Akai 27" LCD tv monitor - suddenly will not get any picture, sound is continuous loud popping. Power on lite (red when off, green when on) is flashing yellow.
    Master:
  • 377 Answers
Is the poping sound coming from the outlet when you plug the unit, or in the unit where the poping sounds comes,..
i recommend first to check you electrical outlet the electrical wire, it is possible that you are experiencing low supply of electric on the the unit and maybe resulting into a power surge.
check first all electrical components.
Posted on May 04, 2008
    President:
  • 2,712 Answers
From the symptoms you describe, it seems the high voltage flyback autotransformer has failed along with the horizontal amplifier (they are slaved to each other). This could have happened during the moving process. The sound comes from the flyback unit..
Well, the only way to solve this is to get a technician take a look at the set, I'm afraid. Repairs could cost upto $100 or more (including labour), depending upon the number of components that need to be replaced,
It may be worth getting fixed up. If you decide to do so, call around, as shops have different rates and different expertise. Many shops are hurting for work because so many of the smaller sets are never repaired anymore; they are just thrown out and replaced since the cost of a new set is sometimes as low as the repair expense.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 03, 2008
  • Swilin Sampson
    Swilin Sampson May 07, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    If your issue is not resolved, please do not assign
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved (remember that at times a bit of
    to and fro dialogue may be necessary to resolve an issue).
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated.
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
    IrishDruid
  • 13,433 Answers
It seems like a component level issue..
reseting it probably doesnt solve the problem
There is a problem either in the mainboard or in the powerboard of the tv. I would have a professional do the job unless you have experience in this field?
    Brigadier General:
  • 3,614 Answers
Have you done any check up on the unit..? try to look at the power supply area & look for some busted fuse and broke resistor.
Thank you
  • micromaster
    micromaster May 03, 2008
    on the power supply & the non power supply area.
    Post back, and let us know..
  • micromaster
    BTW.. check the power outlet & using a surge protector is better..
    Genius:
  • 1,142 Answers
May i know the make and model and problem in detail to provide you with a solution
  • Maanita Chadha
    Maanita Chadha May 03, 2008
    try areset of your tv..take the power cord out..keep the power button pressed for 10-20 seconds..then turn it back on and check
  • Maanita Chadha
    if you have hooked it u with a computer make sure your system is not in standby or sleep mode
We have 42" plasma akai
Any luck getting this fixed?Please let me know.Thank You very much!
Tyler
Jan 31, 2011 | Akai LCT2715 27 in. LCD Television
My akai flat screen tv is not turning on. the red light at the bottom of the tv is on and when the tv comes on the red light turns green and in a few seconds the tv comes on, when i press the power button...
i have one of these akai 27 inch with dvd, i had a similar issue i found a power supply at auction and exchanged it and it works fine now, normally with this symptom your power supply is fualty. if the light goes green and you have no picture then you know other boards are fualty
Jun 04, 2010 | Akai LCT3285TA 32 in. LCD Television
My Akia 27" lcd tv wont come on, all I am getting is a flashing red light and a popping sound. What could be wrong with it?
Ur power supply board is dead.Tries Websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 21, 2010 | Akai LCT2715 27 in. LCD Television
TV went out over time. Sound immediately, but no picture. Loud POP noise when i changed channel. After a while it would "warm up" and would work fine. now doesnt show picture at all. In monitor mode...
Check the power supply first for bac capacitors (learn more here about bad capacitors: http://en.wikipedia.org/wiki/Capacitor_plague)
I had replaced capacitors in my, hopefully it did not cause damages to other circuits such as backlight inverter board.
Nov 02, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
Akai lct 2701td comes on then shuts down
Hi
You have power supply problem. Please go to ebay and buy cheaper price:
AKAI LCT2701AD POWER SUUPLY MLT166A
Thanks
GEORGE
Mar 11, 2009 | Akai LCT2715 27 in. LCD Television
AKAI Rear Projection 46"TV has a blank picture with sound only
Is it a CRT or a DLP/LCD projector? If not a CRT, a worn-out projection lamp can cause this symptom. When it is a DLP projector, a faulty Colour Wheel sensor can be the additional problem. If it is a CRT projection unit the High Voltage and deflection circuit must be examined...
Please tell me more about your unit...
Thomas
Jan 19, 2009 | Akai LCT2715 27 in. LCD Television
Powering up and warmup problems
why does my lcd monitor change different colors no picture just turns to all sort of colors ViewSonic N2751W 27 in. LCD Television thanks 4 your help
Dec 05, 2007 | ViewSonic N2751W 27 in. LCD Television
Akai LCT2716 Flat Panel TV
I HAVE A RED BLINKING LIGHT ON MY TV ANY IDEA'S HOW TO FIX?
Sep 13, 2007 | Akai LCT2716 27 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
