Question about Kenmore Washing Machines
Kenmore washer top load the load wash but when it go in spin mode it don,t move or drain the water
  • 909 Answers
What is happening is the drain pump motor is jambed. Pull plug out and then remove front cover to allow you to get to the drain pump. Remove both pipes connected to the pump housing and then use a screwdriver to seperate the pump housing from the motor body. Once housing is off, you should see what the obstruction is. Reassemble and test.
Posted on Aug 21, 2010
My kenmore do not drain the water
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 14, 2011 | Kenmore 24032\24036 Top Load Washer
The washer will not drain the water when it moves to the spin cycle.
heatman101
Apr 13, 2011 | Kenmore 24042 Top Load Washer
Washer fills up but doesnt start washing
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The first thing I'd do is see if the washer will continue it's cycle in a different mode. i.e. Try to start it in a different cycle, or try to move the timer knob to the spin cycle.
Following is a Whirlpool / Kenmore installation and maintenance PDF on how top load, direct drive washers work.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It has a troubleshooting section as well as detailed descriptions of how this type of washer works.
Sep 30, 2009 | Kenmore 13202 Top Load Washer
End of wash cycle, no draining or spinning, but can move to rinse cycle and it agitates again, no spinning after rinse either
The drain and spin functions are started when the timer advances to the spin mode.
The motor is reversible. When agitating, the motor spins one way, when going to the drain / spin mode it reverses.
Since the machine agitates, the problem points to the timer.
Sep 04, 2009 | Kenmore Washing Machines
Kenmore Washing Machine won't agitate, spin, or drain
It sounds like the motor needs to be replaced, you can drain the water by taking the drain hose from the drain and lowering down water will drain.
Jun 01, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Series 80 top loading washer that doesn't spin or agitate
Unplug machine, remove water pump and motor, behind the motor is a coupler, take broken parts to your local appliance parts store. Costs 16 bucks, replace the broken parts with new ones, reassemble machine. Never ever do a blanket/comforter in your machine again!!
Mar 31, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 washer will not spin in some washing modes
Has this Washer got a drain water filter ? if so check it first. also some washers have a 'delicates' program which leaves water in the drum to stop creasing, check you manual.
Feb 07, 2009 | Kenmore 22422 Top Load Washer
Drain old water
hi thanks for the question. to drain washer.put hose on floor in bucket. this will drain your washer thanks. for the question the appliance doc
Oct 04, 2008 | Kenmore 22062 Top Load Washer
Washing Machine
check for clogged drain water pump ,and or clutch ussually if the pump its stuck or clogged can cause this problem,
Jun 20, 2007 | Kenmore 14212 Top Load Washer
Washing Machines Logo
21 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
