Question about Sony KDS-R60XBR1 60" Projection HDTV
Sony KDS-R60X-BR1,replaced lamp. standby led blinks green, then blinks red 5x. lamp driver? G-board? or asu/dsu assembly?
4 Suggested Answers
taran_2005
  • 10515 Answers
SOURCE: Sony KDS-R50XBR1 has 4 blinking
4 blinks on your set indicates that one of the fans has stopped - or at least there is a problem with the fan circuits. I think this set has 4 of them. If you want to fix this yourself you would need to be handy with a screwdriver and be able to remove the back cover from the set. The fans are usually between $20 and $30 from www.partstore.com
To have this repaired by a tech is probably going to be about $200-$250 assuming you will be requesting in house service.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 02, 2011
  • 8909 Answers
SOURCE: I have a Sony KDS-R50XBR1
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen A2 slightly.
Posted on Jan 19, 2011
ladywinn
  • 5138 Answers
SOURCE: sony kds-r50xbr1 has 3 time blinking red lights on
Check Fans and Ballast Board.
Posted on Oct 18, 2011
My Sony KDS-60A3000 randomly turns off, then the red "Power LED" blinks three times repeatedly (not "Lamp LED"). We turn it back on, the process repeats again between 20-60 minutes.
3 blinks of Standby/power LED of Sony sets denotes a SMPS board [G-board] failure. . Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 16, 2016 | Sony KDS-60A3000 60" HDTV
Sony kds-r60xbr2 power wont come on and hte power led is blinking red 5 times
The 5 blinks is indicating the lamp ballast needs replacement your model uses the Sony lamp Ballast 147401211 for sony models KDF42E2000, KDS-50A2000, KDS-50A2010, KDS-55A200, KDS-60A2000, KDS-60A2010, & KDS-60XBR2 amd LDS-R60XBR2
Which is available at the bottom of the page at the following link. The ballast comes with installation instructions,
http://www.tvrepairworld.com/sony_circuit_boards/sony_dlp_circuit_boards
Aug 04, 2012 | Sony KDS-R60XBR2 Television
No pic or sound. the stand by light blinks green then the lamp light blinks red untill it turns off all toghther. the lamp is broken i just want to know if that is the only problem or if the driver may...
Flashing green standby led light at the front panel is an indication that the unit waiting for the lamp to turn on. Since the lamp led light flashes, the unit sensed it already burned out.
Faulty lamp driver has a different error code which is "flashing of the standby light 5 times".
Your unit will back to normal operation again after the lamp replacement.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jul 22, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
The tv went blank @ the red led is flashing continuosly sony kds-60a2020
If its lamp light on tv front that is blinking red then lamp is dead/ broken and need to be replaced. Lamp replacement procedure is easy and written in user mnaual of tv.
If it is standby/ power light that is blinking then please count how many times it is blinking after three seconds pause and let me know to diagnose tv problem because it is an error code that has info in its blinking.
Thanks.
Apr 03, 2011 | Sony KDS-60A2020 60" HDTV
The lamp LED blinks 4 times and repeats, I replaced the lamp but the lamp led is still blinking 4 times and repeats and I have no picture
4 times blinking light indicates problem with exhaust fan in KDS-R50XBR1 and possible causes are as follows:
-Fan 1-4 power is not supplied. (ASU board)
-Fan connector is not attached securely.
-Fan caught wires or harnesses.
Please check exhaust fan in tv, it is located at lower right of tv looking at rear of tv.
Thanks.
Feb 04, 2011 | Sony KDS-R50XBR1 50" HDTV
Hi! GREAT site! We have a Sony SXRD KDS-R60XBR1 Projection TV and it stopped working last night... We are getting FIVE red blinks! What does that mean? Fans, bulbs.... ??? Thank you in advance for any...
5 blinks if for the ballast that powers the light. You can try changing the bulb first, if that doesn't fix it then I believ it will be your ballast. If you haven't changed the bulb before It could probably use one anyway, and you could keep the old for a spare.
Here are some more from sony on this.
According to Sony:
Red LED Flashing four(4) times
o Fan not plugged in
o Foreign object hitting blades
o CN2301 on ASU board not seated or connected
o ASU shield touching S1 board
Red LED Flashing five(5) times
o Interconnect harness from Lamp driver 5-pin to ASU 9-pin board not connected
o Lamp driver failure
o Bent pin on Lamp driver 5-pin connector
o DSU to C board harness not locked
o CN6501 on G board not seated or connected
o Lamp failure
Jan 29, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
I have a Sony KDS-R50XBR1 that has no picture. When I turn on the TV, the green Power/Standby LED light blinks for about 30 seconds, then turns red and blinks five times. The Power/Standby LED repeats...
Jan 19, 2011 | Sony KDSR50XBR1 50" Projection HDTV
Sony kds-r50xbr1 turns itself off and then green light blinks 52
I too have a Sony KDS-R60XBR1 tv and the issue that you are experiencing is due to one of your fans in the rear of the tv is not working.  The tv automatically shuts off in protective mode.  Make sure the POWER/STANDBY light is blinking and not the lamp light below it.  Is the power/standby blinking 4 times in red? If, yes then its a fan that needs to be replaced.  If its the lamp light blinking then you need to replace the lamp.  The lamp is easy to replace by ordering the lamp either from Sony for $250 or find it cheaper for approx. $150 from other DLP sources and replace youself by following your manual.  I hope this helps you.
Apr 22, 2009 | Sony KDS-R50XBR1 50" HDTV
Sony KDS-R60XBR1 60" Projection HDTV Logo
145 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
