Question about Sony FD Trinitron WEGA KV-24FS120 24" TV
On and off with horizontal line - Sony FD Trinitron WEGA KV-24FS120 24" TV
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
Tip
Add Horizontal Lines in Word 2007 Document Quickly
You can add horizontal lines in Word 2007 document quickly without having to use the ribbon on the top of the page. A very easy way to add horizontal lines in Word 2007 quickly is by using the keyboard shortcuts. This method will save your time. You will be able to insert lines of many different designs by using the keyboard and not having to use the mouse at all. In order to add horizontal lines in Word 2007 document quickly, you can use one of the following procedures:
1. If you want to add a simple straight line, type three dashes (---) and press Enter on the keyboard.
2. For this style of a horizontal line, type three asterisks (***) and press Enter.
3. Type three underscores ( ___ ) and press Enter to get this line:
_____________________________________________________________
4. Type three equal signs (===) and hit Enter to get this line.
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
on Jun 29, 2010 | Microsoft Word for PC
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
Horizontal lines samsung lcd tv, then more horizontal lines, then complete static out, TV restartes itself. after a 5 minutes or so, it seems fine.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 04, 2015 | Samsung Televison & Video
Horizontal lines on page
Your printer head - the ink cartridge in case of most HP deskjet printes, in most cases is defective and you need to replace it to have a clean print.
Anyway, read this tutorial, has some good tips:
HP Deskjet D2500 Printer Series Horizontal Streaks or Lines in the Printed...
For Epson printers, read this
Epson Stylus Color Ink Jet Printer
Epson Printer Horizontal lines
Same for Cannon priters
Horizontal lines when printing with Canon ip4500 Forum Thread
Aug 23, 2015 | Office Equipment & Supplies
Solid white horizontal line
Horizontal line WITH SOUND is only vertical output stage problem.horizontal line without sound is osc problem.So kindly verfy that.If h line with sound then
check vertical ic and ver supply voltage.
Aug 02, 2010 | Sansui DTV2700 27" TV
Green lines
Due to vertical section failure horizontal line apprears. You did not mention about picture. Green horizontal line means with picture or without picture. With picture means there is some leakage. Without picture only singe horizontal line means vertical section totally not working. Particularly green horizontal line means maybe leads to jungle ic failure. Please mention your simptom clearly what you get and what you will not get both video and audio. It will be helpful to answer. Based on your question this is my small information.
May 24, 2008 | Sony KV-35S42 35" TV
3 INCHES HORIZONTAL LINES ON SCREEN
i have a whie line going horizontal all the way across the sceen. how do i get rid of it?
Apr 29, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
SAMSUNG LCD TV horizontal lines
causing of horizontal lines is leaky or defective capacitors. check big value capacitors around the board at Horizontal area. check the filter capacitor as well. good luck
Mar 21, 2008 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Horizontal lines
sometimes I encounter vertical lines below..... when i tap the sides it clears for a time being  but after a few moment again appears
Dec 06, 2007 | AOC 19LVWK LCD Monitor
Sony FD Trinitron WEGA KV-24FS120 24" TV Logo
18 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
