Question about Olympia Startype 3 Typewriter
How to correct mitake after taking documents and feeding it second time? which key I have to use for that purpose
  • Olympia Master
  • 3,594 Answers
Using the space backspace und paper up and down keys get back to the error press correction key, then the letter to be corrected.
DickyO
Posted on Aug 21, 2010
Will not feed 11x17
You probably need to set the user settings to "long doc" mode.
1) When the machine is in the standby state,
press the NEW FILE key and Count Only key
simultaneously. During the user mode, the
LEDs of the NEW FILE key and Count Only
key illuminate and the address (U01-U10)
and data (the last digit) appear on the
counter display.
2) When changing the address, use the NEW
FILE key. Each time NEW FILE is pressed,
the address changes, cycling from U01 to
U10.
3) When changing the data, use the Count Only
key. Each time Count Only is pressed, the
data changes.
4) Pressing the Stop key exits the user mode.
Long document mode =U10; 0=normal and 1=long document mode.
Happy Scanning!
Scan-R-Store
Scan Store provides service and maintenance contracts on all Canon Fujitsu...
Apr 02, 2014 | Canon DR-9080C Path-Through Scanner
How to reset error 5100
Jams in the Document Tray
When a document jams or misfeeds in the Document Tray, <OPEN COVER> and <SEE FIG. 1> <!!CHECK!! 5100> are displayed on the LCD.
Note
You do not need to unplug the fax when clearing document jams.
* When <OPEN COVER> and <SEE FIG. 1> are displayed alternatively
1. Press [Stop].
Important
Do not pull out the jammed paper manually at this point.
2. Hold down [Start/Copy] for a few seconds.
* The document will be fed out automatically.
* If the document is not fed out, gently pull the document out of the fax.
* When <!!CHECK!! 5100> is displayed
1. Check if any paper is jammed.
If jammed, make sure to take out all the jammed paper.
2. After taking out jammed paper, turn the fax off, then turn it back on with [ON/OFF].
Jams in the Multi-Purpose Tray
If paper jams in the Multi-Purpose Tray, <CLEAR PAPER JAM> is displayed on the LCD.
1. Gently pull any jammed paper out of the fax as shown, then press [Stop].
* Pull it gently in either direction.
* If you cannot pull the paper out, continue with the steps below.
2. Open the Printer Cover.
3. Gently remove the jammed paper inside the fax.
4. Press [Stop].
The fax returns to standby mode.
Sep 24, 2013 | Canon FAX-JX200
I am not able to feed several documents into my Cannon MF6500 printer to be scanned. I can only scan one document at a time. How do I correct this so I can feed documents in to be scanned
Do you have problem with multiple copies or just wit puling scans?
Try to say that the original is feed from adf, clean rollers if you have trouble with copie too.
May 18, 2010 | Office Equipment & Supplies
The feeder takes several sheets at a time. How do
When ever you face such type of issue, the Scanner will display U-2 error with the Red led blinking and the TWAIN display will be "The multi feed is detected.(Code DS32006)".
To resolve the issue, please follow the steps provided below:
#Check if the documents satisfy paper specification? Please refer to the Operator’s Guide for paper specification, paying
attention to the following points:
• Is there any print within 10mm x 10 mm square in the center of documents on the top?
• Is multi feed error detected by paper length when scanning documents with different length?
• Is there perforation in the center of documents?
#Check ADF and clean pick roller, Pad ASY and around DF sensor with care.
#Replace Pick roller and Pad ASY and see if the error is removed. Check the consumable counter from the TWAIN driver screen. When the counter exceeds the permitted values, replace Pick roller or Pad ASY. If the error still occurs, confirm that the cable is correctly connected then replace the sensor.
Hope the above information will be helpful.
Please revert if you have further queries.
Thanks & regards,
TechSatya
May 06, 2010 | Fujitsu fi-5120C
Printer paper feed
Hi there
This hapens a lot with different printers, best way is to gave your papers a good shake and keep in a worm place then it may work for you.
