Question about LG 52LG60 52 in. HDTV LCD TV
My TV a LG 52LG60 52 in. "Scarlet" HDTV LCD TV "loops" when powering up. It will light the power button, begin the startup sequence, and then power back down, and back up again, never attempting to light the screen or any other component, not making a sound, just stuck in the loop. It also will not shut off with the power switch after the loop has started. I physically have to take power off the TV (unplug it) and it will do the same thing again, only initiated with the power switch - it will not be in the loop until I touch the power switch when plugging it back in. This happened out of the blue one day - TV was on, and I was on the PC, and then I noticed the sound and picture disappeared, and it being stuck in this loop and began trying to figure out what the heck happened. It had been on for a few hours then boom, it just powered off and went in this weird loop. Any ideas?? Thanks in advance.
  • LG Master
  • 12,061 Answers
This is a classic switchmode power supply, shutting down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, So the power supply tries to do this, however when it does, the fault, is temporarily removed, (Usually because the faulty component cools down) and then, it restarts up again, senses the fault, and shuts down, and then... and so on...
We call this a "Hicupping Power supply" This set should be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free.
Please find below FYI a Training manuals, this is what I use to teach the technicians to troubleshoot and understand just how it all works and what to do,and how complex and difficult, these units are to service.
www.scribd.com/doc/.../Lg-Plasma-Tv-Full-Training-Manual
www.scribd.com/doc/.../LG-LCD-TV-42LP1D-Service-Manual
Posted on Aug 21, 2010
Wont turn all the way on
Power supply failures involve more than just faulty capacitors.
Jan 15, 2014 | Samsung LN40B750 40-Inch 1080p 240 Hz LCD...
My lg 47 60 scarlet will turn on and there is sound but no picture
Are you using a AV Receiver for the sound? If so your TV is probably on the wrong video imput.
May 25, 2012 | LG Scarlet 42LG6000 42 in. HD-Ready LCD TV
Hi, I have a 37lc46 LG LCD which takes ages to start. When I press the power button the standby light goes off for about an hour, when it comes back on again I have to continue pressing the remote power...
Replacement power supply is used?
You need to verify the DC output voltages of the power supply first and make sure this power supply has no bad caps with leaking/bulging tops. It goes into standby can also be that it detects fault some where in the set.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Dec 06, 2010 | LG 42LC2D 42 in. LCD HDTV
My lg scarlket 42lg60 will not power on
Make sure you have the TV's power cord put into a good outlet in your house. Next make sure the TV's power cord pushed all the way into the TV.
If you do not hear any clicking and or do not see any lights on the TV, the your problem is a bad power supply (switch mode power supply). This is a know issue with this 42lg tv.
Check to see if you still are in the one year warranty. If you are still in warranty, call LG for a free repair. 800-243-0000
Good luck.
Jun 27, 2010 | LG Scarlet 42LG6000 42 in. HD-Ready LCD TV
Whistling when TV is switched on. LG LCD 32''
If the sound is coming from the back of the TV, then the issue is with the power supply and may get worse causing the TV not to power on.
If the sound is coming from the speakers, then the issue may be with the main board, an audio hookup to the TV, and or a bad ground loop with the TV and the connections to it.
May 17, 2010 | LG 32LG30 32 in. LCD HDTV
When I power on the TV, there is no display. However the audio is fine.
It sounds to me like either the inverter(The board that lights up the screen) is bad,or the screen itself has a bad bulb in it.Thank You very much!
Tyler
Mar 05, 2010 | LG Scarlet 42LG6000 42 in. HD-Ready LCD TV
37'' LG lcd tv, no power
I just want to clear things here.
The stand by light will remain on whenever the tv set is turned on by a button on the side of the tv.
Then use your remote to turn on the tv, but wait as it can take 10secs before you get a picture.
Nov 04, 2009 | LG 37LC7D 37 in. LCD HDTV
Connect headphones to lg scarlet 32inches tv
ya..you can connect your headphone to the
LCD tv.It will be available on the back of the
tv.The port will be available.
check this out..
thank u..
rate me..
Feb 24, 2009 | LG Scarlet 42LG6000 42 in. HD-Ready LCD TV
LG 52LG60 52 in. HDTV LCD TV Logo
471 people viewed this question
Computer Repairing
Computer Repairing
