Question about Maytag CWG3100A Gas Single Oven
The alarm turn on by itself when the oven is off, F2Code
  • Maytag Master
  • 17,130 Answers
Faulty signal that is going to the alarm driver to trigger off the alarm. The possible fault is the switching circuit, possible a leak in this semiconductor that is causing this issue.
You will need to go back to trace from the alarm buzzer backward to the driver. Since all other features are working fine, it can be only the faulty trigger.
Disconnect alarm if you think the fault is beyond you to avoid this annoying fault.
Helpful?
Posted on Aug 21, 2010
How do i fix the timer for delayed start
Strangely in all of this, u don't tell the oven when to start - it works it out itself!
First u need to set the length of cooking time, eg 2hrs.
Press the cooktime button(2nd one along), THEN use the +/- buttons to set the display to 2.00.
THEN press the readytime button (3rd one), and use the +/- buttons to set the end time.eg 1730hrs
The display should then revert to the present time.
THEN turn the oven control to the required temperature.
The oven will switch on at 1530 hrs.
If u were to press the cooktime button ONCE WHILST the oven was on - it will display the cooktime remaining.
AT 1730, the oven will switch off and the alarm will sound
To switch off the alarm, press the minuteminder button - first one - looks like a bell, THEN
REMEMBER to cancel the programme by pressing buttons 2 and 3 TOGETHER, otherwise it will do it again tomorrow!
HOPE THIS HELPS
I would suggest first.trying it when you're at home all the time the oven is on.
Sep 08, 2014 | Belling XOU592 / XOU593 Electric Double...
Timer alarm volume is down
iam sorry to tel you there is no way of turning it up you would have to get a new timer
Paul http://www.apart4u.co.uk
Mar 04, 2010 | Ovens
I pressed the self clean option and the oven locked but every two minutes an alarm sounds and the code F8 appears. The cancel option stops the alarm temporarily. How do I either clean the oven or cancel...
F8 code means your door latch assy needs to be replaced. Two options:
1. Turn it off on the circuit braker
2. Replace the door latch.
It will continue to try to lock itself most likely, as door latch microswitch logic is messed up.
www.oc-repair.com
Feb 10, 2010 | Dacor ECD230 Epicure Electric Double Oven
Oven turns on by itself without being preset to do so
You may have already called service and that is a good Idea since this could be a fire hazard if something was left in the oven when it comes on.
First I would check all the key lights on the oven controls to ensure that they do light. We have the same stove and several times we have brushed the top panel and turned things on accidentally. Ensure that the audible alarm is on/working - it helps.
The next strategy has to do with all the myraid of oven control modes if there is a defalult - reset to it . Otherwise cancel all timing or alternative mode methods for controlling the oven.
Has there been power outages or power surges correlating to these turn on phenomena? A surge protector if such a thing exists may be needed and static electricity may play in this as well - good luck.
Nov 18, 2008 | Ovens
Oven wont work
when i turn onether oven then a bipping alarm and oven will not come on. light come on but not heated up.
Aug 30, 2008 | Ovens
Alarm won't shut off
did you try turning breaker off then on after 5 secs or clear cancel or stop
Dec 12, 2007 | Jenn-Air JJW8530C Expressions Collection...
Maytag CWG3100A Gas Single Oven Logo
104 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Mack Baxter
ashburton
Are you a Maytag Oven Expert? Answer questions, earn points and help others
