Question about Philips 27PT543S 27" TV
Is there an on line manual for element 32inch . The tv turns on,but after 10 minutes of being on the sounds stop working . Even the remote is unable to turn the tv on andoff. the only way to turn off is to unplug it. what is making the sound go away ? Even when I turn the tv on manually it doesn't work
  • Philips Master
  • 1,229 Answers
Betty I have repaired a few of these. The biggest problem is capacitor location 2455, which is a 25 volt 47Mf capacitor. This capacitor is dry and the voltage is rising and shutting things down. Also resolder Q7461 and Q7463, these are transistors. Take this note to your local TV tech to fix your TV! Thanks for asking me...repairs are near!
Posted on Aug 21, 2010
I lost my remote and I can't get to my WiFi network how do I reset my 32inch hisense TV
First, how can you 'lose' a remote control?
Second, what does your television have to do with you getting on wifi?
Google
Hisense replacement remote control
You Reset most things by disconnecting from the power for 10 minutes.
Jan 18, 2017 | Hisense Televison & Video
HOW do I get my element lcd tv 32inch flx3711b to work with my toshiba satellite C75D A7370 windows 8.1 via hdmi cable. The cable works on my tv in kitchen however, on the Element TV no picture shows.
a couple of things. on the computer lower the res to 16 bit. 800 x 600. 60 hz. on the tv look for input and change it. or look for video on the remote control. also look in the owners manual if you have it. also since you have a blank screen try moving the mouse off the screen and to the right and to the left. you may have it set to extended instead of copy.
Nov 05, 2014 | Televison & Video
Tv stops responding to remote after 10 minutes
I have same issue and not just remote even controls on tv do not work. Eventually hitting power button will turn it off then I can turn on and have functions for 3-10 minutes. Wish someone had a solution
Nov 23, 2012 | Toshiba 46SL417U LCD TV
Bought an 32inch LCD HDTV DVD Combo not even a year ago---there is picture but no sound---can't turn up sound with remote or even turn up sound manually--any ideas?i
Good day!!!
That problem is usually cause of low reception if you are using aerial antenna,if your are using cable or digital signal check your wiring and the worst is you have defective audio IC..
I will teach how to determine the exact trouble just click this link LCD HDTV ASSUMED TO FIX and click "get service"..
Thanks for using fixya...
Nov 03, 2011 | RCA L32HD32D 32 in. LCD HDTV
Element 32 inchTV want turn on. When hitting the power button it turns on for a quick second display the digital tv words and click back off.
This is a protection circuit that prevents the tv from coming on (to stop damage of the components) ....you need to check your voltages off the power supply and make sure they all read well (EX: 24v12v5v etc). Also look for popped capacitors that would make the values lower than need be for the tv to power on properly.
Once you repair the power supply then you may need to replace other components if needed!
Please rate if this helps! :D
Mar 08, 2011 | Element Electronics FLX-3211B 32 in. LCD...
What would cause the sound on a lcd hdtv 32 inch flat screen tv to just stop?
What other device are you connecting to your tv and how are you connecting it?
If you connect via a single HDMI cable that may be causing your audio problem. Some Tv and STB have handshacking issues which can knock out audio and/or video. The only solution would be to replace the HDMI cable or switch to composite cables.
Dec 14, 2009 | Element Electronics FLX3220F 32 in. LCD TV
Element 32inch Flatscreen Sparking
Hmm, never heard of Element TV before... I suggest calling the manufacturer and letting them know that this is happening, it sounds like the unit is damaged or faulty in a way that trips the breakers, loose wiring, broken wiring, even a bad fuse can do this. As long as you haven't opened the unit, the warranty should apply and they should help you with the problem.
Dec 27, 2008 | Televison & Video
42mf231d/17 fails to turn off manually or w/ remote.
Magnavox suggests unplugging the tv for exactly 10 minutes to reset the tv---try that---or call the service number for assistance
Oct 25, 2008 | Philips Magnavox 42MF521D/37 Television
RCA TV Remote Malfunction
From your post I understand that the tv is not turning on even if you use the button on tv, if that is the case there is nothing wrong with the remote control, and from the blinking light shows that there is something wrong with the tv. Get it checked by a qualified service guy.
Jan 25, 2008 | Televison & Video
Philips 27PT543S 27" TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
