Question about Sony KP-57WV600 57" Rear Projection HDTV-Ready Television
Tun on tv but in 10sec. turn of - Sony KP-57WV600 57" Rear Projection HDTV-Ready Television
  • Sony Master
  • 12,061 Answers
This is a classic switchmode power supply, shutting down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free.
http://www.fixdevice.com/smanuals/file/6252.html
Should you wish to DIY you must have a service manual, I have included the link above, for your convenience.
wanting to have a go and try to repair you set. But PLEASE, start in the right place, otherwise you will simply waste your time and money, You see, you MUST start, in the right place, The power supply, FIRST, as, if, that isn't right, nothing else can be. But you simply cannot do anything without a Service Manual. In this it has everything one needs to repair the set. OK if it is shutting down, after that amount of time, of working and then faulting, then it is most definitely a "Thermal" problem, the way we "Find" problems such as this is "Freeze Spray" you use this on each component that is suspected of being the "Culprit" and you will soon,find that errant component. Now, also not every fault is a Capacitor, I see many, many people that think, that Capacitors are always the "Culprit" and replace them, because someone else had done so and it worked, well that maybe sometimes true, but most Symptoms, can, and do have many, many different "Causes" & also, now while that may be true in a few cases, a faulty Electrolytic Cap, or even, ordinary, Cap goes faulty, this is only a SYMPTOM, something has damaged those caps causing them to "Fail". One MUST always find the root "Cause", otherwise if you just treat, the SYMPTOM, the "Cause" will just make the "Symptom" come back, in short order, as the prime cause still, hasn't been fixed., Now Capacitors hate AC ripple, or Over Voltage. Thats it. Oh.. and Heat, if these Capacitors, are too close to a Heat Source, then thats a prime cause of failure. Resistors, hardly ever go faulty,and if they do, it is generally obvious. However it doesn't hurt to check values with our Multimeter. Remember though resistors are made, with up to 20% tolerance from stated value, as such, are not too critical, unless in Timing circuits etc. Always check, the Values, of resistors, as with any other component, with the power OFF. Now Diodes especially "Zener Diode", are another thing to check, those and ordinary "Signal Diode" should always be suspect. next we have Transistors and IC's. The Transistors MUST ALL be checked to see if they have a good, "Junction" this is done, with our meter set to "Diode Test" and usually are about 0.6 to 0.7. With IC's you must check, voltage levels, or Logic Levels, going in and out, have a look at the circuit diagram, and it will tell you what they should be. It is a good idea to always measure the Power Supply voltages, see if a "Rail" is Low, that will be because some component has gone somewhat or all short circuit, to Earth, now, if the "Rail" is Higher, suspect an "Open Circuit" component, like a Diode, or Transistor. The voltages expressed in the manual are spot on, ANY variation MUST be investigated. I have been doing all this for over 30 years now, and I do indeed wish, we could have a set of "Symptoms" and be ables to say.. "Oh that;s the so-in-so and replace this" however unfortunately this although does happen, most "Symptoms" can have literally tens, of "Causes" all often "Interlinked" One simply has to do a methodical troubleshooting procedure, and always think, "are my Voltages Correct" as this is how, you Fix the problem, by making them so. Keep up the good work
Posted on Aug 21, 2010
When i turn on my TV (Philips) it's shows black screen and in middle is writed Locked after 7-10sec it turns off
That's a fairly old TV...The locked means that specific circuitry is locked because if running it would cause a major problem, and that is also why it shuts off. You are going to have to find someone familiar with Phillips TV's.
Oct 29, 2013 | Philips Televison & Video
Child lock on
Keep pressing one for one for at least 10sec, if not works try to press two button simultaneously at least for 5sec.
Sep 01, 2009 | Apex Digital PF2020 20" TV
Tv tuns itself off, maybe needs bulb?
Check fuse inside tv lower panel where power cord gose in to tv maybe your problem
Mar 02, 2009 | RCA P61960 61" Rear Projection Television
When the tv on then auto tunning start
same of the tact switch are defictive so change all the switches with a new one or else try to fix that switch
Aug 23, 2008 | Sanyo DS20930 20" TV
JVC TV crisis.....HELP
yes... i actually work at verizon the tv is to old for fios because fios is so advanced we run off ot 720 to 1080 depending on areas. what kind of box is it? is it the hd box or stb>
Feb 13, 2008 | JVC AV-32230 32" TV
Wii not turn on
splitter box
Dec 13, 2007 | RCA P60828 TV
Tunning and setting a all in one remote control for tv
pink,
I believe you mean One-for-All? In any event try this link for codes.
http://www.remotecodelist.com
Bill
Nov 18, 2007 | Universal Remote Control Hampton Bay...
TUN 881 TV CARD DRIVERS
I might be able to find a driver for it, just need to know which company makes the card?
Oct 20, 2007 | Microsoft Windows XP Professional With...
Green pict and turn off in 10sec
Rod,It sound like you have a Grid to Cathode short in you Green Gun Contact me when im online and Ill be able to Help you ttech
Jul 24, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony KP-57WV600 57" Rear Projection HDTV-Ready Television Logo
66 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
