Question about GE (GTS16BBS) Top Freezer Refrigerator
Maytag Water Dispenser Problem
We have a Mayag side by side fridge (MSD2655HEB).
This unit is just 1 1/2 years old and this morning the water dispenser stopped working. What gives?
    Problem Solver:
  • 7 Answers
If your water supply line is not pinched closed somewhere and the fridge has electricity supplied then it may be the solenoid operated water supply valve that has failed. This electric actuated valve should open when you activate the switch in the door with your glass.
Posted on May 03, 2008
Maytag MSD2650HES leaks out the bottom when we use the door water dispenser. It's 10 years old. Is it worth fixing or should we just replace it?
this fix could be a simple leaking connection or hose
you have some options
call a technician and have the problem properly diagnosed and get a quote
if the quote is around 40% of the price of a new unit then consider a new unit as parts for your unit will be at the no longer available stage lf you really do not water dispensed from the door , disconnect the system and use a jug of water in the fridge or purchase a water/ drink cooler but that is an option to consider
Aug 08, 2016 | Maytag MSD2650HES Stainless Steel Side by...
Why would my Maytag MFX2570AE 4 door french door fridge motor/fan run constantly?
if the compressor goes off and only the fan keeps working thats broken fridg but fan is not a big energy drainer on bill if the compressor works allways it might be to hot in the room or door is not seald or totaly closed give it a strog push when closing or maybe you have under floor heating so you have to insulate bottom from heat or maybe its not insulatdd well from heat of compressor
May 20, 2014 | Maytag Ice2O MFX2570AE 25.0 cu. ft. French...
556124 refrigerator. Ice/water disp. shorted out.
Your problem may be with the dispenser electronic control board. This is an issue that should be handled by an appliance service company.
Feb 22, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The water dispenser on our Maytag sideby side isn't working well. water comes out slow and funny noise from back of fridge
IS THERE A WATER FILTER ON UNIT....???...CHECK INCOMING WATER PRESSURE AND VOLUME AT SUPPLY TO UNIT.SADDLE VALVES DO GET PARTIALLY PLUGGED IF INCORRECTLY INSTALLED.
Aug 15, 2009 | Maytag MCD2257HE Side by Side Refrigerator
Maytag French Door MFD2561HEB water dispenser not working
We had the same issues with the water freezing and called a technician out. He added some extra insulation installed around the water lines inside the refrigerator and we also keep our frig at 40 degrees Fahrenheit, slightly above the manufacturers default setting. Hope this helps.
Jul 01, 2009 | Amana AFD2535DES French Door Refrigerator
Ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
Jun 16, 2009 | Maytag MSD2456G Side by Side Refrigerator
Maytag side by side fridge water dispenser not working
there are two water inlet valves on the back of refrigerator, one for icemaker the other for water in door. the valve for the water inlet is plugged or the soelinoid coil is bad. replace faulty valve, usually about 20 to 30 greenbacks at the appliance parts store
Apr 09, 2009 | Maytag MFI2568AE Side by Side French Door...
Maytag MSD2655HEB cold in bottom, no air flow
No air flow at all means Fan is not working. Also check damper between freezer and fridge.
Oct 11, 2017 | GE (GTS16BBS) Top Freezer Refrigerator
Water leak from under fridge when water dispenser is used
The water line is broken somewhere from the water dispencer all the way down to the water valve. I usually find that it is broken next to the water valve. Hint: Water valve is blue and located behind the fridge in the compressor department. Water line is 1/4inch clear tube that is probaly now a "yellowish" color. Easy to spot, easy to fix, especially if located next to water valve...
Nov 26, 2008 | GE Profile PSW26P Stainless Steel Side by...
Jenn-Air side by side you already answered once!
hi thanks, it could be the water valve at the back of the fridge a fridge with a water dispenser and ice maker has 2 solenoids on 1 valve 4 wires if you don't have a water dispenser just the ice maker then olly 1 solenoid 2 wires you can check by using an old electrical cord install on cord the connectors you see on the valve disconnect the wires that are there now and install cord you just made up disconnect fridge before you do this if the water comes out with this new cord you need a ice maer if it does not. replace the water valve thanks the appliance doc
Sep 17, 2008 | Jenn-Air JCD2389G Side by Side...
GE (GTS16BBS) Top Freezer Refrigerator Logo
248 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
