Question about OKI B2540 MFP Printer
How to reset the Toner Counter witout cheap card
How do you reset counter on Toner for TN-360
No, If you use a refill in your recent toner cartridge you need to reset the toner, if you use a new toner cartridge, no need to reset.
Aug 28, 2014 | Brother MFC 7840W Printer
Error code E03-12
Enter in the tehnical rep.mode,counter select the consumables mode and reset the waste toner counter.
Jan 23, 2012 | Panasonic Office Equipment & Supplies
My problem is i forget my Ricoh toner card how to start my 4 in 1 printer without toner card
unfortunately you don't have any chance to do that without toner card.
This card just reseted your printer counter after printing some number of images!
Your MFP is same like Xerox Phaser 3100 MVP so no other way!
Sorry for this...
Mar 23, 2011 | Ricoh Aficio Sp 1000sf All-In-One Laser...
Kyocera FS-C5030N Led Printer My printer ran out of the blue (cyan) toner so I replaced the cartage carefully following are the cleaning steps like I've done successfully before with the other colors....
You need to reset the toner counter. This is done through the Menu button and selecting Life Counters. The instructions on how to do this are found in the Advanced Operators Guide on page 2-75. The link below will take you to the manufacture's website where you can download it.
http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=14192&rid=14764
Resetting the Toner Counter
The toner containers must be replaced when the printer displays the Low toner or Replace toner message which will be given depending on the color of toner. The Low toner message will be shown as a pre-warning that the toner is running out and the printer will soon stop, at that time showing Replace toner. If you replace the toner container before Replace toner is displayed, you must manually reset the toner counter as explained below. Note that if you reset the toner counter before the toner container is replaced, the subsequent toner warnings will not be indicated correctly.
I hope this is helpful,
Shawn
Mar 09, 2011 | Kyocera FS-C5030N Led Printer
Panasonic dp-c322, "replace black toner"
This model estimates toner usage based on dot count.
You can reset the counter by pressing "function" key, then counter view. Scroll down near the end and you will find toner counter reset. Select "k".
Feb 15, 2011 | Panasonic DP-C322 Copier
On Xerox Phaser 3100mfp., after refilling the toner its asking "insert toner card"
when you refill the cartridge you got to put a card {seem like a credit card} to reset a counter of the printer. the slot of card is in bottom of control panel {panel with buttons}
Jan 11, 2011 | Xerox Phaser 3100MFP/S Laser Printer
Trying to clear the memory of a Xerox Faxcentre F116. Do you know the steps to accomplish this?
One needs to know what they are doing when resetting memory to the machine.
When resetting the machine, one needs to consider, the loss of memory data on the copy cartridge counter in the machine.
When resetting memory a copy toner cartridge needs to be in stock with a counter reset card.
Erasing memory will wipe out the old copy/toner cartridge odometer setting, resuling in "Replace toner/cartridge" error.
Please clarify which memory area is being erased.
Aug 05, 2010 | Xerox FaxCentre F116 Plain Paper Laser
Rocoh ac104 toner reset
I believe it has a 'quick blow' fuse on the front, left side, that needs to be replaced to reset toner counter.
Apr 08, 2009 | Ricoh AC104 All-In-One Laser Printer
Samsung SF560 Laser Fax
in the box with the new toner cartridge was there a credit type card to use when changing the toner to reset the toner counter?
read the instructions in the box :p
May 23, 2008 | Samsung SF-560 Plain Paper Laser Fax
OKI B2540 MFP Printer Logo
290 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
