Question about Dell PART NUMBER CARD NTWK PCI TR IBM 16/4 WOL 10462 Network Adapter
DELL PART # DN804 For E521 computer
Would like to know how to install this part
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 156 Answers
Hi
Dell Part # DN804 is PCI-e ATI Theater 650 Pro Combo Analog/Digital TV Tuner and it is compatible with Dell Dimension E521.
The ATI Theater 650 Pro PCI-e card is available in two form factors - Low Profile or Full Height. Dimension E521 is compatible with Full Height cards only. It is important that you ensure the you receive a full height card.
Check Installing a PCI Express Card for help installing the hardware. Next install required software/drivers.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/parts.htm#wp1080274
Mike
Posted on May 08, 2008
I have a problem with my daughters Dell Dimension E521 computer the fan is always running and there is no picture of any kind on the monitor.The monitor is good because it works on my Dell computer.can you help me with this problem. Thank You .GK
Posted on Jan 20, 2009
How do i reformat my dell dimension e521 computer
The easiest way is to boot from the Windows installation CD and select format hard drive.
Jan 17, 2012 | Dell Dimension E521 PC Desktop
Describe your dell dimension E521 wont boot and Problem my computer turns on but doesn't open it goes to a black screen with little flashing bar in top left corner nothing new was installed but there...
The 123 lights on tower translates as:
Routine system activity subsequent to video initialization.
Watch your monitor for on-screen messages.
Disconnect the video cable from the computer and see if you get floating color bars on display. If not, your monitor is defective.
Jan 10, 2011 | Dell Dimension E521 PC Desktop
I dont know how too reboot my dell dimension E521?
Dell seem to not make a lot of computers with reboot/reset button. If Windows is already running, you can turn it off or reboot it from the start menu. What you can also do is to hold down the power button for at least 5 seconds. Usually it will turn it off itself if you hold it for long enough.
Mar 08, 2010 | Dell Dimension E521 PC Desktop
Help! My dell dimension E521 will not boot after
Its seems like your RAM is not working properly, so once you replace the this RAM and check it, you problem should be resolve.
Regards
Ashly
Feb 01, 2010 | Dell Dimension E521 PC Desktop
MY DELL DIMENSION E521 WONT BOOT WINDOWS AFTER STARTING UP, I WAS TOLD THAT THE VIDEO CARD COULD BE BAD, WHERE IS THIS LOCATED IN MY PC AND CAN i USE ANY VIDEO CARD TO RPLACE THIS?
Hello, if you were told by an expert tha you need a video card, here what you need:
1: You do not have a slot card type video card in your system( Dimension E521) your system has on board video, which you can not remove from the system but disable it.
2: Your system has PCIe x16 slot that can be used for new video card.
3: Link below will give you a list of PCIe x16 video cards, you can pick and choose according to your needs. Do you need DVI (digital connection, does your monitor has a white port in the back or just the blue one?), or regular VGA (blue port) is enough, do you need HDMI etc...
bottom line is any of those video card will work.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=40000048%201069609641&Description=pci%20express%20video%20card&name=PCI%20Express%20x16&ActiveSearchResult=False
4: I am assuming you have never done this before so before you open up computer and start taking things apart go to the link below and download service manual for Dell Dimension E521 ( I selected the model for you so you don't have to look for it :-) )
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/index.htm
5: In the service manual link there are several Sections like:
Before You Begin
About Your Computer
Technical Overview
Specifications
Advanced Troubleshooting
System Setup
Removing and Installing Parts click on each one and read about it first to familiarize your self with the system.
6: Once you feel confident enough remove the power cable from from computer.
-> open computer cover
-> follow instructions in service manual under
->Removing and Installing Parts
-> Cards
->PCI Express Cards
-> Installing PCI express card.
-> Close computer cover
-> plug monitor cable to new card
-> power on the computer
-> if Picture quality is bad that means card was not properly recoginzed, install drivers from the CD that came with the video card.
I hope this helps, if you get stuck at any step or not clear feel free to post back.
Kind Regards,
Amar Sondhi
Feb 01, 2010 | Dell Dimension E521 (D10E16) PC Desktop
Would like hepl installing drivers to my new Dell Dimension E521 computer(Windows Vista)
Actually Dell can help you do that without calling them. Click the link provided here: http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?journalid=445651935F0948DCE040A68F27284B24&docid=324898
Than click, installing Drivers in the Correct Order.
Driver site for the Dimension E521:
http://support.dell.com/support/downloads/driverslist.aspx?os=WLH&osl=EN&catid=-1&impid=-1&servicetag=&SystemID=DIM_P4_E521&hidos=WW1&hidlang=en
If I tried to type this all out for you I'd be here for hours. If you get stuck let me know but I'm sure this will get you going.
please vote...
Feb 18, 2008 | Computers & Internet
Computers & Internet Logo
654 people viewed this question
Alun Cox
