Question about Samsung Televison & Video
How to install samsund tv un46C6400 to the stand
My Samsung TV doesn't show a picture, when there was a picture audio and remote not working. Which boards need replaced?
If there is no audio then most likely your main board. If your red power stand by light blinks less than 3 s then its the M/B. If its more than 3 s then its the P/B.
Sep 03, 2015 | Samsung PN50C550 50 in. TV
How do I hook up a samsund bluray dvd player to my tv
depends on the TV and what kind of connectors it has .HDMI,RCA ,or USB both units have to have the same type
Aug 14, 2015 | Dynex 32 in. LCD Flat-Panel HDTV
Samsung UN46C6400 turns OFF randomly.
Have you checked all the secondary voltages at its main power regulator board. I think you haven't. If so, check the link given here. It has http://electronicshelponline.blogspot.com/ voltage details to all sockets at the power supply section. But you have to find the relative post there. Pull up older posts by its left side bar, or see it in Timeslide option.
Jun 16, 2013 | Samsung UN46C6400 46 in HDTV LCD TV
Il.comwhat is the wattage power consumption on this TV and does it work on 240 volts in Australia and pick up all the digital channels. Is there a ghost/ motion problem with this TV as some American...
240 volts is the same anywhere
the specs will be on the decal on the back of the unit
ghosting is an antenna problem
one thing to be aware of
buy it overseas and the warranty will be no good here
Feb 04, 2018 | Samsung UN46C6400 46 in HDTV LCD TV
I have a Samsund LNT4032HX/XAA i need to find a oem base/stand and cant find one. do you know where i can get one or what the part number is?
the easy way to find one is going to a tv repair or call , and have then macht one for u , the part # is BN96-03697B
Nov 03, 2010 | Samsung LNT4066F 40 in. LCD Television
My 72 inch samsund dlp tv has a ''check fan no. 2 message and the stand by/temp and timer lamps are blinking. both fans, sensor, balast, power supply and main board have been replaced
Hi,have you tried replacing the lamp? if tv is between 2-4 yrs thats what it could be,also reset tv by unplugging it wait 5 min and plug it back again.
Sep 30, 2009 | Samsung Televison & Video
Samsund rear projection tv
I hate to tell you this but its a good chance its your light engine,if the dots begin to spread over the TV it is the Light engine.
Jun 11, 2009 | Samsung HLN567W 56" Rear Projection HDTV
Samsund cd rw drive not able to read cds. though there is power light blinking on drive
samsund cd rw drive not able to read cds. though there is power light blinking on drive
Feb 07, 2008 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Connecting DVD VR357
direct to tv always best picture ok hdmi then sound from tvs digital outputs to input on your digital reciver ok
Jan 18, 2008 | Samsung DVD-VR357
Televison & Video Logo
65 people viewed this question
Jerry Greenberg
Jerry Greenberg
