I have a cineplus widescreen tv, but no manual to know how to hook up a dvd to the tv & what button do I press to play the dvd?
  • connie haluschak Aug 21, 2010
    The model of the tv is cineplus LCD. Model # is LC-27R25C
  • 4,472 Answers
First off I need the exact make and model of the tv and the dvd player. To hook them up you go from the output on on the back of the dvd player to the input on the back of the tv. As far as playing the dvd you just press the play button on the remote. Once I have the make and model information I can help you.
thank you,
Lee
Posted on Aug 21, 2010
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
Can not find codes for toshiba remote for my sony dvd home theater changer nor any specifics on hooking it up properly and it has s video but no hdmi hook ups help By the way i already pd 1459.00 dollars...
To find the code for the Toshiba remote to the Sony DVD changer.
If you do not know the device code for a particular device, you can view each available code for that device mode and sample the functions to find the code that operates the target device. 1 Press a mode select button on the remote. 2 While holding down INFO button , press 8, 5, 0, 0. The remote control enters program mode. 3 Point the remote at the target device and press Power button, 1, VOL UP, CH UP or PLAY. Some keys are ignored if they are not applicable to a specific device mode. 4 If the device responds to the remote control: Press INFO button to store the device code. The mode select button blinks twice. The remote exits program mode. 5 If the device does not respond to the remote control: Press UP. Press POWER. Repeat this step until the device responds to the remote. Press INFO . Note: When a search cycle is completed, the mode select button blinks 3 times. The remote displays each available code again. If no key is pressed within 10 seconds, the remote exits program mode and returns to the previous code.
The previous section was from the manual p.86: http://www.iusermanual.com/tv/toshiba-46vx700u-tv-manual.htm
Hooking the DVD changer to the TV: The TV has composite video inputs and can accept s-video by a adapter cable as in: http://www.amazon.com/S-Video-3-RCA-Composite-Cable-Laptop/dp/B002ZKTCUM/ref=pd_cp_e_1
May 05, 2011 | Toshiba 46VX700U LCD TV
Dvd stuck in RCA widescreen tv
There are two things you can try to correct this problem on your TV/DVD combo unit:
  • If you're using the remote control, press the DVD/TV button first to make sure the remote control is in TV mode.
  • If you're trying to use the buttons on the front of the unit, unplug the TV/DVD for two minutes, and then plug it back in. Press the ON/OFF button and try again.
Feb 20, 2010 | RCA L40HD33D 40 in. LCD HDTV
I have an old DVD player from 2002 & I'm trying to hook it up to my TV (old TV too). Do you have a graphic of the hook up? The TV has a spot to hook up my cable for my basic cable channels. The DVD...
You connect up a DVD to a TV via the Audio Visual leads, they go into the Red White, the Audio, & Yellow, the composite Video. In & Out. They wire color to color. Then you select AV on the TV. & press Play on DVD.
Feb 07, 2010 | Toshiba SD-2800 DVD Player
I have a Pioneer DV-525 DVD player, and recently upgraded from a 4:3 TV to a widescreen TV. However, under the Setup menu, it won't let me change the setting to 16:9. The options are grayed out, and I...
The DVD movie has to be a "widescreen" version...
Check the cover of your DVD movies ... there may be one or more widescreen DVD's in your collection...
That should work.
What widescreen TV did you get? Brand / model.
If it is Samsung ... on the remote, press the "p.size" button (and wait) ... continue pressing and waiting after each press to see if the Samsung will adjust ... You may get a distorted pic ... like very short and very wide people.
What TV Brand / model??
Sep 14, 2009 | Pioneer DV-525
Cineplus tv, loud popping sound, no picture? Warranty co. gone!
having a hard time turning on my Cineplus LC-32R25C
Cineplus 32” High Definition LCD Television...when i hit the power button..thered light on tv goes to yellow..as it it was in sleep mode..and i dont know wat to do to get it out of that state to turn it on..is there a sequense of buttons on the remote i gotta push to get it to work?
Sep 13, 2009 | Televison & Video
How may i hook the phillips dvdr3455h/37 to record from my fm tuner,i have it hooked up as follows audio out on philips to tape in on amp and audio in on phillips to tape out on amp,but when i press any of...
The dvd recorder uses the video signal to detect, thus it will not detect the audio as a signal. I believe there are "boxes" you link in somehow to "fool" the dvd into thinking it's recieving a video signal, but I don't know where to get them.
Jun 14, 2009 | Philips DVDR3455/37 DVD Recorder/HDD...
Dvd player wont play
I found this on the PROSCAN website under customer support manuals.The website is www.oncorpus.com.I hope this information helps you with your problem. IMPORTANT THE LABEL SIDE OF THE DVD MUST FACE THE BACK SIDE OF THE TELEVISION 1. Press the ‘INPUT’ button to select ‘DVD’ mode, if no disc is inserted yet, the display shows ‘No Disc’.
2.Insert a DVD with the printed side facing towards the rear of the TV/DVD Player (see below)
3.The TV will first display ‘Loading’, then change to ‘DVD-video’. Most DVDs will show some preliminary
information then stop at a main menu screen.
4. Press PLAY/PAUSE to play it directly. Or press the DVD-MENU button to access the disc menu during
playback.
5.Use the direction button on the remote control to select the desired option. Press ENTER to select the
option or press the ► button. Playback will now commence.
6.After playback, press the EJECT button on remote control or EJECT button on TV/DVD to remove the
disc.
Note: No function‘’ will sometimes appear on the screen after a button is pressed. This indicates that the
function is not supported at the current time.
Feb 14, 2009 | Proscan 32LA30Q Television
Sound problems
TRY PUTTING A SET OF PHONO CABLES INTO THE VCR INPUT THEN TO THE ANALOG OUT PUTS ON TOUR DVD/VCR SWITCH AMP TO VCR PRESS DIGITAL INPUT BUTTON ON FRONT OF AMP UNTILL YOU GET _ _ _ SET SOUND TO PROLOGIC 2.THIS SHOULD WORK.
HOPE THIS HELPS.
CABLE GUY.
Jun 18, 2008 | Onkyo TX-SR605 Receiver
Widescreen?
The answer was hiding in our Toshiba DVD player manual. We press setup then arrow down to General setting-then Video-then TV aspect- then select 16:9 wide. When finished press setup to exit.
May 18, 2008 | iLO V27DMBX Television
Televison & Video Logo
133 people viewed this question
Top Televison & Video Experts
