Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
Will not drain
My GE Profile PDW 7880 dishwasher will not drain. No obstructions in the lines. Drain pump does not come on at all during wash cycle. Have tried the rinse cycle start then cancel trick and the drain pump still does not activate. Any suggestions would be most appreciated.
  • walbrecht Jun 20, 2008
    Same problem. Doesn't fill or drain. Runs through cycle except for filling and draining. Have gone through all steps recommended in manual (canceling program, etc). Nothing works
  • docpeters Jul 18, 2008
    Our PDW 7880 dishwasher won't drain either. I disassembled the major components underneath and found basically clogged everything. Sump was also deteriorating and shedding major chunks.. Replaced sump, filters, drain basket (cracked). Checked pump rotor and it moves at least. Checked all drain lines and they're clear. All check valves are installed properly. Checked plumbing (drain pipe) on wall and it's clear. Water runs in alright and it's hot. It just doesn't drain except to the level of the overflow.
    I don't know what else to do. Maybe it's the pump. How can I check it? We've had this unit for a couple of years and it's been a complete disappointment. We're about ready to go buy a Kenmore...
The selenoyd is bad take front bottom cover off you will see the problem selenoyd with 2 wires conected to it
Posted on May 03, 2008
My Kitchenaid model KURD25SHBL0 dishwasher is not draining. Drain line is clear, wash cycle runs fine, and there is no obstruction to overfill sensor. Can hear pump runnng during drain cycle but no...
Usually the wiring won't affect the direction of the pump turn. It is more likely that the fins on the drain pump empellar are damaged.
May 30, 2011 | Dishwashers
Have a GE Profile PDW8280 dishwasher. My dishes are not as clean as they used to get - dishes feel gritty and food particles keep getting stuck in the middle and lower arm spay holes. Is there something...
If you have cleaned the filter sump and you are sure the kitchen side of the drain hose is ok, then I suspect there is some problem in the separation circuit between the wash and drain pumps in the dishwasher.
See this diagram.
The turbidity sensor (item 321) could be faulty. This is supposed to check wash water quality and drain it out and bring in fresh water during wash cycle. The other possibility is the flapper valve (item 328) is not working properly. This valve is supposed to separate the drain and wash sides of the dishwasher.
First thing to do is buy a dishwasher cleaning kit (Finish brand if you can) from the supermarket and run empty dishwasher with it according to instructions on the kit. Use the hottest cycle available.
If this does not affect the quality of wash, then start checking the parts I mention above.
Hope this helps.
Mar 30, 2011 | GE 24 in. Profile PDW8280JSS Built-in...
Our GE Profile (Quiet Power 6) dishwasher is having trouble cleaning our dishes. The top shelf rarely gets cleaned and the bottom is questionable. It used to work fine. We always use Cascade powder...
The obstruction can be external to the unit. Check the drain at EACH connection working backward from the sink connection all the way to the motor pump outlet hole. Do not forget to dis-assemble the Air-Gap (if installed) and to check the inside of the garbage disposal hole also.
If all of these areas are free of obstructions then there is a good possibility that the pump impeller is either very worn / broken blade or there may be damage in the pump housing itself.
I think that if you look at the external drain lines, holes, and connections you notice a big change in the dishwashers performance.
Noting that you have hard water.... I really don't like promoting products.. but when one works and works well I will pass that information along.
There is a product out there made by FINISH called Jet-Dry and it comes in a mini basket form:
http://www.viewpoints.com/images/review/2009/134/13/1242326145-55717_full.jpg
or an additive if you have a rinse dispenser:
http://www.finishdishwashing.com/rinse-and-drying-agents.php
Lastly.... if you need to clean up the dishwasher.. on an empty no dishes cycle add 2 cups of white vinegar when you know the cycle has just started filling NOT draining and let it wash. Then do your dishes after that cycle.
Thanks for using FixYa.
Kelly
May 01, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
GE Profile Dishwasher does not drain. model #
I had a similar problem with a GE GSD5811 model. The hoses were clear, and the auxiliary pump worked fine. It turns out that it was the "piston" assembly that had basically disintegrated over time. This part diverts water to the pump during the drain cycle.
To check it, remove the mesh filter at the rear of the inside of the machine, by carefully unclipping the heater element from the back of the machine and removing the 4 hex-head screws securing the filter panel.) Unscrew the piston assembly from the tub, and pull it out. If the sealing plunger has deteriorated or is jammed, replace it. The part number for the "piston and nut assembly" for my machine (and probably numerous others) is WD24X10018. It should cost anywhere between $10 and 16, depending on where you shop.
Another possibility is a bad drain solenoid. (This is what actually triggers the piston assembly during the drain cycles.)
Dec 13, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Ge pdw 7880 does not drain, even into a bucket straight from the outlet pipe
clogged strainer, clogged or kinked drain hose ,clogged pump, faulity motor,faulity drain valve. all can be disassembled and cleaned except motor & valve they need to be tested if u have a valve it can be repaired
Nov 20, 2009 | GE 24 in. Profile PDW7800 Built-in...
GE Profile 7880 will not drain
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to some different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then you may want to consider calling a professional plumber. He may need to replace the drain valve or hose.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 29, 2009 | GE 24 in. Profile PDW7800 Built-in...
WATER WILL NOT DRAIN OUT
Sounds like either you have a blockage in the drain pump or the drain hose is blocked.
The washing machine will run the drain pump for about 2 to 3 minutes to empty water from the drum then stop automatically.
If the pump is blocked or the drain hose blocked or kinked then water will be left in the drum.
Blockages are usually caused by buttons, bra wires or metal objects from pockets eg coins.
The pump can be popped open using simple tools ie screwdriver and any obstruction removed easily. The drain hose can be detached and a metal object eg knife dropped through to test for a blockage.hope this helps
Jun 01, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
My ge Profile dishwasher will not drain
HI. check the following areas for fualts.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).....
Feb 08, 2009 | GE 24 in. Profile PDW7800 Built-in...
My dishwasher does not completely drain after a wash. what do i do?
  1. Check for hose kinks or food plugging drain hose. Start at the drain port exit
  2. Check the check valve and drain hose for debris.
  3. Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
  4. Check timer for not letting the dishwasher pause. ( not all dishwashers )
  5. Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
  6. If you have recently installed a new garbage disposal, check knock out plug at connection.
  7. Check pump impeller for damage.
  8. Check that the water inlet valve isn't seeping fresh water into the dishwasher when off
Jan 08, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher
Check the drain hose and sink drains for obstructions. Check your disposal make sure it is clear if you have one. If drain lines are clear, then you may have an obstructioin in your pump. clear obstruction and it should work properly. If no obstructions are found check voltage going to pump during pump out. If you have voltage to the pump and the water is not pumping out, you will need a new pump. Good luck and I hope this helps you.
Mike Anderson
May 08, 2008 | GE 24 in. GSD5110 Built-in Dishwasher
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
423 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
