Connection I can't connect to the internet using my wireless on my laptop. It says to turn on my LAN switch on, but it is already on?
  • Georgia B
    Georgia B May 11, 2010
    Is this a newer laptop? Look on the sides and the back for a switch.
  • lan switch??or wlan??
    Guru:
  • 1,342 Answers
Assumed solved. No reply to clarification request.
Posted on Jul 26, 2008
  • 13,433 Answers
Try turning it off and on, off and on.
also restart the laptop and keep switching it off and on untill the wireless light comes up. if its not coming up at all.
Posted on May 04, 2008
I have internet connection but cannot access internet
Bluetooth connections allow devices to connect without the use of wires or cables.
Some users of the Sony Vaio laptop computer have encountered problems with the connection of Bluetooth devices with their computer.
The problem lies with turning on the Vaio's Bluetooth function.
This is turned on through the computer's Wireless Switch Settings manager.
The icon for this is in the system tray in the taskbar when the computer is first purchased.
Double-click the "Wireless Switch Settings" icon in the system tray of the taskbar.
It is a a blue-green icon with "LAN" in one corner and "B" in the other.
Check the "Enable Bluetooth Device" setting in the Bluetooth Device section.
Click "OK."
If the device was already enabled, change the wireless LAN from "2.4GHz" to "5GHz" because, as the warning message should say, using the 2.4GHz wireless LAN and the Bluetooth device can make the connection unstable.
Click the "Apply" button after the appropriate boxes are checked to activate the Bluetooth signal. A blue light should come on near the computer's on/off switch for the Wi-Fi radio.
Click "OK." Another dialog box should appear explaining that the Wireless Switch Settings icon should now be in the taskbar.
Use this icon if you need to turn off or on the Bluetooth device in the future.
http://supportforsony.iyogi.com/vaio-f-series/bluetooth-4.html
sony support
Apr 15, 2014 | Sony Vaio Tap 20
Dell inspiron 1525 not connecting to internet
I am one of the Dell Certified System Expert.
For internet connection, there are two ways to connect to the internet. One is through wired connection (connecting LAN cable) and connecting to wireless connection (through wireless router or through wireless Modem WLAN).
For wireless check the switch located on the left side of the portable after switching check the status light located at the front left of the computer.
check the driver if it is properly installed meaning no bang(!) or question mark(?) for both ethernet (LAN port) and Wireless Device.
To check the driver go to control panel then device manager. Check the network and you should be seeing the ethernet and wireless device. If not installed use the driver cd that came with the computer.
How to check the internet connection.
For Wired connection:
First check the cable, check the LAN port in the computer there should be blinking lights, if none try to reseat the cable. Check the ipaddress of the computer and the default gateway.
This is the instruction to get the IP address and default gateway.
For windows xp
1. Click start, then choose run then on the box type CMD then click ok.
2. on the black screen type ipconfig. get the ip address and default gateway.
3. normally it will give you 192.168.XXX.XXX
4. try to type ping 192.168.XXX.XXX (this should be the gateway)
5. If you receive replies, then you are connected to the router/modem
6. then try to ping www.yahoo.com
7. if still reply then you are connected to the internet already, might be your issue is browser or security on the computer.
For vista and Windows 7
click windows then in the start search type cmd, you should be seeing cmd on the top, right click then choose run as administrator. then follow steps 2-7 above.
For wireless connection
Check the switch, and the status light, if all are checked checked the ip address and default gateway as well, the instruction is the same above.
For more information about setting up your system please refer to the link.
http://support.dell.com/support/edocs/systems/ins1525/en/SG/Y465HA01MR.pdf
Hope this will help you a lot.
Thank you for choosing fixya
Mar 01, 2011 | Dell Inspiron 1525 Notebook
Cannot the wireless internet setup
Hi kschmerer,
I understand that you are not able to setup the Wireless Network Connection in your Computer.
To fix this issue, please make sure that the Physical Wireless Switch on the Computer is turned ON and then try connecting the Computer to the Wirelss Network.
