Question about Spektrum Dx6i Computer Radio
When I turn my radeo on the low battery keep flashing even when I put other batties in
Did you work it out, the same thing just happened to me today, it's not throttle hold or flight mode switches on or anything like that.. it just keeps flashing low battery, went out and bought fresh batts, it switched on the first time and told me 6.5v, then when i tried to switch it on again i got the low battery screen and a bad smell.
Posted on Sep 11, 2010
  • punkinboy Sep 11, 2010
    sorry that's no help!
Tail light dont turn off there on even when i turn the jeep off
no jeep stated, no year stated.
wow.
tail = parks
jeeps can have lots of PARK lamps, only 2 on tail
the park relay is bad (stuck)
if car drives perfectly, but you never said that.
if all else works that tells my battery voltage is OK
and that the BCM didnt go batty, (on low volts failures)
pull there relay, see?
this jeep? has tails, rear, only.
Feb 10, 2017 | Jeep Cars & Trucks
HI GOOD DAY I CANT TURN ON MY CAMERA IT DOESNT WORK EVAN WITH NEW BATERY THANKS
Check to make sure the batteries are inserted correctly.
Clean the battery terminals with a dry cotton swab that has a fine and soft tip, and then re-insert the batteries.If the [Memory Card / Battery Cover] is not securely closed, the power of the camera may not turn on.Close the [Memory Card / Battery Cover] securely, and then turn the power on.
If your camera still does not work even after you have performed the above procedures, your camera may be malfunctioning. Please have the camera serviced in this case.
Apr 19, 2011 | Canon PowerShot A460 Digital Camera
The intior lights went out and none work. I tryed to put in a new radeo and it wont even turn on. how can I fix the wirering so that it will start working and the radeo will play?
Sounds like you may have crossed a wire and perhaps blown a fuse..
have you checked your fuse box? If not, you may also still have a crossed wire or otherwise a short existing somewhere.. retrace your steps and take a closer look around you will find either a short or otherwise a wire which may be unplugged...
Ck
Feb 13, 2011 | 1998 Dodge Neon
Whenever I put new batteries into my Canon Powershot A480, I get the same thing - I get the 'Low Battery' red flashing light. And Then as I go to take a picture it shuts off and says ; Change The Batties....
I've got the same problem with 2 A 480 canon. I put in NiMH batteries and they work fine. If you put in slightly drained used batteries they work!! Nimh batteries are 1.2 volts and Alkaline are 1.5 volts. There is definitly a problem with this camera. I measured the voltages of brand new batteries 1.51 volts each and they didn't work. I put in some old batteries 1.4 and 1.42 volts and they worked fine.
Dec 17, 2010 | Canon PowerShot A480 Digital Camera
My Samsung Digimax 420 keeps saying low battery!
Check that you are using the correct type of batteries and that they are rechageable as i found i had a similer problem when using just normal non recargeable
Dec 22, 2008 | Samsung Digimax 420 Digital Camera
Type of batties
TRY RECHARAGEABLE BATTERIES...IF THIS DOES NOT WORK THEN YOUR CAMRA MADE A SHORT CIRCUIT
Feb 21, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
IBM Thinkpad Errors
Good evening!
163 & 173 are "date not set" and "configuration data lost", respectively.hat can be caused by the BIOS battery being dead, among other things. The 192 is a fan error, which also can be caused by the BIOS battery being dead. These errors can also be caused by other things, such as a bad system board, etc. But from what you've told us, I'd check that the BIOS battery is up o snuff, or that it may have gotten disconnected.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thank you, and have a super day!
Ron-
Dec 11, 2007 | IBM ThinkPad 600X Notebook
Startup problem
I have the same problem with this flash. In a couple of days I'll find out what's wrong with it, and write here.
Sep 19, 2006 | Minolta 3600HS (D) TTL Flash
Spektrum Dx6i Computer Radio Logo
271 people viewed this question
Top Spektrum Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Spektrum Toy Expert? Answer questions, earn points and help others
