Question about Mitsubishi WS-55511 55" Rear Projection Television
I have always used this television on sateliete. I am now using it on local networlk tv. The channels do not come throgh in order and when it gets to the middle channels it keeps repetining them, it will not go above channel 30.1 unless it is manually punched in, any idea?
  • 901 Answers
Did you try re-tuning! or Auto tune. To do this go to MENU mode and refer user guide.
Posted on Aug 21, 2010
Need to scan channels
you can do the auto search channel. just press the tv menu and then find the channel search and select auto search. so that all available local channel will tuned.
Aug 30, 2012 | Insignia NS-LTDVD19-09 LCD TV
SAMSUNG UE32B6000 have problem with conecting ,it say weak signal,or no signal just blank screen, where do i start,
If you just have over-the-air signals from local broadcast stations, you need a good VHF/UHF antenna connected to the RF input jack on the TV in order to get reception. If you have access to cable TV or satellite, you need to connect the box or receiver set-top-box to the TV using a HDMI cable. You need to select on the TV using the remote, (press the MENU button) setup for tuning channels. Do a scan after setting to AIR or CABLE so the TV picks up all available channels you can get. Once this is done you can change channels and see TV. If you reply back with specifics, I can help more...
Mar 29, 2011 | Samsung UE32B6000 32" HDTV-Ready OLED TV
We lost local tv from Dish on one of the local channels. We want to use the TV (model LC-46D85U) to view the local channel. How do we get the TV to view in local over the air instead of the satellite. ...
Connect air antenna to RF(coax) input of tv. Go to the menu and look for channel setup.Select antenna and auto scan. When done scanning you should have whatever stations you are able to pickup. Connect Sat reciever to one of the other input on the tv. Then go to INPUT or SOURCE on remote and select tv for local and what ever input you sat box is connected to for dish.
Mar 07, 2011 | Sharp Televison & Video
Missing channel I used to get (using Broadcast)
You simply need a "Better" antenna system.
Feb 11, 2010 | Polaroid FLM-3232 Television
Unable to pick up local ''free'' channels following digital change over. Using RCA DTA800 converter and Phillips 2750/27 antenna. Can pick up only one local channel, but signal loss is more often the...
first of all, make sure all your connections are secure and threaded all the way in. Next, go to the main menu and press 5 (configuration) and press 1 (search for channels) if this doesn't work, press 4(signal strength meter) and see how strong your signal is. You may just need to re-position your antennae. If all else fails try system reset(number 5) and repeat search for channels. I've had similiar experiences with mine but I have a 62% signal strength and still get 20-something channels. Hope this helps.
Oct 11, 2009 | Televison & Video
Trouble receiving local channels on TV using new Magnavox converter box
Your digital converter box probably does not have an analog pass through that allows the old analog channels to go through to the tv's analog tuner.
Jun 27, 2008 | Sanyo DS27910 27" TV
Mitsubishi WS-55511 55" Rear Projection Television Logo
77 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
