Question about Philips 42FD9954 42 in. Plasma HDTV
I have a Phillips 42in plasma 42PF7321D/37 when you turn tv on green light lights up you have sound and picture flickers a few times and then picture is fine and looks great. Noticed menus are hard to see and every once and awile you will get a flashing red light and nothing ?
  • Philips Master
  • 1,210 Answers
I would certainly say the problem is in your power supply. Chances are real good that two capacitors are bad! You will have to remove the back cover...this is tedious and requires patience. You will be concerned with the board on the left side. You will have to remove the screws on the power board to lift it and see the top of this board. You should see at least one bulged capacitor. Replace, and you can bet the other next to it is bad. And another note..there may be a small cap at about 16volts at 10Mf that needs attention. These are clues and should help with repairs! Thanks for asking.
Posted on Aug 21, 2010
  • 2 more comments
  • cryan20874 Aug 21, 2010
    Where can I buy the new capacitors?
  • matt martin
    matt martin Aug 22, 2010
    Try 'Matelectronics.com' or Jameco.com. Always be sure to get the correct Microfarad caps. And you may use the next higher voltage, if not the same voltagee. For example..25 volts at 1200 Mfs may be sustitted for 35 volts at 1200Mfs. This goes for many electrolytic radial capacitors. You cannot down size! Another note..you will want to use a high temperture capacitor. I recommend 105 degree caps and not the 85 degree cap.Thanks for asking. I will be listening for you!
  • cryan20874 Aug 24, 2010
    I am a auto technician and am experienced soldering wires, etc. would this be something i can tackle myself or should I have a specialist do it ?
  • matt martin
    matt martin Aug 24, 2010
    I believe you can! Be sure you have a pad ,and a sharpie marker,and a ziplock bag. This way you can mark the screws as you take the back cover off! Thanks for asking!
Plasma tv takes time to start then picture flickers really badly then picture returns as normaal for a few hours then goes black but still has sound i turn off tv for a number of hours & repeat the...
This tv seem to have two problems.The problems that the tv take a long time the tv to turn on,the tv power supply board have dying capacitors most likely.That the board where the power a/c cord plug into it.The picture flickers badly this problems is harder to determine because this causes by two backlight buffers boards X,Z buffers boards could be either one it is dying.This tv should get an estamate by a shop or shops and repair it by them,bcause the tv must have to be doing replacing x munbers capacitors components to the tv power supply board and alot more work to trouble shoot and to detrmine which of the buffers boards it is the causes of to the picture screen to be badly flickers and replacing it.
Jun 10, 2011 | LG 42PX8DC Plasma TV
Philips 50pf9631d/37 no picture sound. Red light flashing
hey crs246, I have the same exact problem with my philips tv same model. Have you gotten any help that you can share with me. Any help would be appreciated.
Dec 15, 2009 | Philips 50PFP5332D 50 in. Plasma...
No power to my Phillips 42 inch Plasma 42pf7321d/37, just a red blinking light
Most likely it going to be a power supply related problem. The red blinking light is a code for a TV tech to diagnose the problem on the power supply board itself or the board that regulates the power for the screen. Some manufactures call it a Backlight Inverter Board. A TV repair shop should be able to look at it for you and tell you which board is bad.
Replacement boards can be found at a good price at Shopjimmy.com
Sep 05, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
TV does not turn on, blinking red LED
Problem is a bad audio IC esp if your are reciving 11 blink code
if it is a 5 blink code replace Crystal 1h00 On Ssb new part number is 24225430 1397
Jan 12, 2009 | Philips 42PF7321 42 in. Plasma HDTV
Phillips Plasma - Model #42PF7320A/37 - 3 flashing red lights
it sounds like you could have a signal board problem they are pretty expensive but there is a web site that sells refurbed parts
Nov 17, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 37pf7320a/37 picture issues.
control boards on LCDs and PLASMA tvs are causing no picture , missing area , and other wierd symptoms , it will need to be tested to determine the true problem
Sep 20, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 30PF9946 D/37
You have sound but no picture. Green power light is on and NOT flashing. You get a screen flash or flicker on power-up or even a minute of screen before going all black. It is your inverter board. Common problem on LCDs (maybe more so on Phillips?). They are easy to replace (unplug-plug) and are available on the net.
Veritas
Feb 24, 2008 | Philips 30PF9946 30 in. HD-Ready Plasma...
Philips 42FD9954 42 in. Plasma HDTV Logo
289 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
