Question about HP ProCurve 2424M (J4093A) 24x10/100 Mbps Networking Switch
Hello Sir, I am using HP switches model 2424M @work. I have configured a trunk on switch A (port 23) and another trunk on switch B (port 22). However the lights on the ports are not being waken up. The cables have been tested. I have another switch C, from where i have created another trunk and linked it with either switch A or B and here everything works fine. The port light turns green. Can you please advise?
  • HP Master
  • 2,004 Answers
Ever consider asking HP, we are not HP. we are just chat boxes.
Posted on Jul 17, 2017
  • 79 Answers
SOURCE: pc's say a network cable is unplugged
First, NO, crossover cables are for connecting LIKE devices.. you need a Straight Thru cable for connecting 2 PCs to a switch.. So, if you are using Crossovers, then you are getting the correct results (cable unplugged). Replace with the proper cables, and it should see the network fine..
As this ProCurve HP 408 is 10/100 auto sensing, you should be able to automate speed and duplex within your NICs conifiguration...
Happy Holdiays!
Posted on Dec 23, 2007
  • 139 Answers
SOURCE: Network is SLOW
I can assist with the full and half duplex question...but I'll need a specific HP model number for the Procurve in order to give you correct advice about it.
If the Procurve is not configurable, or has never been configured, then it is using autonegotiation to determine speed and duplex. Each of your computers should also be set to auto for speed and duplex.
The general rule of thumb is to make sure that speed and duplex for both ports on a link are set the same. For example, if the port at one end of a cable is set manually, then the port at the other end must also be set the same speed and duplex values. If one port is set to auto, then the port at the other end of the cable must also be set to auto.
Posted on Jan 15, 2008
  • 15 Answers
SOURCE: HP Procurve 1700-8 working upto 10m UTP cable only.
It is not a distance limitation of the switch, rather the cabling in the walls and ceiling. If the cable is Cat5 it can be up to 100M, but this can be drastically reduced with things like EM interference from fluorescent lights, kinks in cable and more. The switch auto detects the maximum reliable speed and this interference would cause it to drop to 10MBps. If you don't have a cable certifier (very expensive) you may want to consider simply replacing the cabling run with Cat6 following best installation practices. You can learn more at
Posted on Feb 14, 2009
  • 25 Answers
SOURCE: Trying to Configure HP ProCurve 2524 24x10/100
This switch will not function as a DHCP server itself. You will need to have a DHCP server on the VLAN with the access points to give out IP's to the wireless users.
HP has free design and configuration services
Posted on Apr 14, 2010
  • 124 Answers
SOURCE: which cable can i use
The switch comes with a console cable which will be connected to the console/mgmt port one end and the serial port of the Laptop at the other end.
If you dont have a console cable then you can try a rollover cable.
Posted on Oct 31, 2010
How to config vlan on switch 3cdsg8 and a router draytek 2920
You can configure trunks TRUNKS > Configuratio
You can configure port to be part of that truck via TRUNKS > Members
Jun 16, 2014 | Draytek Computers & Internet
Vlan trunk on summit 24e2
Extreme uses tagged and I untagged instead of trunk/access, so it would look like this for a trunk:
conf vlan test add port gi1 tagged
(and of course you could put other VLAN's on this same port too since it's a trunk)
conf vlan user1 add port gi1 tagged
and this for handoff:
conf vlan lam test add port fa1 untagged
Feb 14, 2012 | Extreme Networks Summit 24e2 Networking...
Hello have the switch model 4924 24 port....i want to reset but dont know how to do that....can u help me to settle this prob sir...i want to make this switch like new means the function like new...
Connect some text-based terminal emulator such as Hyperterm, telnet,VT100, etc to the serial port. Configure the emilator
to19200 Baud 8 plus none.
Switch the 4924 on and login using the user "recover" (without quotes) and password "recover" (also without quotes.
The switch will go into recovery mode. It will display a count-down starting at 30 seconds. If you power thye switch off before the count is up, the default password for the main administration account "admin" will be cleared.
After a few seconds, power the switch on and set a new admin password.
After loigging in again, take the option "GettingStarted". Configure the ip settings (best to use a static address) and eventually you will get to the "Initialize" option. Enter yes, and after reboot it will be at factory except for its ip address.
Jun 01, 2011 | 3Com SuperStack 3 4924 24-Port Gigabit...
Sir I have 4200 series 26 ports Switch i want to Configure intra VLAN But I am Getting a problem to Configure that switch . After Cnfigure VLAN on Consol prompt. I am not accessing to my Server & WAN...
If you are creating only Layer 2 VLANs on the switch , you wont be able to ping the servers and Routers as they are in default VLAN1.
you can do the below steps
1. Create sub interfaces on the router LAN interface
2. Provide a new ip range to the new sub interface
3. Make the switch port connecting router as trunk, so that it will carry both the VLAN info
4. on your Labtop/PC give the IP address in the newly defined range
5. Make your switch port to be in the new VLAN
This will work , if you wont be able to configure the above settings, let me know i will give you the detailed config
Nov 01, 2010 | 3Com 4500 24-Port Ethernet Switch
Hello, I have a Linksys SRW2016 and 2048 switches with one cisco 1800 series router. I have successfully created two vlans on one switch and when i try to connect a trunk port to cisco router it...
Make sure that the frame encapsulation is set on the router to 802.1q on each of the sub-interfaces. You could also try fixing the speed and duplex on both the router and the switch in case there is a problem negotiating the speed and duplex.
Hope that helps!
Oct 04, 2010 | Linksys SRW2016 (745883562435) 16x1000...
How can configure trunk
not sure about the 3COM side, but on the Cisco side... go to the configure prompt, then the port that you need to trunk (int [interface name and number] and enter)
Once you are in the interface, use the following command:
switchport trunk encap dot1q
switchport mode trunk
Then make sure that the interface is not shut down, connect the switches together and (hopefully) the 3COM will negotiate to trunking... if not you will need to manually configure the 3com.
Hope that this helps!
Jan 07, 2010 | 3Com Switch 4500 PWR 26-Port...
Trunking problems
  1. u may need to check first internal network broad casting. if any system is giving too much packeting
  2. connectors of cables which is properly crimp
  3. quality of cable
  4. cable which is comes in ur premises through area junk box is properly connected.
  5. u may need to check load balancing of network from your authorised vendor
Apr 06, 2009 | Cisco Catalyst 2950SX-48-SI 48-Port...
Hp channel ethernet
The speed of the link will not change when you trunk 2 or more ports together. Trunking is meant to spread the bandwidth across more then 1 link; but be aware, if you watch the traffic going across the trunked ports you may see a majority of the traffic crossing 1 link. That's because the switch uses an algorithm with the source and destination MAC address to determine which port the traffic will take. Adding a 3rd port to the trunk may help spread the bandwidth across more links.
Dec 27, 2008 | HP (322118RB21) Networking Switch
3550 Cisco switch
It does not have to be port 24 to port 24 - You just need to make sure that whatever port you use is configured the same way as port 24 - Example: Log into switch #2 and set port 23 with the same attributes as port 24. Also log into you new switch and make sure port 23 (or 24) is configured the same as those on switch #2. You can the cleanly go from switch #1 - port 24 to switch #2 - port 23 AND switch #2 port 24 to switch #3 port 23 - If you also configure switch #3 port 24 like the others you'll be ready for any additional expansion
May 08, 2008 | Cisco Computers & Internet
HP ProCurve 2424M (J4093A) 24x10/100 Mbps Networking Switch Logo
42 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
