Question about Nintendo Wii Console
I BOUGHT NEW WII REMOTE AND IT WONT TURN ON - Nintendo Wii Console
  • 277 Answers
Is the power not working on your Nintendo Wii? This can be a frustrating occurrence, especially if your Nintendo Wii was working properly before. While there are a number of reasons why this might occur, there are two common ones -- the use of a non-licensed or genuine AC adapter, or a failed AC Adapter on your Nintendo Wii. On very rare occasions, the power supply adapter on your Nintendo Wii may requiring the entire Nintendo Wii unit may need to be replaced.
However, before get too worried about that -- let's try a few basic troubleshooting procedures to try and diagnose the issue. Nintendo's guide on this problem is fairly comprehensive and has some good content, so I have included that below. In addition, you will want to check that following common issues before moving forward.
1. Check and make sure your cables are properly plugged in. This may sound silly, but sometimes they can become loosened causing bad power connections. Best to check before you spend much time troubleshooting.
2. Does the power strip or wall outlet that your are plugging the Nintendo Wii into have power? Make sure you can plug in other devices into that same outlet to verify there is not an issue with either the power strip or the wall outlet.
3. Make sure there is adequate ventilation. Although it is covered below, it is best to make sure there is several inches of free space at the back of the Nintendo Wii to provide good air circulation to the Wii so it does not overheat.
Here is the Nintendo information on trying to troubleshoot power problems on a Nintendo Wii:
1. Make sure that the word "Wii" and the model number "RVL-002 (USA)" molded into the AC adapter. Unlicensed products are not fully compatible and may not work
correctly.
2. Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices. Some of these products are poorly manufactured and may result in damage to your system. If one of these products is attached to your system, remove it and try resetting the AC Adapter (see below).
3. Check all accessories, licensed or not, for phsyical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. Remove any damaged products and try resetting the AC Adapter (see below).
4. Make sure the Wii has good ventilation. Avoid operating the Wii while it's on carpeting or inside an enclosed space. If you have the Wii placed in a vertical position, make sure the vent on the bottom is lined up properly with the hole in the plastic stand and no foreign material is obstructing that hole.
5. Check the vents on the back and side of the Wii for dust build up. The system will shut down if it cannot vent properly to prevent overheating. If there is a build-up, remove it using a vaccum cleaner with a soft brush attachment.
6. Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on the verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
7. Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Wii (the port is labeled 12V IN) and into a working wall outlet.
8. Once plugged in, check the power light on the Power button to see if the system is receiving power.
If this fails, try resetting the AC adapter.
1. Unplug/remove all accessories from the system (including game discs, SD Cards, memory cards, Nintendo GameCube controllers, hookup cables, the AC Adapter, and Sensor Bar) from the outlet and Wii.
2. Let the system rest for about 90 seconds. While you're waiting, check to see that controller cords, AC Adapter, and Stereo AV cables/Component Video cables are not frayed or have exposed wires (this can cause the system to shut off); if so, you should replace those parts.
3. After the 90 seconds, Plug the AC Adapter into the system and wall outlet. Check to see if the power light on the Power button comes on.
4. If the system works, plug ONE accessory into your system starting with the Sensor Bar, then turn the system on to see if it still works. Repeat this process with ONE accessory at a time. If your system doesn't work once you put a particular accessory in (Sensor Bar, GameDisc, Nintendo GameCube controller, Memory Card, SD Card, etc.), there may be something defective with that accessory.
5. If the power does not come on, a repair will be necessary. Because it is not possible to determine which item (Wii console or A/C Adapter) needs repair, please call our Consumer Service Department at 1-800-255-3700 to discuss available options.
6. If the power is still continually shutting off regularly, please call our Consumer Service Department at 1-800-255-3700 to discuss available options
Posted on Aug 21, 2010
    Problem Solver:
  • 10 Answers
It wont sync or it wont do anything at all? if it wont sync press the home button and go to the controller settings press reconnect and hold down the 1 and 2 until it syncs...if it wont do anything at all u may have a problem with a failed ac adapter
Posted on Jan 01, 2011
  • 70 Answers
Hai. I am one of the user of wii....... i also got manyproblem like this..... i solved my problem using wii repair guide....click hereto help you........
