Question about Raypak Free Hydraulic Lift Gate Delivery - No L...
I have a digital raypak nothing turns on its like there is no power going to the heater any advice. thank you
    Top Expert:
  • Raypak Master
  • 5,743 Answers
If power going in check transformer if no replace if ok bad display board
Posted on May 25, 2016
2 Suggested Answers
  • 22 Answers
SOURCE: raypak 2100 digital heater give fault code eol
ILO or ROL. There is no EOL.
ROL is a switch inside the lower left corner of the heater. Press the red button. ILO is a lockout. Power down and power up.
Posted on Dec 21, 2008
I have a code that says Water Sw Open...Just turned on the gas line from the winter going to start the heater and see this message.
ahh its a pool heater .
cant find a user manual for it
.gas
if not sure dont light it up ..till you know its safe
May 27, 2016 | RAYPAK R266A 266K BTU ASME DIGITAL...
Why won't my poool heater start? I have a 3-year old Raypak 130 pool heater that won't ignite. I don't even hear it trying to ignite so I am thinking it is a switch or circuit problem. Thoughts?
check to see if pressure switch is closed if not check copper line to it if ok check ignitor if ohms out ok disconnected should be 78 ohms at 70 degrees if shorted or open bad and relace also check for fuses
May 15, 2014 | Raypak 130,000 BTU Propane Gas Pool...
Knocking sound in heater like something loose. Stops when turn off heater
This issue sounds tricky. I recommend you call the Raypak technical support line at 800-947-2975 or 800-627-2975 and they should be able to help you figure this issue out. I hope this helps.
Please vote on this answer. Thank you.
Aug 16, 2011 | RAYPAK R266A 266K BTU ASME DIGITAL...
I have a Raypak RP 2100 R405 pool heater. When I
Yes its faulty PC board.As no Power Coming from the board.Click this link directly to get PC board. http://www.a1poolparts.com/-strse-Heaters--dsh--Parts-cln-Raypak/searchpath/1015892/start/61/total/103/Categories.bok ------------------ To confirm the fault in PC board. Check for exact 24 volts on PC board. One yellow and One Blue wire. --------- For checking transformer check 120/240 volt to transformer(time clock circuit breaker wire connections). Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jul 10, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Just replaced the heating element on my Raypak 1102-2 Turned the unit on & the on light didn't come on. Did i replace the element for nothing? What could the problem be THANK YOU
Check your high limit. This is the reset switch behind the rubber button on the face of the heater. It probally tripped during the process and didn't get reset.
May 12, 2010 | Raypak Spapak Electric Spa Heater -...
Raypak pool heater piliot light on heat will not turn on
Make sure that gas control knob is set to ON (counterclockwise). Make sure that ON/OFF switch is ON. Check that temperature setting is high enough to call for heat. Make sure pool pump is running and water is flowing to unit.
If not above there is a diagnostic procedure on page 33 of manual at:
http://www.raypak.com/uploads/6000.52AG.pdf
May 24, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
I have a Raypak 2100 digital, I have it professionally open and closed. The company opened the pool, but the heater does not come on. While looking over the heater(which I know nothing about)I have noticed...
that water leak would not keep the heater from coming on is there power to the heater check and see if it is on there is a switch on and off switch on the side of the heater, check and see if it is on
May 19, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak Free Hydraulic Lift Gate Delivery - No L... Logo
111 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
