Question about Garden
My cascade pump 1500 is clogged and do not have instructions to take it apart
  • 1,498 Answers
Hi Cheryl,
Before you take it apart try this.
With the pump off, attach the outlet to a garden hose and run water backwards through it. If it's being stubborn flip it on for a sec. every once in a while.
The process has worked well for me.
Best regards,
Posted on Aug 21, 2010
CE022BM Cascade Breadmaker CE-022BM
Are there any product codes on your belts? The will look similar to this if you have them: 60S3M503 or 80S3M485 etc. etc. email those codes to me at daryl441@msn.com
Dec 30, 2013 | Cook's Essentials CE022BM Cascade...
2005 dodgeram reduce engine power
Clogged Cat
Reduced Fuel Pressure
Clogged Fuel Filter
Clogged Air Filter
Bad Fuel Pump
This should give you a path to start troubleshooting. I would put my money on a Defective Fuel Pump..
Apr 16, 2013 | 2005 Dodge Ram 1500
Dear sir i have a hozelock cascade 1500 pond pump,which is 2years old.it has been fine until today were it just works for about 30 secs then nothing for about 3mins,then it works for 30 secs again then...
It sounds like the pump is overheating, this can be caused by a few things. First check the filter for clogging and also while you have the filter casing open take a look at your impeller. Gently turn the impeller to check if it is jammed, it's ok if there is a little resistance from the magnets but it should turn readily. If the impeller feels like it is grinding or sized you can try to gently remove it from the housing. The impeller is attached to a barrel shaft made of magnetic material that will wear down over time and is replaceable. If everything on the intake end seems normal, we check the output line for clogging or restricted flow. To detach the output line from the main unit simply unscrew the pressure bolt at the base of the output pipe. Open the valve on the output pipe and probe the pipe for clogs using a probe (a bit of wire coat hanger will serve just fine). Gently probe for a soft mass that will feel very different than the plastic. If you do feel a clog simply bend a small hook in the top of your probe and carefully snag and extract the clog.
If after these steps you fail to locate the issue most likely the issue is with the motor and the unit will need replacing.
Mar 17, 2011 | Garden
Why doesn't my detergent in dishwasher dissolve?
I've been having the same problem. It's a Sears Elite, made by Whirlpool. The problem gradually got worse until the dishwasher failed to wash at all. It runs through it's cycles and fills and drains, but the water isn't spraying. I am still in the process of fixing it, but it seems that the pump that sprays the water has failed. The motor runs, but the pump isn't pumping. I will be taking it apart to see if it's clogged or if the impeller is broken. Good luck with yours.
Apr 16, 2010 | Cascade 1400 Gph Pump
We use the Cascade tablets but they don't dissolve
Either:
1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Apr 13, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
How to set up a Hozelock cascade 1500 pond pump
if there are no markings, check each opening for a vacuum with a small piece of paper, the one sucking in is the inlet, the other is the outlet
Jul 25, 2009 | Cascade 1400 Gph Pump
My pond pumps faulty
sounds like the pump has shorted out internally and needs to be replaced, try on different circute first to see if breaker is not faulty
May 24, 2009 | Garden
Detergent sticks in main wash compartment. We use cascade complete with bleach (hydroclean action). When this problem started, I switched to cascade complete (liquid) and still same thing happens. The...
Jsmarquez, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Jsmarquez), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 25, 2017 | Whirlpool Gold 24 in. Built-In Dishwasher...
Does this model fully drain?
Switch immediately to a Brand Name Dishwasher powder (like Electrosol or Cascade.)  Avoid gels, tablets and never use a dish soap that is meant for washing dishes in a sink.  This will solve the "bubbles" problem.
Yes, dishwashers do maintain some level of water inside to keep the pump seals/gaskets from drying out or seizing. As long as the water down there is clear and has no odor, you and your apartment's dishwasher is fine.
OK?  Post back with any more questions.
Apr 14, 2009 | Dishwashers
How to repair my Cascade 1500 fish pump it just stoped working
First check age as they have a three year warranty. If not, the impeller needs to be checked for blockage or breakage.
Nov 22, 2008 | Garden
Garden Logo
193 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
