Question about HP iPAQ RX3715 Pocket PC
I reset my ipaq 114 and then just appears the screen of beggining, i do it more than once and appear the same screen what can i do?
  • 12 Answers
Do it 3 times
Posted on Aug 21, 2010
I am trying to hard reset my IPAQ but it's not resetting...I have 2 and one was successfully reset, is there another way of hard resetting the HP IPAQs? Thank you
Please go through following link to set up your iPAQ.This page has the links to reset different models of iPAQ.http://resetcellphone.com/solution/HP
It will be better if you can give the exact model number of your iPAQ.
Mar 05, 2011 | HP iPAQ 114 Pocket PC
Ipaq 111 hard reset
Soft reset Perform a soft reset
A soft reset stops all running applications, but does not erase any programs or saved data.
NOTE: Be sure to close all running applications before performing a soft reset.
To perform a soft reset:
1. Locate the recessed Reset button on the HP iPAQ.
2. Use the stylus to lightly press the Reset button.
Hard reset
To perform a hard reset and return the HP iPAQ to factory settings:
Press Win + OK + Record together.
While doing that, press reset button and hold for 3-4 seconds.
Release reset.
Release buttons.
NOTE: Do not release the buttons until CLEAN REBOOT appears on the screen.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 18, 2011 | HP iPAQ 111 Classic Pocket PC
Can you put a sim card in a hp ipaq 114
sir how to install sim cord i paq114 hp
May 19, 2010 | HP iPAQ 114 Pocket PC
My ipaq does not load fully
I had same problem. Finally got mine sorted!!
Try a full reset. Hold the quick launch button and the rotate screen button simultaneously (top and bottom of 4 buttons on left of device) and then use stylis to press in the reset button (on top edge just left of SD card slot). Keep depressed until it resets then release the 2 buttons and then release reset button.
It will appear to do the same but it tells you at the bottom it is doing a reboot or something. After 30 secs or so it then goes past and gets to the screen align screen.
You might loss settings but it worked for me.
Aug 07, 2009 | HP iPAQ RX5915 Travel Companion GPS...
Memory on HP ipaq 114.
there are two types of memory my friend
1. RAM
2. ROM both built in PDA
third type is Storage Card u can store music and photos there but u cannot merge it with RAM or ROM so pls try to understand this difference
secondly if u want me to help u out on this memory shortage
then u can reset the device i mean hard reset and re install ur applications by time ur ROM is occupied by some useless files and ur performance is de graded try to refresh ur OS
Hard reset
HP iPAQ Setup Assistant
Use HP iPAQ Setup Assistant to simplify configuring settings on your HP iPAQ.
HP iPAQ Setup Assistant lets you save the settings on your computer. This can help you restore configuration settings on your HP iPAQ at any time. HP iPAQ Setup Assistant also allows you to perform a factory reset on your HP iPAQ and view detailed product information.
To hard reset HP iPAQ 114:
- press and hold the 3 buttons Windows, OK and REC
- press the reset button for about 3-4 seconds and release it
- release the 3 buttons
u can see the video for that but it is in russian lang but self explanatory
http://www.youtube.com/watch?v=BG68AzNBsds
third option is if u want to really get rid of this slow performance and shortage of space just get a clean CUSTOM ROM from
http://forum.xda-developers.com/ for ur PDA strictly at ur OWN RISK
pls rate me fixya if i have fixed ur problem
Mar 01, 2009 | HP Computers & Internet
Wallpaper problems
First of all, you need to reset your device, and replace the configurations to a factory settings, this make the things easier.
2nd: to set a picture to wallpaper the picture need to respect the characteristics of the display, and the image need to math the display size. in your case 240 x 240 and must be in JPG format.
Try to use this settings and post me a reply.
Good luck
Mar 01, 2009 | HP iPAQ hw6515 Pocket PC
When i do hard reset hx2490b screen calibration does not appear
Try using your finger to calibrate the screen at first. (If you have difficult to navigate to the alignment screen use the stylus & keyboard to feel out your way) when calibrated to an accepable degree use the stylus to calibrate the sreen, if the target doesn't respond to stylus at any specific piont use your finger. Continue this process till u get it aligned as best as possible. I suspect this problem is caused by specific points on the screen going bad.
Feb 24, 2009 | HP iPAQ HX2490 Pocket PC
Lost Default IP Settings screen after Mult. Interface Table
You have to do a factory reset to the device or it wont go away, make sure you dissconnect ethernet cable when doing the factory reset.
Jan 30, 2009 | AudioCodes MediaPack MP-114 FXS and FXO...
Rx3715 will not recover from a hard reset
try removing the battery - for a few minutes to begin witj, then a few hours if that doesn't help.
Sep 08, 2005 | HP iPAQ RX3115 Pocket PC
Backing up to memory Card
On the opening screen of iPaq Backup there's a line, "File," where the backup's filename appears, and a little box with 3 dots. Tap that little box and you'll get a menu allowing you to set the location.
Sep 07, 2005 | HP iPAQ H1945 Pocket PC
HP iPAQ RX3715 Pocket PC Logo
77 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
