Question about Western Digital Caviar SE WD1600AAJS 160 GB SATA Hard Drive
My computer HDD have bad sactors please help to remove this on
  • 32,281 Answers
When a hard disk has bad sectors, these sectors can be fixed by running check disk. This is a temporary fix as the hard disk is nearly worn out and it will get more bad sectors and evenually the hard disk will fail completely.
Bad sectors occur when the magnetic oxide on the disk platters is worn out and data cannot be written or read from these sectors.
To run check disk click Start - My Computer - right click on C Drive and click on Properties - click on Tools tab - then Check Now in Error Checking
I suggest once this has been done, you back up your data and purchase a new hard disk ready to install Windows etc. when the hard disk fails completely. You may want to install a new hard drive before the old hard drive fails completely.
Posted on Aug 21, 2010
My hp desktop says internal hard disk not found how do i reset my drive
First reset the CMOS. Check your motherboard specs for how to do this or remove the small round silver battery from the motherboard; wait 30 seconds and reinstall it. (It is a good idea to replace with a new battery.) This will reset the CMOS. Then reboot to see if HDD is detected. If not, go into the BIOS setup (repeatedly hit F10 at HP logo screen) and check to see if your hard drive is listed. You may have to set it to "on". If it is listed in BIOS, but not detected another drive (a bad one) could prevent it from being detected. If you have any removable or external drives attached to your computer, disconnect them. Reboot your computer to see if your HDD is detected. If not, open your case and disconnect the data cable from all drives except your primary hard drive. This includes the floppy, optical, zip, backup, or secondary hard drive(s). If your HDD is detected, reconnect each drives data cable one at a time rebooting between each. If after reconnecting a drive and rebooting, your HDD is not detected the last drive is a bad drive and preventing your HDD detection. I have found that sometimes a bad drive that is connected will let the HDD be detected then on later boots the HDD will not be detected. Also it is possible that your BIOS is corrupted. Let's hope not. Another possibility is a bad motherboard. I hope this helps you.
Aug 11, 2012 | HP Computers & Internet
My acer aspire 4741z-602G32 had problem... when I start, there is no hdd indicator light & the screen also blank.. please help me...
There could be several problems happening there. One could be the computer has a bad motherboard, or a bad HDD. Without more info theres not alot that can be done from here.
Apr 10, 2011 | Computers & Internet
My pc says insert system disk in drive what happens. please help me.
bad news: hdd has gone bad.
No boot device found. the computer cannot find the hdd in the computer.
Get a new hd. if the computer is in warranty get it replaced else buy another one.
Good news: its not that costly item.
Best of Luck!
Please rate this solution, if you find it helpful. :)
Thanks.
Aug 17, 2010 | Toshiba Satellite 1415-S173 Notebook
It has an error e 74
E74 means a hardware malfunction, might be due to a bad memory storage deive attached to the Xbox 360 which is the hard drive (HDD). Steps to do:
• turn of the console and remove the HDD
• restart the console without HDD
• if it works without the E74 error, the HDD is bad and needs replacement
• if still having the same error even without the HDD, it's is an internal hardware failure inside the sytem already
If all else fails, please contact Microsoft Xbox Support for it ti be repaired. Hope this helps.. Cheers!
May 11, 2010 | Microsoft Xbox 360 Console
Unable to boot system and repair feature will not run. Also, there are no restore points (files). However I can get into the cmd prompt mode. Safe mode does not work. System is a Toshiba Satellite...
Hi there!
Well it seems that you are in a bad situation my friend. So let me help you out.
It seems that your system files are corrupt & preventing it to go to windows (may be due to improper shut-down).
What to do?
Please remove the hard disk from your laptop, put it in an external 2.5" casing. Then plug it to another laptop or pc having a good anti-virus. Now switch on the other computer. The system will correct the files on boot. If this doesn't happen, go to my computer after boot. Locate the HDD in my computer \ your HDD \ properties \ tools \
Here you'll run chkdisk & scan for errors, bad sectors etc. After that scan for any virus in that HDD. Now back up your important stuffs & send it to your DATA partition.
Now shutdown laptop & remove the HDD from the casing, then put it back in your laptop. Now boot & see your problems solved.
Please send us your feedback & vote to motivate us.Thanks.
Feb 19, 2010 | Toshiba Satellite A215-S4747 Notebook
Portable HDD stopped working and not recognized
Sounds like hardrive maybe bad try on another computer! Good luck!!!
Jun 22, 2009 | Samsung (MP0804H) 80 GB Hard Drive
Bad sectors removal and formating Seagate 80 GB
I suggest puting your hdd on another computer, full format it again, and scan it for bad sectors.Also, searching for a program that repairs bad HDD sectors, the windows default erros scan could not be very helpful if there are many bad sectors.
Sep 02, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
Bad sactor
a low level format could revive the disk - download the disk utility from the disk website (e.g if it is a quantum load the disk manager from quantum site & run on the disk - follow screen instructions)
hope this helps
Mar 16, 2008 | Computers & Internet
3gb microdrive
have you checked the cables that connect the drive to computer first remove the ribon cable from hard drive and power up computer check if hdd is spinning up you may feel a slight vibration if you feel this vibration then power off if you have the cd ribbon cable still attached place this end to hdd then power on if boots in then you need a new ribbon cable. if hdd is not spinning replace hdd hope this has helped
Aug 08, 2007 | Hitachi (MD4GB/A) 4 GB Hard Drive
Problem in pen drive/mp3 player capacity
when you hook it up to the puter, go into My computer right click on the removable drive then click on explore disc and see what oter types of files are taking up the extra memory as if there are none then the drive has bad memory cells.
Apr 28, 2006 | Sony NW-E405 MP3 Player
Western Digital Caviar  SE WD1600AAJS 160 GB SATA Hard Drive Logo
351 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
