Question about Pyramid 10 BAND EQ 300 W WITH LIGHTS Car Equalizer
Is the plus wire the solid color wire or the color wire with the tracer? Thanks
  • 12,061 Answers
Well usually the solid color is the Plus, and anything else is NOT. Usually the Positive will have a fuse in it though?
If you have a meter, simply connect up to that wire and earth, and see if there is a connection, there shouldn't be, if NOT, then, that will be safe to hook up to the Positive. Usually the Case will provide the Negative, or earth.
Your manual below.
www.pyramidcaraudio.com/manuals/PA305.pdf
Posted on Aug 21, 2010
I am trying to check voltage to my 2006 jeep liberty v6 fuel pump. There are 4 colored wires, I need to know which wires are the hot, and groundrive for the pump.
The dark green wire with orange tracer is voltage for fuel pump motor. The solid black wire is ground.
The other two wires should be for fuel gage sending unit.
Mar 05, 2016 | Jeep Cars & Trucks
What does o/w mean in a 2001 heritage softail wiring diagram?
That is the abbeviation used for the color of the wire. Yours is an orange wire withe a white tracer line going around it. IMPORTANT*
Do not confuse o/w Orange with a white tracer line with w/o White with an orange tracer wire. The first letter in o/w will stand for the primary color of that wire, in this case Orange.. It will be a bit thicker width on that wire. The second letter, in this case White, will stand for the tracer color, look closely, the tracer line is thinner than the primary line. This is so you can more easily trace wires on your bike. There will be more combinations of colors used on your bike, but they will all follow the same rule. Primary color is the first letter and is wider or thicker/ Tracer line is the second letter and the line will be thinner than the primary.
Apr 18, 2013 | 2004 Harley Davidson FLSTC - FLSTCI...
Brother took off wall sensor wiring and now I don't know what colored wires go together
The solid white wire from each sensor goes to terminal #2 and the white wires with the black tracers go to terminal #3.
Sep 21, 2011 | Sears Craftsman LiftMaster Chamberlain...
GE Network & Coax Wall Plate has 8 wires of solid colors. My CAT5E cable has 8 wires, only 4 of which are solid and correspond to 4 of the solid colors on the wall plate. The other 4 wires on the CAT5E...
Hello
Your cat5 will make up 4 pair. org/org/wht being one pair and so on.
So as long as you keep them in pairs you will be ok.
Meaning. Pair one from cat5 org and org/wht to wall plate wht and brn.This would be one complete pair.So the wall plate colors are different from cat5 but as long as you stay in pairs and go from left to right on your conections you should be ok.
Jun 05, 2011 | Computers & Internet
Witch wire is the ground on the headlights socket
Hello jbarnes12342: My name is Roger and I will help you. The center wire in the lamp plug should be the ground. The wires on the out side of the plug should be colored wires with a tracer color on them. The center wire is a solid black wire. The black wire is the ground. Should you need further help please just ask. Please rate the answer. Thank You for using Fix Ya. Roger
Apr 25, 2011 | 2000 Ford Expedition
Need wiring diagram for eyes that control safty device door willnot close by one button push , have to hold button to close , light on opperator has one flash
Safety reversing sensors wire open (broken or disconnected).
Each sensor has a solid white wire and a white wire with black tracer.
The solid white wires go to terminal 2 and the wires with the black tracer go to terminal 3.
Jan 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a 93 Ford Laser hatch back and I need to know the radio wiring color codes for the wires that plug into the back of the radio-cassette. 1)Orange-green tracer 2)Orange-black tracer 3)Grey-green...
OK this is what I did: First I soldered a wire each end of a 1.5v battery. I then bared the other ends of the two wires and tinned them. Then I touched the wires coming from under the dash in pairs until I heard the resultant sound coming from a speaker. This then told me the position of each speaker in the car. From there it was just a matter of noting the color codes for each pair of wires and from which speaker they came. My Gregory's Laser KH manual had wiring codes, but entirely different to my vehicle. Also there is no indication of what color matches what letter code! Cheers. Gerry
Dec 19, 2009 | Philips Car Audio & Video
What color is the wire leading out from the PCM to the starter?
There is no wire that comes out of the PCM to the starter. It's a completely different circuit that emulates from the Ignition Switch on the steering column...(which is still interchangeable with General Motors). However, the color of wire that attach's to your starter will either be a solid 14 ga.Brown wire or a 14 ga. Light Green with a Black tracer on it, dependent on which engine you have.
"00 Buck"
Nov 06, 2009 | 2006 Chrysler Sebring
I imported a o2 town car executive model into canada.how do i get the daytime running lites to work.Is there a drl module already installed or do i have to buy one.If there is one ...where is it .and whats...
The original lighting module supplies separate power to the left and right sides for headlamp operation. You will have to wire in the aftermarket module accordingly. These are the factory wire colors at the module. Left Low = Dark Blue/ white tracer, Right Low = Dark Green/ Orange tracer, High beam = Light Green/ Black tracer.
Goog luck
Oct 30, 2009 | Lincoln Town Car Cars & Trucks
Wiring diagram for garage door sensers Garage Master 1/2 hp part # 41A4252-7G
Each sensor has 2 wires. One solid white and one white with a black tracer. The solid wire from each sensor goes to terminal 2 and the white wire with the black tracer goes to terminal 3.
Oct 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Pyramid 10 BAND EQ 300 W WITH LIGHTS Car Equalizer Logo
41 people viewed this question
Top Pyramid Car Audio & Video Experts
Greg Cann
Greg Cann
Steve Sweetleaf
Steve Sweetleaf
Mark Skinner
Are you a Pyramid Car Audio and Video Expert? Answer questions, earn points and help others
