Question about Panasonic KX-T7636-B Corded Phone
Hi, can I connect KX-T7636 phon to computer ?
  • Panasonic Master
  • 2,460 Answers
Sort of. The 7636 phone connects to a TDA/TDE/MCP system. There's a 7601 USB module that will connect to the phone and it can be used with special software. Check it with your dealer.
Carl
Posted on Aug 21, 2010
How do i change the preferred line assignment (outgoing)?
The manual (same as KX-T7636) explains that, and can be downloaded from...
Jun 23, 2014 | Panasonic Kx-t7633 Single Line Corded...
Panasonic KX-T7636 I transfer calls from the office to the mobile but after about 10 minutes they get cut off. I don't think it's anything to do with the mobiles or the reception. Is there a...
There is and you found it. It's adjustable, depending on your system. In a TDA-30/50 it's system program 473 and the keyword search is either Extension - CO or Call Limit. If turned on, the default is 10 minutes...it's adjustable to 60 minutes.
Carl
Jul 06, 2011 | Panasonic KX-T7636-B Corded Phone
Can't pick up phone messages off a Panasonic (office phone) KX-T7636
hello you will have to call your network provider they will set it up for you only takes 2min goodluck
Mar 25, 2011 | Panasonic KX-T7636-B Corded Phone
Need to turn on the ringer on my KX-T7636 corded phone, how do I do this please
It depends on how it's turned off. If the display says RingOff, then you press the button and use the Up arrow on the navigator button.
If it's off because it's not programmed to ring, then your extension needs to be added to the ICD group that rings all the other phones. That, of course, is an installer or administrator function and beyond the scope of a free forum to provide.
Carl
Oct 28, 2010 | Panasonic KX-T7636-B Corded Phone
HOW TO SET THE TIME KX-T7636
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system.
From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook:
1. Press PROGRAM * * or PROGRAM * # followed by the system password ( usaully default is 1234).
2. Now press 000 and then ENTER.
3. Enter the last 2 digits of the year and then select the month with either SEL+ or AUTO ANS / MUTE.
4. Scroll right with the right arrow key and change the date.
5. Press the NEXT button on the screen and the time will appear.
6. Set the time. Press AUTO DIAL / STORE to save your changes.
7. Lift the handset and put it down to exit program mode.
Mar 14, 2010 | Panasonic KX-T7630 Corded Phone
How do i set up new Extention names and numbers for the Panasonic phone KX-T7636
Extensions are named in the 004 programming section of System or Manager programming. You have to have access and a password to get there. Generally, we give everybody access to Manager programming, but your installation may be different. Extension 101, the operator's phone, by default has access, but it may have been changed.
Try page 177 forward with the 004 command on page 183 in the attached manual link. Somewhere, there will be the key to entering letters as you name the extensons.
http://public.carl.airpost.net/Pana/TDA/200_TDA_OM_06-121.pdf
Carl
Nov 09, 2009 | Panasonic KX-T7636-B Corded Phone
How to undivert a KX-T7636
*7100. clears all forwarding. If that doesn't work *790 clears most extension data.
Sep 12, 2008 | Panasonic KX-T7630 Corded Phone
Panasonic KX-T7636-B Corded Phone Logo
101 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