All The Best Pineworks
Mar 05, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
ERROR E 725 AND MISFEED IN ADF
Most times on these machines the most common problem is worn document rollers.
Cleaning them will improve document feeding, most times they have to be replaced espeicailly the lower ****** roll or ****** pad. These pads and ****** rolls will cause multi-sheet feeds when they are worn.
Sometimes paper hole punches fall into the machine and cause sensor actuator arms not to go up and down, or just bearly resting on the face of the sensor.
At times linkages will bind, paper dust on the sensors causes jams, sensor actuators bind and will pop off its mounting position Clutches will not work correctly, they slip and too fast for the eye to see.
If there are further inside dissassebley of the ADF, this might take a service technition to look further into the matter for repair.
Oct 16, 2009 | Toshiba e-Studio 202L Copier
Radio code not working
leave key in "ON" position for 2 to 3 hours -radio will reset to original "CODE" message
Dec 20, 2008 | 2001 Mitsubishi Galant
Coping from Canon MP610
Unfortunately this model does not have document feeder on top. So you can only do it one sheet at a time. I think the 31ppm indicates that you can print 31 copies of one document in one minute. The models above this tend to have document feeders for this purpose but not the mp610.
Good luck.
Please rate my advice, good or bad.
Feb 01, 2008 | Canon MP610 Photo All-In-One Printer
Alpha seting of dfx 8000 printer
The purpose of this adjustment is to set the PG offset value in accordance with the nose dimension
of the printhead. (For details, refer to Chapter 2.)
The offset for the nose dimension is represented by the adjustment value “ALPHA.” The “ALPHA” value
is stored in the memory on the main board, so the PG adjustment mechanism can read the value as
needed. Be sure to perform the adjustment when required. If this adjustment is not performed correctly,
the platen gap will be incorrect, the paper could be caught by a head pin, or, in the worst case, a head
pin could break.
NOTE: The printhead adjustment value is written on the front of the head unit (refer to Figure 4-2). After
the printhead is attached, the value cannot be seen. Be sure to write down the value before
attaching the printhead.
Step 1: Connect the AC cable. Mount the ribbon cassette, and load paper into the front tractor.
Step 2: Turn the printer power on while pressing the LINE FEED, MICRO FEED (V), and PAPER SELECT
switches (Be sure that the top cover is closed. Do not open it until you turn the printer power
off.), then wait until the buzzer rings five times.
REV.-A
Step 3:
Step 4:
Step 5:
Step 6:
Load the paper by pressing either the LINE FEED or PAPER SELECT switch, then wait until
the PAPER OUT lamp goes off (approximately 15 seconds).
Press the ON LINE switch.
Press the MICRO FEED (A) switch the number of times indicated by the value written on the
front of the printhead.
l The buzzer rings each time the MICRO FEED switch is pressed.
l Press the MICRO FEED (A) switch to increment the value.
l Press the MICRO FEED (V) switch to decrement the value.
l The value range is O to 10.
To confirm the value stored, press the FORM FEED switch so that the value is printed.
l If the value is incorrect, return to Step 5.
. When the value is correct, go to Step 7.
Step 7: Press the ON LINE switch and confirm that the buzzer rings five times. The printer prints the
final value stored. If the value is correct, turn the printer power off.
Dec 06, 2007 | Epson DFX 8000 Matrix Printer
SADF Mode problem
Try turning off the machine, pushing and holding the utility key and turning it on, don't take your finger off the key. You should see a blank screen with one touch button on it saying Trouble Reset. Press it, if the machine doesn't reset itself turn it off and one again.
Jun 14, 2007 | Konica Minolta DiALTA CF910 Copier
Olympia Startype 3 Typewriter Logo
42 people viewed this question
Top Olympia Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Are you an Olympia Office Equipment and Supply Expert? Answer questions, earn points and help others