Posted on Aug 30, 2010
3 Suggested Answers
SOURCE: wii remote wont work after installing wii fit
From Nintendo:
  1. Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
  2. Turnthe power of the Wii console ON. When you see the Health and Safetyscreen, open the small flap on the front of the Wii console to find ared button labeled "SYNC." Press and hold the SYNC Button down for 15seconds. This will clear all the syncs on the Wii, allowing you to geta clean start to begin the process described below.
  3. After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
    1. Withthe first Wii Remote you wish to sync, remove the battery cover on theback of the Wii Remote to find a small red button just below thebatteries.
    2. Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
    3. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
    4. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
    5. This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote added to the system.
Posted on Jan 03, 2009
  • 10 Answers
SOURCE: bought new wii remote and wont power up
The wii remote won't power up the Wii itself, or you can't get the wiimote to come on?
If it won't turn on the Wii, it may have to be synced with the system. Not really sure, though. But to sync it, take of the back of the wiimote(the battery cover) and open the little flap on the Wii. There should be red buttons in each. With both on(turn the wii on manually with the power button on the system), press both red buttons at the same time. Alternatively, you can go to the menu and sync wiimotes from there.
If the wiimote won't come on, make sure the batteries are new/charged.
Posted on Nov 26, 2009
Cant get pass the "press A button" screen
Turn off for a moment, try again, reconnect your controller.
Since its brand new, you can get it replaced if that doesn't work, dont waste your energy on it, just get another one, free replacement / warraty. Im sure.
Sep 05, 2008 | Nintendo Wii Console
My wii remote wont turn on, i even tried a couple different new batteries but still no lights or anything
Have you tried syncing the Wii remotes? To sync, turn the Wii on, open the back of the remote and then press a red button that says "SYNC". Then open the SD card slot in the front of the Wii and press another red "SYNC" button. If you do this, your Wii remotes should be able to turn on.
If your Wii remotes still don't turn on, visit support.nintendo.com
Or call 1-800-255-3700 for assistance on your Wii.
Sep 23, 2010 | Nintendo Wii Remote Controller
My wii remote keeps flashin but wont trun on
You have to sync the Wii remote to the console.
To sync the Wii remote, turn on your Wii. Then open the back of the remote and press the "SYNC" button. Then open the SD Card Slot cover on the front of your Wii and press the "SYNC" button. Your remote should be turned on if you do this.
If this problem still occurs even when the Wii remote is synced, your Wii remote might not be working properly. Return it for a new one.
Feb 21, 2010 | Nintendo Wii Remote Controller
We just bought new wee remote and it will not
Have you checked the remote sensor strip that you mount on the TV is there? Is it connected to the WII console?
Dec 28, 2009 | Nintendo Wii Console
Bought new wii remote and wont power up
Nov 26, 2009 | Nintendo Wii Console
Bought brand new batteries for my remote, but
You need to re-assign to the Wii. When you first bought it you pressed the button on the front of the Wii to configure controllers, then the controller buttons to find the Wii. When you change batteries you need to repeat this process as the 'memory' of the controller to the Wii has been wiped
Nov 12, 2009 | Nintendo Wii Console
We bought an additional wii remote and have tried to sync it but all we get is all 4 blue lights flashing??? wont work? thanks
Well, I don't have a Wii myself but I did some checking and found this. Hope it helps.
When you first get a second Wii remote, you have to press the red button inside the battery compartment and you press the red button by the Wii's SD Card slot simultaneously. Then you turn on the game and you press the Wii menu button. Go to controller settings and select reconnect remotes (can't remember if that's the exact words, but it's something like that). Next you hold 1 and 2 on the first remote, then hold 1 and 2 on the second remote. And that should do it.
Jan 19, 2009 | Nintendo Wii Remote Controller
Wii remotes wont hook up
did you try syncing them up by pushing the red button on the wii and the remote
Jan 03, 2009 | Nintendo Wii Console
Nintendo Wii Console Logo
115 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
