Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Our Frigidaire Model no. FEF365ASA was being used for a family dinner and we'd just finished heating up garlic bread at 350 degrees. I took the bread out and turned the oven off. A short time later, I noticed the orange of the lower element through the glass. More than enough time had passed to allow for some cooling and at least the darkening of the element... I opened the door and found the temperature much hotter than the previous 350 degrees! I reached up and touched the screen for ON again and then OFF, but the element heat remained. I called for my husband and asked him to go to the panel so we could turn it off from the breaker. This worked of course. We kept it off for a period of time thinking there might be a reset factor involved and then turned on the breaker again. I didn't have to turn on the oven at all - I just watched as the lower element turned orange again and the heat kept rising. We tried it one more time with a longer period off, but the same thing happened again. So we kept it off and later when it was cool, I pulled everything out and unplugged the oven, took the paperwork off the back (fair schematic and diagram) and tried to do some minor troubleshooting. My husband and are both electricians. We find the schematic to be limiting without information about the EOC in the drawing. I do believe we may have seen the beginnings of a runaway oven situation and I didn't want to take any chances - so I took the EOC out and thought it might be the problem. There are no obvious smells permeating from this device and it doesn't look damaged (traces, etc). None of the described electronic oven control fault codes were displayed while these things were happening. I've used my Fluke meter to 'ring-out' several components for drill and they've come out okay. Does anyone have any suggestions or thoughts?
  • katwoonan Aug 23, 2010
    Thank you for your suggestions! And the website concerning the recall - WOW, I just read through all those comments. Sounds like we have the something like the same issue. Our Serial Number falls within the ones detailed in the recall - and I, like many of the folks who left their comments - would be hesitant to accept the 'repair' of a moisture barrier and new EOC... It would only be a matter of time. Funny...I've found myself watching the moisture that comes up from the inadequate venting - many, many times - and that it might affect the controls above - didn't hit me until reading all of these experiences. OF COURSE it would affect the electronic devices inside! There is no protection whatsoever around the EOC - NOTHING!! Until this event occurred, I'd never taken the oven out of its place in the counter to look behind it. After pulling all the plates off the back, there's nothing to protect the controls in the upper section where the EOC is located. Yesterday, to provide at least the cook top for use, I disconnected
  • 3,083 Answers
Wow, a crazy problem for sure. All I can think of is that you have to identify the element controller (probably the EOC, of course) and actively troubleshoot it, if possible. Voltage regulators, transistors, etc., can break down under a load, so ohming them out isn't always accurate, as you know. Wherever the most current is flowing, that controller path will be the culprit. On the schematic, backtrack the current supply, and take your best shot. If you can determine the current supply from the EOC, you might be able to take a couple shots at suspect components.
I just ran across this web page you need to read, it's about a lawsuit concerning your problem:
http://www.aboutlawsuits.com/frigidaire-and-kenmore-smooth-top-electric-range-recall-5664/
Maybe that will help, and hopefully Whirlpool will assist you.
Good luck, and hope this helps.
Posted on Aug 21, 2010
How do I clean my Frigidaire electric oven, Model FEF352AWF?
See page 13 for specific instructions.
ShopYourWay FRIGIDAIRE Free Standing Electric ShopYourWay
As tedious as it may seem I suggest that cleaning the unit by hand is the preferred process. Most failures that I have experienced have occurred just after the clean cycle is completed. There is a lot of stress during self clean and critical components are stressed and are more likely to fail. On two occasions I have had a failure days before family dinners. Usually in preparation for family we had been cleaning the oven. Both the temperature sensor and heating element have failed.
With a free standing oven repairs are a lot easier than with a built in wall oven requiring saw horses to remove and set. In any case plan to clean long before company in the event a repair results.
Why You Should Almost Never Use Your Oven Self Cleaning Function
Jan 06, 2016 | Frigidaire 30" Self-Cleaning Freestanding...
