Question about Samsung Refrigerators
I just bought a brand new Sansung ref side by side tonite and they did not give me a manuel , how do I get my ice maker to work
  • 909 Answers
Once the unit arrives and is in place, you need to purchase a reducing tap and pipe with couplings to allow connection to the fridge at the back so you can get water into the system. It will then supply both the water dispenser and the icemaker.This should be done by the agent as the warrenty depends on it. If later when the water is in the ice tray and it wont activate, underneath the ice module should be a test button that you push and release. It should do an automatic cycle to start the action.
Posted on Aug 21, 2010
We have a Samsung side by side refrigerator that we bought 1/22/2013. The ice maker is working but has begun making a very loud chattering noise. It is producing ice, the dispenser is fine, the only...
Turn ice maker off for 12 hr's. Next time you buy a ref. pay the extra $150 for a 5 yr. warrenty. Ice makers break all the time. All of them!
May 21, 2014 | Samsung Refrigerators
I have a ge refridgerator side by side model gsh25kgmd bb. I bought it in 2002. The issue is, the ice maker. It has stoped working. I notices there was a lot ice build up in the back below the ice...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Aug 08, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My ref. Ice maker don't work
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Feb 14, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
On my Frigidaire Ref/Frzr Model number FRS6LR5ew5-Ice maker is not working???
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 07, 2010 | Frigidaire FRS23H7CS Side by Side...
Nasty tasting ice cubes
Change the supply line to the plastic tube line or copper. Do not use a braided plastic or metal braided line these will make the water taste bad. Changed mine to the plastic line and cured mine, no filters needed.
Jul 13, 2010 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Whirlpool ref GS5SHAXNL00 NEW ICE MAKER NOT
Check your water pump to see if it's working.
Also you might miss some connection when you replaced the new one so double check all your connection
Nov 30, 2017 | KitchenAid KSRG25FK Side by Side...
Frigidaire refrigerator, ice maker
If the ice maker is doing the normal cycle and when calls for water doesn't get any,probably the fill tube to the ice maker is clogh with ice because the dual valve (solenoid) is leaking and this water freezes up clogging the fill tube , or the solenoid doesn't work ,in both cases it has to be replaced(it's located in the back of the refrigerator attached to the water supply line).
Aug 28, 2009 | Frigidaire FRS3R5EMB Side by Side...
ICE MAKER NOT WORKING
heatman101
Jan 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker doe's not fill up with water to make ice
just bought a brand new side by side with ice and water dispenser i have water coming out of the door dispenser but the ice maker tray is not filling up with water can someone help me
Jan 01, 2009 | LG LRSC26940ST 36" Side-by-Side...
Refrigerators Logo
56 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
