Question about Danby DKC646BLS Full Size / Pony Beer Keg Cooler
Same problem with our kegorater
Can you tell me how you fixed your problem after taking the coupling apart? We did the same think & can't get it to pull beer through the line...
email us at rkratz@tampabay.rr.com
Thanks!
  • Anonymous Dec 24, 2008
    Cannot get the beer to come out . Do we need a different coupling for stella artois
Turn your temp down in cooler
Posted on May 18, 2008
How do I take Panasonic fz150 apart that has had water intrusion
I dont think thats possible. Some parts might be permanently damaged. give it some time, otherwise contact Customer Support and/or get(buy) a new one.
Oct 02, 2014 | Panasonic Lumix Dmc-fz150 - Kit Digital...
Front brake caliper sticking
You have two choices
Take it apart yourself & fix it
or take to a shop
You can only have a rusted caliper or
restricted flex hose.
If you never take the brakes apart once a year,
then you got a rusted mess to work on for a
couple days
Sep 20, 2013 | Jaguar Cars & Trucks
How to repair plastic hose behind water pump 3.8 v6 what is the easy way to fix do i have to take apart intake to get to it
No, you do not have to take off the intake, but you do have to take off the Alternator and bracket. It is really an easy repair and the tubes don't cost very much at all. The tubes come off with the Alt. and heater hose bracket. Couple of odd metric, bolts I think they are a 15mm.
Sep 29, 2011 | 1998 Pontiac Bonneville
No sounds . no voice . no noise on numbers. cannot hear people talking. cannot hear voice mail. will ring. cannot answer
take it your phone has been dropped a couple times? lol..
Does the screen work normally? either way if you havent fixed this yet (seeing as this is 23 days old as i post) your going to have to take your phone apart. you can try the easy way and take the bottom half apart but dont try to take the screen off. there is a flimsy ribbon cable that runs from the top corner of the bottom half through the hinge that is easier than heck to break. after you get the bottom half apart try pressing down on the plug of it to see if it is loose then try your phone again.
the reason i asked if the screen is working is because that one cable usually handles everything in the top half and when one thing in an electrical device (expecially a small one that has a bunch of tiny components) doesn't work there can be no telling what else will go with it
Nov 12, 2010 | LG VX8350 Cellular Phone
How long does it take to take the transmission apart. Not fixed just take it apart. I had a nissan maxima 2004 5 speed taken the transmission apart and they shop wanted to charge me $800. Is this right...
It shouldn't take more than a couple of hours, 3 or 4 at the most, to disassemble the transmission. Sounds a bit expensive for just taking it apart. I would check some other places.
Nov 12, 2010 | 2002 Mercury Mountaineer
Hoover Maxi 6 TC50 Tumble Dryer making squealing noise
Have you fixed this problem? I also have a Hoover condenser dryer, only a few months old, and has started to make a squeal/whistle. I'm thinking it might be the front fan needing some WD40, OR too much water vapour around the belt that moves the drum causing the sounds.
If it's the fan, lubricating the shaft and its components should fix the problem, if a wet fan then I'd think maybe fully cleaning the condenser filter, reservoir ect will fix the problem.
The problem seems to go away though "mostly" 15 or so minutes after you start the dryer, so that makes me think ones it gets warm something is expanding to allow more "give" so maybe the belt.
Aug 26, 2009 | Hoover Dryers
Env2 got wet, front keypad having problmes, "o.k" button doesn't work can I remove front cover, how??
This just happened to me last night. I FIXED IT!
The bottom half was working, the top keyboard was not working. The only button on the top that worked was the power key. Today, I got a screwdriver and took the whole entire thing apart. Start by removing the battery, then take out the 6 back screws. Gently pull the back apart - this will be tough, do it evenly around all sides instead of getting just one side and yanking or you might break it. two of the screws on the top are accessible readily, but the two near the hinge are only accessible once the back is apart. Take the front apart with these 4 screws. dry it out with a q-tip. There should be four more screws inside - take those apart and dry clean. Pull the face off and dry the large white plate that receives all the button action. I put it all back together and my buttons worked again. I didn't even feel like I did anything to fix it because it wasn't really wet inside, i think there was just a micro-dot of moisture on that white plate. I hope it works for you. I was so excited about mine that I got on here to tell others. But hey - I also prayed about it and God cares even about the little things!!!!! Now - I've got the battery out and am leaving it out for a couple of days just to make sure that its totally drive because any water in there could still damage the phone if there is a power source. GOOD LUCK!
Mar 09, 2009 | Verizon Communications enV2 Cellular Phone
Eureka atlantis...water won't spray out.
Try taking the upholstery nozzle apart, there are only a couple of screws, and make sure the little tube is attached where it is supposed to be attached. Be careful when you take it apart, and remember how to put it back together. Try running some water in the one end and see if it comes out the other end. I had a problem with the grip switch not working, and ended getting Eureka to send me a whole new unit as it was still under warranty. I honestly tried to fix it myself, but I don't think the design is good enough to be fixed, so replacement is usually the better choice. Again, I say, shame on Eureka for such a bad product. A good appliance service depot should be able to get a new hose for you, but if you have to pay big bucks, I think it is better to try a different brand than Eureka. I'm assuming by your question that the nozzle is the one on the upholstery hose attachment.
Nov 20, 2008 | Eureka Atlantis 2595A Upright Wet/Dry...
The on button seems to be stuck down on my sony cybershot
The button is made of plastic an one of the tabs i probably broken. If you have the skills to take your camera apart, you can fix it yourself. You can go to the YetiCam.com site, under manuals select Sony DSC-S600 Version 2 (Updated 2/17/07). This will tell you how to take the camera apart. Then you need to take some Super Glue and glue the two pieces back together. Be carful not to put too much glue on the pieces, or the switch will glue itself to the other pieces in the switch cover. Here are a couple of shots of the underside of the cover showing the switch piece. Red circles show the weak points.99f3da3.jpg7325b53.jpg
Jan 27, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
No Power?
I have repaired a couple of my units, its hard to get the right plug but if you open the unit you can compare it to ones on Digikey.com or Mouser.com. soldering will be tricky...
Jul 28, 2007 | Fine Digital FineDrive 400 GPS Receiver
Danby DKC646BLS Full Size / Pony Beer Keg Cooler Logo
150 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
