Question about Samsung TXJ2754 27" TV
No sound and has a horizontal line at the center
  • 901 Answers
Check SMPS power supply DC voltages like +12, +5, +24 etc. If you are trouble shooter your self, you can try this with your multi meter.
But one doubt: When you say only horizontal line is visible there should be sound from the selected channels audible!!!!
If circuit is not available note down the IC numbers, track them in Google.
Note down the supply pin nos. You can check the voltages accordingly.
Posted on Aug 21, 2010
TV screen has a thin horizontal line in center
this will only help until the next time it is out of alignment but if you slap the side of your tv about where the line is it should straighten out but there is no telling how long it will stay straight......My sons tv was doing that and i had a tv when i was young that did it that is what my mom told me to do and what i told my son to do and it works.... the problem is an alignment or conection problem from dust most likely.
Jul 11, 2012 | Sanyo Televison & Video
How do you adjust headlights on a 1993 chevy C1500
if you look at the light, there is an adjustment screw at the top of the light that controls the up and down motion , clockwise will raise the beam, and a screw on the side that controls the side to side motion. the best way to center your lights would be to park the vehicle 25 feet away from a verticle wall. be sure to be very square to the wall and on level ground. make a tape line vertically on the wall in very close relation to the center of the vehicle, and another tape line vertically in very close relation to the center of each headlight. now place a tape line horizontally in very close relation to the center of the headlights. start with low beam adjustment. adjust the high intensity zone to 2 inches below the horizontal line and 2 inches to the inside of the vertical line directly in front of the headlight. for high beam adjustment, adjust so that the high intensity zone is centered on the center vertical line and just below the horizontal line. hope this helps
Apr 04, 2010 | 1993 Chevrolet C1500
Horizontal line in toshiba TVs
its the horizontal output IC
Feb 14, 2010 | Toshiba 28N33 28" TV
White, horizontal line in center with vertical striations.
55hdm71 plasma hitachi vertical lins 3 red on right side what do i do?
Oct 04, 2009 | Toshiba 42HP84 42 in. Plasma HDTV
Symphonic WF 2702 has sound but no picture. The
This could be a capacitor if your lucky but can also be the horizontal transistor. The repair could cost you between 60$ and 150$
My opinion; it's not worth it.
Jul 01, 2009 | Symphonic ST419E TV
TV BLACK SCREEN WITH THE POWER ON.
It needs repair.
If the line is vertical, then something is damaged on its horizontal circuit section on the mainboard.
If the line is horizontal, the vertical circuit section is damaged.
have it repaired to a qualified service center or person!
avoid switching it to avoid further damage on other parts!
May 28, 2009 | Philips 32RF82S TV
Vertical line in center
If the line is "vertical" then the vertical circuit sounds OK. The problem would be in the horizontal deflection.
Check yoke connection and solder around horz defl circuit.
If the line is horizontal then I would suspect the vertical IC.
Apr 02, 2009 | Sanyo DS31520 31" TV
Toshiba TV CX2789K Horizontal Line
Failure in the vertical deflection amplifier section. This is usualy from failed components, and sometimes cold solder connections. Most of the time, I found bad capacitors, and sometimes the output IC or transistors (depending on the model type) that have failed.
Take the set to a service center for an estimate. You may find it more feasible to buy a new set depending on the parts that failed and the time involved to do the work.
Jerry G.
Apr 14, 2008 | Televison & Video
Toshiba 32d46 single horizontal line in center of tube
Hi. Check the frame output IC for dry solder joints.
Sep 15, 2007 | Televison & Video
GE 35GT168
If you indeed have a line down the center of the screen that means the horizontal output transistor is working as it produces high voltage as well. The rectifiers are working otherwise you would have no power or sound. What you need to look at is either the horizontal windings of the deflection yoke are open or you have a open return from the yoke to the horitontal output stage.
May 06, 2007 | GE 35GT740 35" TV
Samsung TXJ2754 27" TV Logo
Jerry Greenberg
Jerry Greenberg
