Question about Whirlpool AWM6120 Front Load Washer
Can you wash in cold water only - Whirlpool AWM6120 Front Load Washer
  • Whirlpool Master
  • 17,130 Answers
Yes , you can look into the program and find an easy economical quick wash which will has a fast wash with cold water, rinse and short drying cycle.
The normal/regular wash uses the heater as with warm water the dirt comes off well and is sterilised wheras in cold wash the average dirt might go off but not as clean as in a hot wash.
So you can use the programs as required for the clothes in question.
Posted on Aug 21, 2010
I HAVE A ZANUSSI AQUACYCLE WASHING MACHINE ZWF1221W. IT WORKs THROUGH THE WASH BUT JUST BUZZES ON THE RINSE CYCLE. I CAN TURN IT TO SPIN & EMPTY AND THAT WORKS AS WELL.
clair you may have a cold water problem, it may have filled with hot water and gone through wash cycle but as it got to rince it only fills with cold water ,the buzzing may be the cold water solenoid staying open and if there is no water passing through it will make a buzzing noise,
1.check the cold water valve # is on . it's what the blue /cold hose is connected to, also in some hoses there is a filter ,it's possible it could be blocked but unlikely.
2. check the cold water hose has not bend in half from the wall valve to the washing machine,this will stop the water flowing.
3. or it's possible you could have a faulty cold water solenoid valve.**
cold water pipe on wall> water valve# > blue cold water hose > * *cold water solenoid valve on machine.
Nov 14, 2016 | Zanussi Washing Machines
Cold water fill does it heat to temputure requied?
If your washing machine has inlets for both hot and cold water, you should connect both if possible. If you can only connect cold water, the washing machine will still work and heat to the required temperature, but it will need to heat the water in the machine, so the wash cycles will take longer and it will use more energy.
If connecting a hot and cold fill washing machine with cold water only, you will need to connect a Y-Piece for it to work:
The tail of the "Y" attaches to the cold water valve on your pipework. You then attach both hot and cold water hoses to the branches of the "Y" and connect both hot and cold water hoses to your washing machine.
Please post back if you need further assistance.
Regards,
BElectric
Nov 25, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Cold/cold wash uses hot water wash and warm rinse. I have t set to hot/cold wash to get cold water wash.
probably the water inlet hoses are hooked up cold water line to the hot water inlet and vice versa
Aug 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
GW52F Fisher and Paykel Washing Machine Col...GW52F Fisher and Paykel Washing Machine Cold water valve does not seem to be letting any water into the washing machine, so it does not spray rinse or deep...
You are better off swapping the valves over in the machine until you can buy a replacement valve. I've done this for a month or so until I replaced the valve. Works as long as you only use a cold wash and your cold water is not too cold as to make the machine want to add some hot. If it does this then simply press start to clear the fault.
Jan 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
Warm Wash: Force it to be cold?
you will need to put a "Y" in the cold water line and remove the hot water hose otherwise the hot water solenoid will open up and let in hot water,if you have cold water to both solenoids then you can get done what you want to accomplish,wash and rinse in cold water on all cycles
Dec 24, 2009 | Washing Machines
Whirlpool washing machine...only uses hot water
Make sure the hoses are connected correctly to the water valve on the machine. The connections will be marked with an "H" and a "C".
Given they are correct, most current washing machines have and auto temp feature on the water fill. It allows even cold water settings to bring in some hot water to make sure the water temp is hot enough to efficiently disolve your laundry detergant. The preset temps are usually around 75* for cold, and 105* for warm. Hot water comes in at whatever temp your household water temp is.
Sep 12, 2009 | Washing Machines
Cold water Washes
It is normal for the machine to cycle between hot and cold water when filling even if selecting a cold cycle. The reason for this is because even a cold cycle requires the water temperature to be 78F for the soap to break up efficiently.
During the cold months the water in your pipes is probably less than 78F so the machine will need to add some hot water to bring it up to this temperature. Basically, it is adding cold and then hot water to maintain a temperature in the tub of 78F for cold water cycles.
Hope this helps, please rate my solution.
Apr 07, 2009 | LG WM-1832C Front Load Washer
Cold water valve won't turn on to fill washer
either the valve has failed or the water line screen is blocked.
Aug 31, 2017 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Whirlpool AWM6120 Front Load Washer Logo
43 people viewed this question
Dan Webster
Dan Webster
Sal De
