To change the input and output resistors of a Geepas sound device, you'll need to follow these steps:
- Acquire the necessary tools: You'll need a soldering iron, solder, wire cutters, and the resistors you want to use (in this case, resistors numbered 45 and 47).
- Locate the resistors: You'll need to open up the device and locate the resistors that need to be replaced. Make sure you know which resistors are numbered 45 and 47 before proceeding.
- Remove the old resistors: Use the soldering iron to heat the connection points of the resistors and then gently pull them out with a pair of pliers.
- Install the new resistors: Place the new resistors in the same location as the old ones and solder them in place.
- Test the device: Reassemble the device and power it on. Test it to make sure that it's working properly.
Note: Replacing resistors can be a delicate process, and if done improperly, it can cause damage to the device. If you're not confident in your ability to perform the task, it's best to seek the help of a professional.
