HP Pavillion Hi there, My HP Pavillion is going back to HP for fixing and they are going reset the hard drives back to their original settings and I need to recover the data from them. Can you do this and what is the approximate cost? Thanks, Lynne
  • Jeffrey Pemberton
    Jeffrey Pemberton May 11, 2010
    What is the problem with your pc? I understand they're going to restore the hard drives but I need to know what the problem is so I can advise. Thanks lynne.
  • 144 Answers
Yes I can do that.But you need ship to my place Thailand
Posted on May 05, 2008
Factory reset for HP 2000 running Windows 8
a clean wipe of the partition and reset can be accomplished in the Bios functions, simply go into set up at boot and move through the menus until you achieve your goal. HP is well known for installing ghost partitions on their hard drives .
Jun 06, 2014 | HEWLETT-PACKARD Hewlett Packard Techno...
How do i hook my hard drive back after it was taken out
Hi There,
Laptop hard drives do not have wires. They are a simple plug in and go device. You should be able to open the hard drive caddy on the bottom of your laptop and slip the hard drive back in without any issues
Jun 07, 2012 | HP PAVILLION DV6840TX (FE086PA) PC...
Reset factory settings on hp 2000
In order to reset the PC to factory settings you must do a system recovery, this is located in the system "Tools" (a sub menu of accessories) menu in "Programs" from the "Start" menu.
Jan 25, 2012 | HEWLETT-PACKARD Hewlett Packard Techno...
I have a hp Pavillion dv800 with AMD microprocessor. i installed windows 7 and it was working OK but then some of the drivers were not so I formated the hard drive and tried a restore with the original...
Pull the hard drive, remove the battery AND the BIOS battery. Let it sit for 300 seconds. Then replace the BIOS battery and the main battery, but NOT the hard drive, then go into BIOS SETUP, and choose the default settings. Then boot to a bootable CD (such as Hiren's BootCD 15.2, or Parted Magic). Then set the boot options to NOT BOOT to the hard drive. Then reinstall the hard drive, and boot to your Windows installation CD, and reinstall the OS of your choice.
May 10, 2017 | HP Pavilion dv8000t Notebook
Hp pavillion dv6627 -- wouldn't start - got it to start - did a diagnostic -- said "replace hard drive" -- tech support at HP said hard drive will go down in 2 days ... is that true?
You need to make status "Active" for atleast one partition and then you need to install on an OS what you like, it will be full working.
The messege did not show to down under or within 2 days or longer.
Good Luck
Sep 03, 2010 | HP Computers & Internet
Problem replacing sata drive with eide drive in HP A1330n
if hard drive show in the bios setting and not loading the window then your hard drive not work properly.change your hard drive.
Jan 16, 2010 | HP Pavilion a1330n (EL466AA) PC Desktop
My husband just gave me his HP pavillion m7350n and it has alot of programs i dont want. What is the easies way of go back to the stuff that came with the HP. I guess i want to know how to do a recovery is...
Most systems come with a recovery drive on their hard disk. Smone times it takes the last drive letter before the CD-ROM drive. If that is the case with you, locate the drive by
1. Double click my computer icon on your desktop
2 Locate the drive that has the recovery data
3 Run the recovery
Make sure you read the instratuctions on the sreen and follow the steps you are asked to follow on the recovery wizard.
This will retore your PC to the factory setting.
But note that most factory seting come with evalution copies of original software like Microsoft Office, etc you may need to get the licenses for these software after the retore to make them genuie.
Dec 30, 2009 | HP Pavillion s7420n PC Desktop
Bootmgr missing
To fix this, you'll need a Vista DVD and a working DVD drive. It doesn't have to be the original DVD that came with your computer, you can use any Vista disc.
Put the disc into your hard drive and boot from it. The process differs depending on your BIOS, but the most likely way is to go into your BIOS settings (Press DEL when the computer boots), search for "Advanced Settings" and for anything that sounds like "Boot Order", then change your first device to your CD/DVD Drive. Save the settings and reboot your computer.
Once you've booted from the disc, press "Repair" - you'll be greeted with a screen with several options. One of these should be "Startup Repair", press it and let it do its job. When it finishes, reboot your computer: your problem should be fixed now.
If this doesn't work, follow the same steps to boot from the Vista DVD, but this time choose "Command Prompt" when the option appears. In the command prompt type:
bootrec /rebuildbcd
Answer "yes" if it asks you about your installation path.
Aug 10, 2009 | HP Pavilion dv2000t Notebook
HP Pavillion dv2500 laptop won't turn on
Kinda strange. Not turning on indicates a hardware problem, you made software changes. If the software changes caused a problem, it would start, just not boot to windows. I would first tryy to reset the laptop. Unplug it and remove the battery, hold down the power button for 60 seconds, then try again. If still no go, start removing hardware one at a time, hard drive, rem, wireless card, dvd rom. You may have a bad hard drive. Your pc should boot to bios if there is no hard drive installed. If that happens, run a diagnostic on your hard drive from your bios. Let me know if you need anything else.
Jul 29, 2009 | HP Pavilion dv2610us Notebook
HP Pavillion Laptop ze4420us CD Burner Not Working
You might find this link helpful then.
I go through this site for a number of fixes and ideas.
Oct 18, 2008 | HP Pavilion ze4420us Notebook
Computers & Internet Logo
David Payne
David Payne