You can locate the Physical Wireless Switch on the front side of the Computer. Please move the switch toward right side to turn it ON.
Once the Physical Wireless Switch is turned ON, please try setting up the Wireless Network Connection.
If you are not able to to connect to Wireless Network Connection after switching on the Physical Wireless LAN Switch, try using the Wireless Switch Setting Utility.
To enable the Wireless Network Connection using the Wireless Device Switch Utility, please double-click the Wireless Device Switch icon on the right corner of the Taskbar. Then in the open Wireless Device Switch window, please click to check the box next to Enable 2.4Ghz Wireless LAN.
This should fix the issue.
Please post back if you have any questions or require further assistance.
Thanks for using FixYa.
Dec 07, 2010 | Sony VAIO VGN-AR150G Notebook
Where is button to turn on wireless internet connection
see the operating instruction manual here :
http://dl.owneriq.net/d/d94ab07b-788b-41ca-8def-00135155738c.pdf
or read below :
For instructions on settings for wireless LAN and cautions during use, select [start]-
[Reference Manual], and refer to "Wireless LAN".
Before using a wireless LAN, turn the wireless LAN on using the following method (at
the time of purchase, the wireless LAN is set to [Off]).
Double-click on the taskbar.
2 Select your wireless LAN adaptor and select [General].
3 Select [On] for [Switch radio].
4 Select [OK].
The icon will turn to or ��
Oct 04, 2009 | Panasonic Toughbook T2 Notebook
How a conect to internet
METHOD 1 - Using Internet connection using DSL or cable connection.
1st. If you wish to connect to the Internet with a LAN cable or a wirelessly and if your computer doesn't have a LAN card or wireless LAN card you need to purchase a LAN card (to configure the wireless router) and if you want a wireless connection you will also need to purchase a wireless LAN card.
2nd. You need to select an Internet Service Provider in your area with a plan and cost to suit your requirements.
3rd. You need to decide what type of broadband connection you need, DSL or cable modem with or without a built-in wireless router, the Internet Service Provider can assist you with this.
5th. The Internet Service Provider can supply these items or advise you what make and model to purchase. They will also provide information on how to connect and setup your Internet connection.
METHOD 2 - Using USB wireless adapter that plugs into the laptop's USB port. It doesn't need a wireless router or a cable or DSL modem.
This is used mostly on laptop computers which allows Internet access anywhere the Internet Service Provide has a wireless transmitter. It uses the G3 mobile system.
This type of service usually costs more and again you need to select an Internet Service Provider that can provide the wireless coverage, the plan and costs that suit your requirements.
Installation and setting up information is supplied by the ISP.
Jul 31, 2009 | Computers & Internet
Hi, I have an old acer laptop and my wife communicates with me on it using broadband and a router with a usb pick up. I have returned home and have a new acer laptop with wireless LAN already installed. It...
Youe broadband router is working ok with the broadband cable.So it is configured with the broadband cable.Now,to work with the wireless internet,you have to configured the wi-fi router to work internet.You can see the wi-fi connection but unless & untill you will configure wi-fi router it must not work or if before it was working with the wi-fi then you can check the wi-fi router setting because it might change by mistake.Surely it will work after configurating wi-fi router.
Jan 03, 2009 | Computers & Internet
Laptop will not connect to the internet anymore.
are you using wifi connection, I mean wireless connection or you're hooking up to a LAN network or through a modem connection?  If all this connection wouldn't worked out anymore, try reinstalling your Operating System!
Dec 13, 2008 | Acer Aspire 5100 Notebook
Shared internet connection help!!!
are you using window xp for both pc?
Aug 25, 2008 | Computers & Internet
Guidance setting up a shared connection :)
1- set up router trough desktop
2-run program for wireless, after it gives you the IP ( which it already has, set user name and password for protection)
3-set up the laptop as a "Shared folder" along with the printer if there is one.
Aug 24, 2008 | Computers & Internet
Computers & Internet Logo
170 people viewed this question
David Payne
David Payne
