Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Hi, we own a Frigidaire side by side refrigerator model FRS3R5EMBE. We recently hooked up a water line to the unit to make ice cubes & drinking water. The problem is that when initially water flowed into the regrig, there is LEAKAGEfrom the filter unit inside the refrigerator. I lost the product manual and am in the dark as how to resolve the problem....so, is there a solution to the leakage? We await your answer. Thank you, John, Monrovia California
  • Frigidaire Master
  • 909 Answers
Very unlikely the couplings are loose, but i think the cartridge is not screwed in properly (all the way). Take the cartridge out again and inspect if seal is in good order. Almost certain problem is there.(screw nice and firm).
Posted on Aug 21, 2010
Ice maker set up
it takes a couple hours for ice and not as long for water to chill .
Feb 09, 2015 | Samsung 26 cu. ft. Side by Side...
Frigidaire side by side with ice maker .. ice maker jams and quits making ice
Hollow ice cubes are a result of lack of water to ice maker. This can be caused by lack of water pressure (clogged filter, bad water valve, obstructed fill tube, etc..) you will need to find the cause to correct this hollow ice cube issue. The ice maker should take on 5.5 oz of water when it cycles (2/3 cup). Mot of the time its a water supply issue and the line could be kinked behind the unit as it was rolled back into place.
Good Luck
Dec 30, 2013 | Frigidaire FRS23H7CS Side by Side...
No water hook-up
you can buy a little pressure pump similar to what r.v.'s use but 110 volt a.c. instead of 12 volt d.c. for about 80 bucks.
Jul 23, 2010 | Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side...
Frigidaire model glrs267zcwi side by side. Crushed ice comes out when either the crushed or the cubed button is depressed. How to fix it please?
It sounds like the water line to the ice maker is partially obstructed (probably semi-frozen) and the unit is making smaller than normal ice cubes. This causes the ice ejector to "shatter" the smaller cubes, producing the appearance of crushed ice.
The easiest thing to try is make sure the water line connection inside the freeezer isn't frozen. A hair dryer can be used to thaw the inlet to the ice maker, but just be careful. Remove some of the product in the compartment so you have enough room to work.
Dec 12, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Can't make ice cubes only crushed ice
This happened to me. If you pull the ice bin out you will see a metal bar that extends from the front to back on the bottom of the bin. Find the square hole in the back of the freezer. Stick you finger in and slide the white plastic square up or down.
The switch you are moving is the toggle from crush to cube.
Jun 02, 2009 | Frigidaire FRS3R5EMB Side by Side...
I have a Frigidaire refrigerator Model FRS6L9EFSS0
Hi
When an ice maker is producing ice poorly--when it produces just a few cubes or crushed ice , or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please revert for further assistance and Do rate the solution if found useful.
Thanks
Rylee
Mar 18, 2009 | Refrigerators
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice maker not making ice
Same thing happened to me. I unplugged the refrigerator, plugged it back in and it worked. I guess the computer system reset itself. Easy fix.
May 13, 2007 | Maytag MSD2756G Side by Side Refrigerator
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
