Question about Mackie 1604 Vlz3 16 Channel Mixer
Smoke came out from the console after 15 mins of testing. Just bought this one from craigslist. Needs repair. Thanks.
  • Mackie Master
  • 5,603 Answers
That may be minor or very major. Open the unit and look for damage.
Best case, loose debris in the unit shorted something in the power supply. Probably replacing one or a few small components to repair.
Worst case, debris or failed component has burned large area of board. This would be fatal.
I have schematic so let me know what you find as source of the smoke. Note that most of these use surface mounted parts and require a bit of soldering skill to repair.
Posted on Aug 21, 2010
I have a behringer pmp5000. At Practice one of the cables was stepped on and came out of a speaker.then, plugged back in immediately. There was some smoke and now the unit wont even turn on. Can this be...
Yes, it can be repaired. Likely at least the output transistors are fried, possibly the drivers are too. Possible other components like resistors gone, too. Needs somebody that knows amps.
Jan 20, 2015 | Behringer Europower Pmp5000 Powered Mixer...
Jb leon515 one speaker cutting out after about 1 hour
It's probably a thermal problem with a component. You should take it into a repair shop as it is not user serviceable.
Oct 01, 2014 | Jbl Eon 515 Eon515 15 Powered Portable...
Alesis Multimix8 started smoking and now won't turn on. If it is a fuse or something how do i replace it?
A blown fuse will not produce smoke. A component failed and probably fried a resistor, which would smoke. That in turn would blow the fuse.Just replacing the fuse will not cure the problem. Your unit needs repair.
Dec 27, 2012 | Alesis Multimix 8 USB 2.0 - 8 Channel...
Kustom KPM7250T mixer made a loud popping noise and lost sound to speakers during gig, but front power lights stayed on. Accessible fuse good. have it at dealer to see if can be repaired but he needs...
Pilot lights mean very little. Either a filter capacitor failed or other part(s) failed. Needs to go to the repair shop. The damage MAY be visible or require test equipment to diagnose.
Aug 11, 2011 | Kustom KPM7250T PA Amplifier/Mixer
Just bought. New b205d power is on but no sound
These are a nice unit... just bought three of them that were dead... I have repaired one so far. I assume you mean the blue LED is on indicating power is on. What I want you to test is if injecting signal on the BACK of the unit jack (power amp in) will create sound. If it won't then better exercise your warranty. The one unit I have completed repair had a bad 15 volt regulator in it... the second that is almost fixed somebody had blasted the input circuits... probably connected to a speaker output... don't do it... these are LINE and MIC level units. If you need to tap off a speaker output, use a DI box with the unit. The third unit I have not received yet. Drummer used the repaired one as monitor last night and was impressed with the power this unit has.
Jul 22, 2011 | Behringer Eurolive B205D Active 150-Watt...
Hi I got PMP3000 and all of a sudden in the program smoke came out of the unit and I unplugged the Mixer...I have given it to repair and they saying the Main power SMPS has blown out..they charging too...
Sorry... you likely have one of the power amp channels bad as well. One does NOT replace the power supply, instead repair it. You need a competent repair shop. I can tell you what parts are blown on the supply. They cost about $30 max for parts to repair the power supply. There usually is about $15 of parts blown on the amp that caused the problem and significant labor to repair the amp portion. If the smoke was dark or heavy, it was likely from the 0.03 ohm metering resistor on the bottom of the amp circuit board that caused the original problem. If one replaces the power supply and turns power on they will find one side of the amp doesn't work and MAY blow the power supply again immediately. I have repaired several of these units and have walked others through the repair sequence as well. You can contact me directly by email for more info if you need it. Unless you can find a competent repair shop that replaces components, including work on surface mounted boards, the cost of the module parts AND availability will preclude repair. The amp module is another $155 after the power supply is repaired if a channel is bad and one chooses to replace rather than repair.
Apr 19, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Got smoke from inside keyboard and diskette, hard drive and scsi no longer show as available on system screen. Am using midis from HD but can't view it when using disk utilities. I suspect a board is gone,...
Any electronic device that has smoke coming from it is not a good sign. Whether it can be repaired is debateable (it depends if parts are available and costs). Usually in cases such as this it needs a new circuit board and possible other associated components/devices. I suggest the best solution is to purchase a new Yamaha keyboard as a new model would have new and better features.
Nov 19, 2009 | Yamaha Portable Keyboard
Audi 90 20v bought recently was driving up hill started spuddering and blowing massive white smoke out exhaust not losin water burning outrageous amounts of fuel. oil smells like gas. sometimes backfires...
master cylinder may be bad....heres why..if you have a bad seal on your master cylinder break fluid is sucked into the booster via vacuum line..when it gets full of break fluid it gets sucked into the engine and the exhaust systm...this will make a car run terrible at times and smoke very bad...especially up a hill or turning...thanks and have a great day
Nov 08, 2009 | Music
I am getting the error message scn on my p120 keyboard and there is no sound from the keyboard.
Just bought a P120 from craigslist. A computer recycle company was selling it as parts for $150. They said it has the SCN error code and the keys don't play. It played the demos only.. Payed $100; took it home, opened it up & found the keyboard plug had detached from the motherboard. Plugged it in & BAM! It works just fine.
Oct 18, 2009 | Music
Loud speaker hum then blows fuse
Hi there. The final output IC (big and black with 15 pins? attached to heat sink) is shorted and needs to be replaced. If you can still see color bands on R63, it should still be good.
Thanks
Paul
Jul 12, 2009 | Music
Mackie 1604 Vlz3 16 Channel Mixer Logo
82 people viewed this question
Top Mackie Music Experts
Michial Gueffroy
Matthew Spark
Matthew Spark
Vito Vacirca Jr.
Are you a Mackie Music Expert? Answer questions, earn points and help others