My frigidaire oven #cpes3085kf dosen't heat up. I start it and then I can see the temperature rising but it's rising so slowly that it would take an hour to get to 350 degree. What is...
Thank you for your inquiry, Stphanie Perreault!
From my understanding your Frigidaire oven will not heat up properly. It sounds like a possible issue with your thermostat or sensor. I would recommend allowing a professional technician to perform a proper diagnosis and locate the part needed for repair. This will help to avoid any unnecessary part purchases. Good luck. -Matt
Dec 27, 2014 | Frigidaire Ovens
Gas oven doesn't get hot enough
Good Morning Friend,
I understand that your Frigidaire oven will not heat to temperature if you set it to 350 degrees. I see that you have to set it to 450 degrees for it to heat up, and then turn it back down to the desired temperature. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power, set the clock and try setting the temperature to 350 degrees. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire Ovens
I have a frigidaire range model number FEFL78CQA
Hello Steve Spinner - From what you have described it sounds like the range is either experiencing a wiring failure or the outlet may be damaged. Could it be pulling too much current, is the range plugged into the correct breaker size? If any proves to be ineffective, contact a professional to move forward accurately.
Dec 01, 2012 | Frigidaire Ovens
What setting do I use to bake a large cake and also bread? The manual isn't very helpful. PDP790
westinghouse oven, cakes are usually 350 degrees where as bread is anywhere from 4-500 degrees depending on which kind of bread because they are different in weight due to yeast if you have any further questions message me back I await your reply and please remember to rank how this opinion has helped it allows me to continue helping others in similar situations in the future. Oh and btw I had to double check with the wife on this one lol have a great day Thanks Rick
May 08, 2011 | Ovens
Have just moved from UK and we don't have broil and bake on our ovens - what do they mean/what's the difference as I've been cooking garlic bread on bake but it's taking twice as long to cook?
The broil is the top element and the bake is the bottom element...so with broil you are heating from the top and with bake you are heating from the bottom...if your oven has a fan, turn that on with a bake setting and it will speed up the process..
heatman101
Apr 20, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
I have a frigidaire stove that heats to 50 degrees hotter than the know setting. Can it be adjusted to read correctly?
There is a calibration method to adjust the oven thermostat plus/minus 35 degrees if it is a digital display. The method varies depending on the model range. This calibration method is used to adjust the thermostat if it is not keeping proper tempature. For example if you are setting the oven to 350 and the actual temp it is keeping is 325 then you could use the calibration method to adjust it plus 25 degrees to correct the temp. Just so you know electric ovens will keep a pretty even temp but gas ovens will vary by 40 or more degrees to keep an "average" temp. For example the burner will come on when the oven is 330 degrees and turn off at 370. 330+370 then divide by 2=350. So a oven thermometer may not show you the temp you set it at in a gas oven but does not mean the oven temp is off.
Jan 14, 2010 | Ovens
I have a frigidaire oven model # PLEB30S8CCB won't get above 290
The coils should glow red when working. If the lower (bake) element does not glow it may be burnt out. Some ovens cycle the bake and broil elements during preheat and that mey be why you are getting some heat.
Aug 27, 2009 | Ovens
Fridgidaire stove/ove
I have a Frigidaire electric oven model # PLES389ECE. It is two years old. It has maybe 50hrs of use. I had the oven blower motor go out. Then I had a circuit board malfunction.  The repairman discovered that one of the main terminal connections was loose and caused the terminal block to short. Could this have been the problem all along? Also, we are having a problem with the oven coming up to temp. According to the operating manual, set oven temp. lets say for example  350 degrees. Once the oven is preheated to 350 a beep sounds. With my oven the oven is about 60 degrees to low. You have to wait about 10 more minutes. Is this normal with this model? Has anyone else had problems with this model? I also heard that Frigidaire made a bad batch of ranges. Could this be one of them?
Thanks, Vincent
Oct 27, 2007 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
