that has rabbit ears -- that is the best way to get KMSP/FOX 9 reception on your TV. Your antenna should have a power boost to amplify the VHF signal if you are having trouble getting FOX 9 or KARE 11.
What Antenna Is Right For You?
Need help locating the proper outdoor antenna to receive your local television broadcast channels? Based on geographical maps and signal strengths, AntennaWeb.org locates the best antenna for you, whether it's a home satellite system, high-definition television (HDTV) or a traditional analog set.
Make sure you antenna is pointed toward Shoreview, where FOX 9 transmits from.
CALL FOX 9 FOR HELP: 952-944-9999
Apr 07, 2010 | Televison & Video
Since the digital switchover, I have lost channels, despite re running the setup and tuning. Any suggestions as to why this is happening?
I have a similar issue. When the digital switch happened here some of the local TV stations changed frequencies from UHF to VHF. I do not have a VHF antenna so I am unable to receive these channels. I do have a great UHF antenna, but it will not receive VHF. The fix is of course is a new UHF/VHF antenna. I am 50 miles away from the TV transmitters.
This may or may not be your problem. I hope this is helpful to you.
Bob
Nov 08, 2009 | JVC LT42P789 42 in. LCD TV
Has anyone figured out IF such a digital anntenna exist yet?
You don't need a digital antenna; any indoor UHF/VHF antenna will work. The antenna and the TV both connect to the converter box, not to each other.
A standard rabbit ears (UHF/VHF) antenna with flat wire (300 ohm) connections can be hooked up to the coaxial cable that goes to the Antenna (RF in) jack on the converter box by using a balun (Radio Shack catalog # 15-1297, about $8). If you have an antenna with coaxial cable already attached, you don't need the balun.
To connect the TV to the converter box, you need an adapter that has an F jack on one end and a 1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The 1/8" plug on the adapter goes in the external antenna jack on the TV, and the other end connects to the coaxial cable that goes to the TV (RF out) jack on the converter box.
Jun 08, 2009 | Casio TV-980 2.3 in. Handheld Television
Converter box connection
You need to get a 75-ohm to 300-ohm transformer, also called a "balun". Radio Shack sells them and you may also be able to find them at retailers who sell TV antennas. It's a small cylinder with a threaded connector at one end for the cable from the converter, and a flat wire with two terminals for the TV connection. Connect the terminals under the "VHF" screws on the TV, put the set on channel 3 or 4 depending on your converter box setting (most are on 3 out of the box) and you're good to go. On a set of that age, you might need to tinker with the fine tuning adjustment a little for the best picture from the converter box.
May 04, 2009 | Insignia Digital-to-Analog Converter for...
Antenna/Cable Switch
You can get a 75 Ohm to 300 Ohm balun from a local Radio Shack Store and connect it to VHF antenna but you won't be able to receive off the air signals for very long because in about a month all TV signals will be being broadcast in Digital Format nationwide and all you will receive is SNOW. You'll need to also buy a Digital to Analog conversion unit as well to receive off the air programming. Sorry for the bad news but that's the advancement of technology and mandates from our government (FCC).
Hope this helps and Happy New Year,
Backyard_Jim
Dec 31, 2008 | Symphonic WF-719 19 in. TV/VCR/DVD Combo
I bought a 32" conia tv and i cant get good reception! i have bought a amplified antenna and a hd set top box and still no good reception. my other tv's in the smae spot have had no reception issues....
well it's the same as the days of old, the antenna has a range of reception. the further the sations antenna, the lager your antenna must be. just because you bought an amplified antenna does not mean you will receive the deep fringe station. also the antenna must be UHF and VHF to receive the broadcast in digital. most of the braodcasters have gone with the UHF band because it is more stable for the bandwith of digital broadcast. the UHF band is very directional as well, so you must be pointing to the broadcasters antenna. no set top antenna will work if you are further than 15 miles of the broadcasters antenna. the roof top UHF/VHF antenna with a preamp is the way to go. I have tested every compact antenna and unless you live in the city that the broadcast generates you will get no reception with these. terks are junk, and any small amplified antenna does not work if you are in low lying areas. roof top, roof top,.....ROOF TOP!!!!!
Apr 24, 2008 | Televison & Video
Televison & Video Logo
1,355 people viewed this question
Top Televison & Video Experts
