Question about Viking VMOS200 Microwave Oven
Looking for vmos200 microwave safe plate - Viking VMOS200 Microwave Oven
  • Viking Master
  • 9,098 Answers
The Viking VMOS200 is just a stylized rebranded Sharp R-530E-series microwave.
So you could use the Sharp tray (part # NTNT-A099WRE0 - zero on the end, not oh) from Encompass here or at 866-779-5835.
O
r contact Distinctive (Viking's parts supplier) at 248-380-2007 if you'd prefer their version.
Posted on Aug 23, 2010
Viking microwave vmos200
mine did the same thing took back apart cleaned put back togerther no fix bout new one
May 10, 2013 | Viking VMOS200 Microwave Oven
Viking vmos200 sparking
If there is spark please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is leaking and sparking to the ground. As you have mentioned it was stored, it is quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Now switch the microwave power on and use a cup of water to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. Replace with same type. If not check the waveguides within the cabin for food particles that can burn and spark, check for rust that can corrode and spark when the ceramic paint has worn out.
If there is heating without any issues, you can use the microwave safely
Click on replacing waveguides: http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Jan 31, 2013 | Viking VMOS200 Microwave Oven
Vmos200 microwave-set microwave timer goes down no power but when open switch is pushed in a little bit it works holding it in slightly
On these, this is usually due to a failing bottom door switch, or its mount. Sometimes the door can also get misaligned due to slamming.
See my help file on door switches here.
The Viking VMOS200 is essentially just a rebranded Sharp R-530E-series oven. The R-530E service manual is here and it's helpful in working on your unit.
All the internal parts will be the same, but outer parts are cosmetically different.
You can order Sharp parts from Encompass here or you can call them toll-free at 866-779-5835.
Viking Customer Support is at 888-845-4641.
For Viking parts, on the West Coast call 1-800-488-9868. Otherwise call Hadco at 800-241-9152 or see http://www.hadco.net.
Aug 27, 2012 | Viking VMOS200 Microwave Oven
MICROWAVE RUNS ANTURNS ON BUT NO HEAT
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ..
Nov 12, 2010 | Viking VMOS200 Microwave Oven
I have a microwave model VM 05200 and nedd the turntable glass plate. How can i get one?
The Viking VMOS200 is essentially a rebranded Sharp R-530E-series oven, so the turntable (part number NTNT-A099WRE0 available Encompass here or toll-free at 866-779-5835) from that should work fine.
If you prefer, you can order it from Viking's supplier Distinctive at 248-380-2007.
Sep 07, 2010 | Viking VMOS200 Microwave Oven
HOW TO CHANGE VIKING MICROWAVE LIGHTBULB VMOS200
The Viking VMOS200 is essentially a rebranded Sharp R-530E.
One or both of these service manuals should cover disassembly and location of the bulb:
http://www.microwavedisplay.com/r530ekt_r530est_r530ewt_sm.pdf
http://www.microwavedisplay.com/r530es_sm.pdf
May 28, 2010 | Viking VMOR205SS Microwave Oven
My viking vmos200 miro wave is not heating everything else works
Basic Microwave Oven TroubleshootingTips
heatman101-=]]-=
Mar 02, 2010 | Viking VMOS200 Microwave Oven
Viking VMOS200 Microwave Oven Logo
105 people viewed this question
Top Viking Microwave Ovens Experts
William Miller
William Miller
Colin Stickland
Colin Stickland
Craig Butler
Craig Butler
Are you a Viking Microwave Oven Expert? Answer questions, earn points and help others
