JVC TH-C30 universal remote codes ? trying to use my bell satalite remote to run the volume controls on the jvc TH-C30 ANY IDEA HOW TO PROGRAM THIS ? I AM NOT SAVEY !
  • 556 Answers
SOURCE: Universal code for JVC-AV 27230
www.remotes.com
please try this web site you will get the solution
good luck.
Posted on Oct 17, 2007
SOURCE: RCA GuidePlus Gemstar Universal Remote Control 242524
i need to program my remote for my tv with this gemstar universal remote control "crk76te1 . how do i do this ? its for a zenth televison . thanks
Posted on Oct 11, 2008
  • 5 Answers
SOURCE: RadioShack Universal Remote (Cat. 15-2147) - to use with JVC TV
programming a device: make sure batteries are installed correctly. Turn device on(for ex., your TV). Press TV button next to Power button on your 15-2147...Press and hold the little P button until the red LED lite blinks twice...enter the first four-digit code for your device(in your case,JVC TV...first set of #s is '0463' ) note: the LED will blink once as each number is entered. If the number is correct the LED will blink 2x. Note if the LED doesn't blink twice after entering the 4 digit code, begin again with the next set of numbers. For JVC the codes are 0463 and 0053. Once your remote blinks twice after entering in your TV code, press the power button. This should turn off your TV. Just use like any other remote. Hope this helps you.
Posted on Oct 12, 2008
  • 10 Answers
SOURCE: remote control code for jvc tv
HERE IS SOME CODES FOR THAT TV 557 558 559 560
Posted on Jan 11, 2009
freetek
  • 5568 Answers
SOURCE: My remote wont change channels
I need to use the cable remote to change the channel and the TV remote to change volume.
That is because your TV is looking at the output of the cable box (probably on channel 3 or 4) so the TV has to be statically tuned to see the cable box's output.
On the second question; I, and perhaps others, can't answer this without spending a lot of time to download manuals for both systems while you have them (presumably, since they are new) on hand. You didn't include the TV's model number anyhow so even that wouldn't be adequate.
The home theatre may have a receiver but what does it receive? Unless it also has channel capabilities that correspond to cable channels, it can't. The typical routing should be from the cable box to the TV S-video input and the sound can be routed separately from the cable box to either/or both, the home theatre's and also the TV's audio inputs.
When I am installing new stuff, I make a sketch of the routing I want (or have) to use. To me, this is less confusing than the supplied instructions.
Posted on Feb 01, 2009
How do you program Universal GE remote to a JVC th C5 system
Use code search to find something that handles some or all functions of your JVC system. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Dec 20, 2016 | Televison & Video
I have an old JVC TH-p7 home theater system. My remote control stopped working. I have an Philips universal remote control, but I can't find the code needed the TH-P7
If you cannot get the Philips to work you could always look to purchase another JVC remote that is compatible with the TH-P7. I believe that the remote model# is JVC RM-STHP7U. You can find the replacement remote by using the remote control search engine below. Here are the search results for the JVC RM-STHP7U:
http://ezremotefinder.com/results.php?mfg=JVC&mdl=RM-STHP7U&keywords=&page=1
Jan 31, 2016 | Philips Audio Players & Recorders
I have a universal control and i don't have the codes for it to work the tv
    Remote Control Code List
    www.jumboremotecontrol.com/remote_control_code_list.html
    Jumbo Universal Remote Control ยท 8 Device ... Programing codes for the remote. If you do not see your device listed, you can use the code search feature to program the device into the remote. TV Codes ... JVC, 013,054,055,060,065,067,089.โ€ŽGuide to Programming the ... - โ€ŽDownload the Manual - โ€Ž8 Device Learning Jumbo ...
    What is the universal control remote code for a JVC television?
    www.ask.com > Technology > Television & Video
    JVC universal codes can also be found on the instruction sheet or manual guide that comes with the remote control or television set. If these universal codes do ...
    JVC Remote Codes
    remote-codes.findthedata.com/l/163/JVC-Remote-Codes
    A list of TV, HDTV, DVD, Receiver, Audio, Amplifier and and VCR remote codes forJVC. images for codes for universal remote control jvc
Jan 03, 2016 | JVC AV-32D305 32" TV
JVC TH-C30 dvd movies skip
Check your formatting on the DVD recorder, you need to finalize the disk to be playable on "any" player. That should solve the issue. Your JVC is looking for specific code as it reads the disc, when it's missing or not understood by your JVC it will either stop play or skip over it's interperated missing info. Hope this helps
Jun 23, 2009 | JVC TH-C30 System
Universal remote
You can try a code seach which many universal remotes will do, this may be called auto search, if you have the manual for the RCA see if it is listed, instead of entering a 3 digit code, you cycle through all codes until the correct one responds to the unit you are trying to program.
Feb 12, 2009 | JVC TH-G30 Theater System
Universal Remote
I do not know if it works but you can check the website, I am very happy with my Logitech Harmony remote. Probably overkill but you will love what you can do with these.
Jun 26, 2008 | JVC TH-C30 System
Universal Remote iwave
I Have The Codes,But No instructions!! Big IWave . 0054-Philips Hitachi-0145 JVC-0053 LG- 0178 OR 1265
Jun 09, 2008 | Hitachi 50HDA39 50 in. Plasma HDTV
Jun 08, 2008 | RCA Universal Remote Control
JVC TH-A30 remote code for universal remote RCA universal remote
The entire manual is available at www.safemanual.com. I jsut printed it out.
Dec 16, 2007 | JVC TH-A30 System
Televison & Video Logo
145 people viewed this question
Top Televison & Video Experts
