Question about Harley Davidson Harley-Davidson FLSTC Heritage Softail Classic i
Intermitent spark - Harley Davidson Harley-Davidson FLSTC Heritage Softail Classic i
  • 1,498 Answers
My name is Mike. A couple times a day I go looking around to give some pointers to our clients (you).
Look at it your question from our point of view. You announce that people should read the description. I agree, they should.
And you supply 'Intermittent Spark'?
There's more. You're wondering why no responses?
Your problem is posted under 'Toys'.
At this point no one here with the expertise to help you has a clue that your problem exists. If you'd like to give it another shot I'll give you a few tips.
More is better:
If you are serious about getting an answer, include Make, Model and year of the product that's misbehaving.
Describe your problem clearly, concisely and with as much detail as possible.
For future reference:
Often, a problem can be the result of a seemingly unrelated event. It is always a good idea to include a recent history.
Additional information such as what steps have already been taken, has the product ever worked, is it new, etc. can have a bearing on providing the best solution for your particular circumstances.
Remember, you are a key participant in this process. We are not there, you are. We depend on you to be our eyes and ears. We can only respond to what you provide us. Without you, all our talent is worthless. How's that for an ego build?
What you get out of the experience depends on what you put in to it. So help us help you.
It would be also be advantageous in your case to repost your problem so that it is correctly categorized and starts over at the top of the queue. This way it can be directed to someone with expertise in the area you need.
Best regards
Posted on Aug 21, 2010
Intermitent spark
if its not your fuel try new plug caps !
Jan 05, 2014 | Suzuki Motorcycles
Ignition coil has intermitent spark
check spark plug wires for burn spots
check the coil at parts store
and bring coil pack for testing too
Mar 04, 2013 | 1997 Volkswagen Jetta
94 nissan altima crank no start
did you change the distributor or just the cap?
Dec 02, 2012 | 1994 Nissan Altima
Case 580CK gas...intermitent spark at points, new coil. Condenser needed?
Hi, the condenser connects to the negative coil terminal and is used to absorb the point spark so the points will not wear out prematurely. If you are getting sparks in the points, I recommend you replace the condenser.
Dec 14, 2011 | Cars & Trucks
Van starting is intermitent. Has new battery, turns over fine, not getting spark or fuel.
You can check for spark by taking off one of the spark plug wires and seeing if it will spark to the chasis ground.
To check for fuel, disconnect the fuel filter and see if fuel is being pumped or not. If you haven't replaced your fuel filter in some time, I would start there.
Sep 26, 2011 | Cars & Trucks
Shows up on computer check number 2 spark plug missfire replaced spark plugs a few oil changes ago bucks while driving??
Replace spark plug as may be firing inconsistently allowing unburnt feul to buid up and ignite intermitently
Apr 29, 2011 | Ford Focus Cars & Trucks
I have had intermitent missing when it is damp
Cap and rotor, spark plugs and wires.
Apr 14, 2010 | 1996 GMC Sierra
No spark Ignition, no gas release from the valve.
I would replace the intermitant spark ignition module if it did not produce a spark from the spark terminal to ground if held 1/8" away. Honeywell makes a universal replacement. I think it is either a S8610U or S8900U.
Jan 31, 2010 | Heating & Cooling
Long cranking when strarting, intermitent problem . I have new spark plugs and good fuel pressure.
you may have bad spark. you need to replace plug wires, cap, rotor. the crank sensors go bad on theses also.
Dec 27, 2009 | 2005 Dodge Ram 1500
1999 honda civic 1.6L very intermittent no start/stall no codes happened twice in 2 months when cold stalls very intermit when warm in gear
IT SOUNDS LIKE A FUEL PUMP OR A IGNITION PROBLEM A INDICATION OF A IGNITION PROBLEM IS THE TACHOMETER SMETIMES WILL START TO BOUNCE UP AND DOWN. CHECK FOR SPARK WHEN IT DIES IF THERE IS NO SPARK THAN IT IS A IGNITION PROBLEM. TO CHECK THE FUEL PUMP TURN THE KEY OFF THEN TURN FORWARDTO THE ACC POSIION AND LISTEN FOR THE FUEL PUMP TO HUMM IT WILL ONY HUMM FOR 5-10 SECONDS EACH TIME TOU DO THIS. THE REASON IT WORKS INTERMITANTLY IS BECAUSE THEY ARE BOTH ELECTRONIC PARTS AND WHEN THEY WARM UP THEY FRITZ OUT LET ME KNOW WHAT HAPPENS AND GOOD LUCK
Mar 31, 2009 | 1999 Honda Civic
Harley Davidson Harley-Davidson FLSTC Heritage Softail Classic i Logo
55 people viewed this question
Top Harley Davidson Toys Experts
Tre Elkins
ray gallant
L Pfaff
L Pfaff
Are you a Harley Davidson Toy Expert? Answer questions, earn points and help others
