Question about Kenwood KDC-MP828 CD Player
Cd player dosen't play with amp
I just installed a amp with subs. Everything plays fine when the radio is on. But when I switch it to the cd the power to the amp dies
  • KCEEZ May 03, 2008
    yes all of the connections are good it plays the radio like its supposed too. But when I put a CD in the amp shuts off
    President:
  • 2,712 Answers
Hello KCEEZ,
Are you using a head unit along with the amp? If your problem was that the CD would play through the speakers, but not the amp, I'd say that the switched power antenna wire was used instead of the amp turn-on wire. Your source is selected through the head unit, so if it plays the radio, it should play the CDs.
Let me know how it goes..
Posted on May 03, 2008
    Genius:
  • 2,035 Answers
Check the connections for the CD player is it connected to amp correctly, try to reconnect all the connections back and refer user guide to install the amp and for connection...........
  • Anand Kumar
    Anand Kumar May 03, 2008
    Try to set to default factory settings , if this amp is under warranty get it replaced as the audio from the CD player is not detected by the amp........................
    Genius:
  • 3,587 Answers
Hmmm...what cd player are you using?..
  • Patrick Michaels
    Patrick Michaels May 03, 2008
    this sounds like an impedance matching issue. Kenwood's are usually quite receptive to anything you can plug into them, as long as the impedance matches well..and the power to the amp, are you saying that the amp shuts down?
  • Patrick Michaels
    Patrick Michaels May 04, 2008
    well..the reason that an amp shuts down is mismatched impedance, or an overload into the wrong input jack..please check that jack that cd is plugged into amp, again, and let us know.
I having problems getting my subs to play through the cd player!!
More than likely you have hooked up the power anttena wire as your remote turn on. So hook up the OTHER blue wire to feed your amplifier, and problem solved.
Aug 07, 2009 | Clarion DXZ385USB Car CD/ MP3 Player
Only door speakers have sound on the cd mode
the amp requires a 12 volt power constant, and a 12 volt "on" signal. you prolly have the 12 v "on" hooked up to the car stereo's antennae remote, meaning your amp gets power when the radio is on, cuase the radio is sending a signal to the amp (thinking that it is sending a signal to the antennae to raise)
you do have one of those collapsable antennas, right?
Mar 12, 2009 | Clarion VRX745VD Car DVD Player
Cd player plays, but no sound comes out of speakers.
Look at the enwood. I bet you have the remote wire hooked to the blue wire insted of the blue/white wire. The blue wire goes dad when you play a cd as it is for a power antenna. The blue/white wire is your amp turn on.
Now, if you do not have a blue/whie and only blue, then obviously that circuit in the radio is bad in whch case your only other option s are either connecting it to an accesory fuse or using a toggle switch connected to power.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 27, 2009 | Kenwood KDC-MP228 CD Player
Troubleshooting in car cd player
that is very strange but it could be that when you put the cd in the radio it maybe sending out a quick shot of amplified power I would try disconecting the subs put in a cd let it play a little then plug the subs in while the cd is playing and see if they work if this works you may to get a new radio or put in a switch to turn the subs off or some type of momentary circuit breaker I'm just trying to help I never saw anything like that before good luck........
Nov 06, 2008 | Sony Xplod CD Player w/MP3 Playback...
Jensen VM9311TS wont play cd
you are probably mising to power on the factory amp from the vehicle
Nov 04, 2008 | Jensen VM9020TS Car DVD Player
CDA 9885 No idea why it suddenly stopped working
It sounds like you have a bad ground connection. You need to take the radio out and check all the connections. I bet you have a loose one somewhere. That is what the problem was with my bronco
Sep 08, 2008 | Alpine CDA-9885 CD Player
My amp only powers the subwoofer when the radio is on but wont when the cd player is on
The person(s) who hooked up your system made a boo boo. They wired your remote turn on lead to the power antenna lead instead of the amp turn on line (both are blue and easy to mix up). Thus when your radio is on it sends a signal to the amp and the amp turns on, but when you set to CD the signal goes away and your amp shuts down. Easy fix, just re-wire the amp turn on lead and the problem will be fixed.
Jun 24, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
Amps wont stay on
try to look at the connection on the back of the cd player and make sure that the amp power wire is connected to the power wire on the wire harness on the back of the cd player and that should work but i only need one amp for a pair of 6by9s and subs try to bridge the speakers all to one amp that should cause it to sta on while in cd mode hope that helps
Dec 26, 2007 | Kenwood KDC-MP435U CD Player
Radio works cd/dvd does not.
What do you have your remote wire for your amplifier connected to?
Dec 05, 2007 | Panasonic CQ-VD7001U Car DVD Player
Sub cuts out when I switch to CD player?
It shuts off because the remote turn-on wire to the amplifier is connected to the power antenna wire behind your head unit. The power antenna wire is only activated when the tuner is selected. You need to switch the remote wire to the blue/white wire from the head unit (currently you're using the blue wire). This is the true remote output, and will activate the amp whenever the head unit is powered on.
Jul 06, 2007 | Alpine CDA-9885 CD Player
Kenwood KDC-MP828 CD Player Logo
83 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
