Question about Samsung Televison & Video
I have a samsung DNIe 32" lcd tv there is a HDMI port at its back but when i connect with my hmdi port of dvd player it says not supported mode .. please help !!!!!!!
opherator
  • 44 Answers
SOURCE: PS3 will not work on new tv using HDMI cable ?
you have to re sync your playstation when you go from HDMI to regular wires.
after you connect ps3 to tv.
hold down the power buttondown on the ps3 for like 5 seconds (1 beep then another ),
after you hear a second beep the ps3 automoatically adjusts itself to whatever it's connected to.
Posted on Feb 27, 2009
SOURCE: HDMi ( no signal, not supported) doesn't work with Dmr-Ez47v
Return set!
Akai Tv is not HDCP compatible. Nothing worked akai was not very helpful. This model , a 2006. aparently will not communicate will the newer HDMI devices.
RETURN SET IF POSSIBLE. NO SOLUTION FOR THIS PROBLEM!
Posted on Jan 04, 2008
ginko
  • 19396 Answers
SOURCE: Samsung 40" lcd - Connecting to PC saying 'MODE NOT SUPPORTED'
First of all, check that the TV is set on PC input when you use PC video input at the back.
Then you may also need to go to video and display properties>>settings, from control panel (personalize on Vista).
There lower down resolution and ensure that frequency is set the same as tv.
Posted on Jan 02, 2009
SHOGUN125
  • 58 Answers
SOURCE: using my Samsung LCD TV as monitor for my Sony Vaio Laptop
yes sir..i think you must looking and buy VGA adapter 15 to HDMI complete with the HDMI cable set. you can find this adapter at the computer spare part store or electronic part store. not cheap but very usefull for you in the next day.
is very easy to connecting...plug you adapter to the output VGA VAIO.. connect the HDMI cable to adapter (like USB) and the rest to the input at your samsung lcd...good luck..
Posted on Jan 31, 2009
  • 8457 Answers
SOURCE: hdmi on vizio hdtv input says not support
Ur board is shorted it cost alot to replace the board for just the HDMI port to use.Must change the board or use the S-Video port.
Posted on Aug 17, 2009
Hello, the DVD play fine but tv mode, continually says no signal and screen is blue. Please help
You either have the DVD player plugged into the wrong input on the TV or the TV not set to that input. If using HDMI change the HDMI cord to another HDMI port on the the TV. In an Extreme case you have a bad connecting cord (either HDMI or other type.)
Oct 27, 2014 | Akai LCT3201AD 32 in. LCD Television
I have a Samsung HLP5063. Just bought a Onyko AV receiver with HMDI hook ups. Also connecting Dish 211VIP, and Samsung DVD connected to the receiver. I was able to get the DVD player to work, but no...
Have you gone through your onkyo receivers setup manual. You will most likely need to adjust the settings on your Onkyo receiver. I also have an onkyo reciever and I have to assign the inputs to the video source. Being that you got sound out of the front speakes. I am assuming when you were playing out of the dvd player your reciever was only on stereo sound. Once I get feedback I can assist you further
Thanks,
Lee
Sep 28, 2008 | Samsung Televison & Video
How can i conect a Play station and a Dvd player to my 32in. tv. on the back is only 3 oulets?
I use a small box from Monoprice. It plugs into the TV's HDMI port and then each of your devices HDMI cables plug into the box from Monoprice.
You can find the box online here for about $15.
3X1 Pigtail HDMI Switch Monoprice com
Jul 12, 2014 | Samsung LN32A330 32 in. LCD TV
Hi is there usb connection and pc input so that we can see movies in 330ld
The usb on the back of samsung tv's is for updates only - you download firmware updates from samsung support and save them to a memory stick. Put the memory stick in the usb port on the tv and start the update mode.
The pc input is for connecting things like laptops and older progressive scan dvd players.
Hope this helps.
Jan 19, 2011 | LG 32LG30 32 in. LCD HDTV
I want to connect my denon 790 to my 5:1 surround, HDMI DVD player and HD samsung 55'' LCD. what cables do i need and where to put them. thanks
You will need 1 HDMI cable to link between your DVD player and the Denon,plug the HDMI cord into the HDMI port on the back of your DVD player and the the other end into the Denon 790 HDMI port labeled DVD,then you will need another HDMI cord to go between the Denon and your LCD TV,plug one end of the HDMI cord into the Denon 790 HDMI port labeled HDMI monitor out and the other end into one of the HDMI ports on the back of your TV, it doesn't matter which one you use, just remember that you will have to change the input on the tv to that specific HDMI port when you play back a DVD and you will also have to change the Denon to DVD as your source to send the audio through the Denon to your surround sound speakers.( The Denon owners manual will help!!)
Nov 26, 2009 | Audio Players & Recorders
'MODE NOT SUPPORTED' message appears on my TV screen
i have samsung 22' lcd series 4 tv but i connected it with the dvd player via hdmi it shows mode not supported. but the same dvd works very well on another samsung lcd of same configuratition. please help me
Jul 13, 2009 | Samsung Televison & Video
Compatibility with Samsung LCD Display
It sounds like the HDMI port on the back of your Marantz is damaged. if you know for sure that the HDMI port works on another tv still you might just use component connection because the visible difference between component and HDMI is not very recognizable.
Jan 13, 2009 | Marantz DV4001 DVD Player
Samsung LN-TFT-LCD Television
The first time this happened to me, I unplugged the power cable from the back of the TV and then held the power button on the front in for 5 minutes. Its tedious but, it clears the memory out of the TV and should work.
The second time it happened my first method didn't fix the problem.  So try this:
1. Press "MENU" on the remote. If you're problem is the same as mine, then the menu is jumping around very eratically so you'll have to time your button presses accurately.
2. In the  "Picture" Category turn ON: DIGITAL NR, DNie Demo, Film Mode, and Blue Screen.
3. Exit the Menu, and Unplug the Television.
I let my Tv sit for about 2 weeks before I turned it on again, but when I did the "Not Available In Current Mode" message was gone, but replaced with smaller blue message boxes that say DigNR, DNie, and Film.  I then went back into the MENU and turn OFF: DIGITAL NR, DNie Demo, and Film Mode and the problem was gone!
Jul 31, 2008 | Samsung LN-S3251D 32 in. LCD HDTV
UPCONVERT DVD PLAYER HDMI PROBLEM
I have the same issue with this player hooked up to a Samsung 58 inch 1080p plasma.
Jun 06, 2008 | Televison & Video
Televison & Video Logo
1,124 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
