Question about Sub-Zero Freezers
My 501f ice cube maker just drips water into the cube receptacle and makes 1 or 2 small cubes of ice. the receptacle fills with water and freezes. It worked perfectly two days ago
  • scottyboy195 Aug 21, 2010
    guess I'll just call a repair guy to come fix it. Is there a way to turn it off in the meantime?
  • 3,083 Answers
Here is a good troubleshooting procedure for this problem, and should let you know what your problem is and how to fix it:
http://www.ehow.com/how_112158_repair-clogged-ice.html
Can't answer your question more specifically, since it seems to me you're saying at first, that the water just drips in (indicating clogged tube), but in the second line you state the receptable fills with water and freezes...at any rate, the web blog should help you figure it out.
Good luck, and hope this helps.
Posted on Aug 21, 2010
  • Tom Carson
    Tom Carson Aug 22, 2010
    There should be a petcock valve to shut the water feed off, and the electrical control plug can be disconnected, but getting to it could be hard. If the water is shut off, that should work until you get it serviced. Good luck, hope this helps.
French door / lower freezer. The icemaker makes ice fine until tray is about full and then slowly drips water until about 1/8 of ice is frozen together with a upside down brown ice cycle fused to them....
The most common reason for this is that the fill valve for the ice maker is sticking slightly.
The brown ice comes from the leaking water sitting there on either the kickout bar or the gears and you are getting some residual rust deposit.
You will need to take the fill valve apart and clean it or possible replace it, I also recommend installing a water filter for the ice maker if you don\'t have one or replace the old one.
Calcium deposits in water are real hard on these small valves.
Oct 10, 2013 | Jenn-Air Freezers
I have a Sub-Zero Model 501F freezer making ice cubes
Check defrost heater that goes into drain tube. When the drain freezes ;the defrost water spills into the icemaker.
Oct 08, 2009 | Freezers
Kenmore ice maker problem
the problem is an unlevel icemaker to prove this do you see little droplets of water freezing from the icemaker or a remote possibilty is do you have to an R/O system and have you change the filter if unit has one.
Aug 19, 2009 | Kenmore Freezers
My jenn air freezer is not making cubes. the
The water inlet valve may be staying open. You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it. If it does stop after trying it several times then the problem is with the ice maker.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Jul 13, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Ice maker seems to be dripping water onto ice in ice container
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Watch it when it fills with water. The fill tube could also be stopped up with ice. The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Jul 12, 2009 | Kenmore Freezers
Ice maker only fills the tray partially.
There is an adjustment, but first check your filters, including the one in the inlet of the control valve. To find the adjustment, take the cover off the front of the ice maker. On the side may be a little hole. Look for any 'increase' arrow or such. If not, use a small screwdriver to turn the adjustment a half turn and let it make a load of ice. If it gets smaller, go the other way, use small adjustments. If you can get the owner's manual, it will help a lot. Google your unit for one, you may be able to get it downloaded free from Whirlpool.
May 05, 2009 | Whirlpool Freezers
Thin Ice on Whirpool Ice Maker
Hi
If  The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
Apr 05, 2009 | Whirlpool Freezers
GE top freezer refrigerator automatic ice cube maker leaks water into the freezer, and eventually on the floor. Water seems to be coming from the area that fill up to make more ice cubes.
If it is leaking water in the freezer it will more than likely freeze amongst the ice cubes causing a block of ice.
It is more than likely leaking at the rear of the unit, near the valve or fill tube for the ice, this will run up the rear wall of the unit.
Mar 12, 2009 | GE Freezers
Ice cube shape
hoshizakis make ice cubes depending on the amount of water in the sump. if you are starving for water the sump only partially fills in the fill time allowed . then it makes ice until the water is used up and the float switch drops and the cubes are little slices. you can adjust the size of cubes you want by raising or lowering the float assembley in the sump. if its to low the water rises and the float rises and tells the machine you happy with little slices. if you raise it up to max height you can max fill before float satisfies and max ice cubes. But if you are starving for water the time to fill will run out before the sump fills and cubes will be small no matter where you set the floats assembly. water starving can be due to crud in the water line, to small a water line, most hoshizes take a half inch line ,or a clogged water filter. if you suspect a filter take it out . if fill is drastically improved you need a new filter. be aware that starving for water on a hoshizaki will eventually lead to broken evap plates. big time expensive.good luck. i put in a new machine ruined by starving water and the new one made little chips of ice real quick. i finally pulled the filter out and voila! big cubes and great production.
Oct 28, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Freezers Logo
223 people viewed this question
Top Sub-Zero Freezers Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
AJMAL KHAN
Are you a Sub-Zero Freezer Expert? Answer questions, earn points and help others
