Question about Canon imagePROGRAF iPF8000 Printer
I have a multisensor Error message with the Canon iPF8000 model.
    New Friend:
I have a Canon IPF8000s. It was working when we bought. But my employee screwed me over and now it doesn't work. I am getting the same error. The screen (Small one where the information is displayed) is saying Multi-Sensor Error, Please turn off printer, wait a while, then turn printer on again. I do this to no avail. It seems to turn on fine. Display would say to close the cave cover and the ink tank cover, so I do this then it would go to the multi sensor error. Please help me, I'm just a kid (18) starting business, and I want to impress my parents. Help! Please!
Posted on Nov 28, 2013
  • jamie
    jamie Jan 04, 2015
    Yoshi - did you manage to fix this problem? I'm having the same issue!!!
  • Mud Slinger
    Mud Slinger Apr 16, 2015
    Call a service company to look at it.
SOURCE: canon ipf8000s can not cat
Check your cutting wheel is in properly, have had a similar problem on a IPF8100, sometimes the wheel/cartridge just pops out
Posted on May 08, 2009
  • 3 Answers
SOURCE: resetting maintenance ctg for canon ipf8000
unfortionatlly there is a microchip on the back of the cartridge and it is looking for a new one. u will need to replace the cartridge by taking the machine offline then pushing the menu button, scroll down to maintaince, then right arrow to maintenance cartridge replacement then selct yes then ok. then replace the cartridge. sorry, but hope it helps
Posted on Jan 20, 2009
johnm329
  • 3 Answers
SOURCE: Canon ipf8000 won't cut paper
Check to see if the cutter module has fallen off the print heaqd carriage. A common problem. It is a blue module that snaps into the left side of the carriage. Usually if it has fallen out, it can be found in the far left end of the printer, so you have to stop the printer, lift the lid and stick your hand into the left cave.
Posted on Dec 29, 2008
techbuster
  • 5081 Answers
SOURCE: My canon IPF8000 printer has
In my knowledge the error indicates the voltage on the print head is abnormal. It is an hardware related issue.
Possible cases can the print head is faulty or the relays to the PCB may be faulty or the PCB itself.
We have to perform continuity checks between the relays and between relays and PCB. then we can confirm if the relay is faulty or the cables between them . If not print head would have failed and needs to be replaced.
Posted on Jan 18, 2011
Daniel S
  • 4323 Answers
SOURCE: I have a Canon IPF8000
Hi
This error is caused due to a faulty thermister however; you can check the fuser unit for any jammed paper around the upper fixing roller and try to clean that area. After this is done try to clear the error by entering the service mode, to enter press Additional functions, #. Then go to #7 Printer and press OK, then go to #4 printer reset and press OK, yes= *. If the issue returns then replace the thermister. Hope this helps...please post back for further assistance.
Daniel
Posted on Jul 28, 2011
Error code E161 403E on Canon ipf8000
The Head right have problem and you can replace it and install it again if the printer read it you can use it for short time.
Mar 08, 2016 | Canon imagePROGRAF iPF8000 Printer
Print head error
i have downGrade firmwares for IPF8100,IPF9100,IPF8000, IPF605,IPF700 UNLOCKS PRINT HEADS WHEN THE PLOTTER ASK YOU TO CHANGE THE HEADS. mail- a.louloudis1@gmail.com for questions and support
Jul 03, 2015 | Canon imagePROGRAF iPF8000 Printer
What causes error 031300312618?
Farid: According to http://www.copytechnet.com/forums/canon/56346-ipf8000-error-03130031-2618-a.html : this is "Print Head failure.
First try replacing the Print Heads and if the problem persist, re-seat all the cabling to the Relay PCB and the Carriage Unit PCB.
A loss or faulty connection to either one of the PCB's could cause the problem. In one case, the problem was related to both a faulty Flex Cable Assembly (QM3-2005-000) and the Carriage Assembly PCB (QM3-1995-020) for the IPF8000 and (QM3-3093-000) for the 8000S.
May 14, 2015 | Canon imagePROGRAF iPF8000 Printer
What is canon ipf_710 error code 003130031-2618
Met deze link kun je het gebruikers handboek ophalen. Het is met koppelingen, maar ik kom nergens 710 tegen.
Misschien kun je zelf zoeken. op de eerst pagina kun je al naar de foutmeldingen toe.
imagePROGRAF iPF8000S
Jul 14, 2014 | Canon imagePROGRAF iPF8000 Printer
Error message E161-403E
please me to fix this canon printer is giving me an error massage e161-403e how can i go with it please.
Sep 14, 2013 | Canon imagePROGRAF iPF8000 Printer
I have a Canon iPF8000 large format printer and a message comes up saying, "Clean Right P Head". I have cleaned the printhead as it states, but it keeps on showing on the printer screen. Because of this,...
Canon has bad heads for this LFP, it is not unusuall. Every model has this issue, canon even lower the price of head because of this.
When you replace the print head message disapears for some period of time.If Im not wrong I think that is P-01 or 03 print head involved.
Jun 15, 2010 | Canon imagePROGRAF iPF8000 Printer
Mystery Print Problem with Canon iPF8000
If it's within 12 months of purchase, Canon will replace free, although you may have to hound them a bit. This problem has occured twice (2 new heads) on our IPF8100 each time about 9 months in.
Mar 09, 2010 | Canon imagePROGRAF iPF8000 Printer
CANON IPF610 ERROR-CANT ACQUIRE STATUS
There might be a problem with the network settings of the printer canon e40
Aug 21, 2009 | Canon imagePROGRAF iPF8000 Printer
Canon ipf 8000 Error Code E161-403F
I have had two of my Canon plotters give this error.message, I had to manually move the carriage unit and replace the printhead. On one of the plotters the error message returned, on the second plotter I was able to go into service mode where it asked me to replace the printhead. I just went though the motions since the printhead was brand new and I was able to get the plotter to function correctly.
Feb 21, 2009 | Canon imagePROGRAF iPF8000 Printer
IPF8000 PLOTER
please input servicemode and reset all iniatilize menü
Jun 18, 2008 | Canon imagePROGRAF iPF8000 Printer
Canon imagePROGRAF  iPF8000 Printer Logo
4,753 people viewed this question
old marine
old marine
