Question about Craftsman Single Speed Rotary Tool
My variable speed craftsman rotary tool has a five postion switch. The model number on the case is 572.610530 which is the number for a single speed tool. I need to order the correct switch but the switches in the Sears parts direct do not tell me wich one is the variable speed one. Can anyone help me find a source for the correct switch?
5 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: Where can I get a PDF copy of the owners manual
go to Managemyhome.com and under manual type in your model number and after the 4 add a 0. The manual is 37 pages long. If I have helped you with your request would you please rate this reply accordingly and Thank you.
Posted on Oct 03, 2009
Testimonial: "Thank you very much. This Manual was difficult to find and you helped get it. Much apprciated."
  • 28 Answers
SOURCE: i have a rotary tool single speed chuck does not
Common issue with these, the plastic flex coupling is broken-
Replacement available for $2.57 from
http://www.searspartsdirect.com
Number: 2615294309
Category: Hardware and Tools
Weight: 0.18
Disassembly on my model involved the following:
Remove the four Torx screws on the body, then unscrew the front end cap at the front of the tool to expose two more screws. Separate the two halves of the body to see the brittle and broken yellow coupling.
Replace with the new white coupling and reassemble. Buy spare couplings as they don't seem to last all that long.
Posted on May 19, 2010
kel1guy2002
  • 3740 Answers
SOURCE: have a MODEL 572.610530 CRAFTSMAN
Hi and welcome to FixYa, I am Kelly. First off you did not mention the age of this tool which would have been quite helpful in my response.
I looked up your parts here:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Rotary-tool-Parts/Model-572610530/0247/0741520/10043672/00001?blt=06&prst=0&shdMod=572610530
You should inspect the brushes (item 11) for wear or broken springs. From what I can tell this particular model has been in the retail market place for at least 10 years. This would lead me to believe that the brushes are suspect. The brushes can be removed by unscrewing the opposing "screwdriver slotted" plastic caps on the outside of the tool and then carefully lift them out for inspection.
Use a flashlight and inspect the armature where the brushes come into contact. It should be shiny copper colored and not dark or black.
I also note that the switch has 5 speeds. Since it does not work on any speed... I doubt the switch has failed.
Detailed view:
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2f10043672-00001.png
Your manual:
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0709185.pdf
If you have more questions after inspecting the brushes, feel free to respond anytime with those questions
Thanks for choosing FixYa,
Kelly
Posted on May 18, 2011
jyackle5
  • 8197 Answers
SOURCE: How do you put a bit into a flexible shaft rotary
On page 2 of the link below will tell you how to change the bit on the flex shaft.
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0403078.pdf
Posted on Jun 12, 2011
Trying to change drill bit on Craftsman Rotary Variable speed drill
Lock the spindle (small chrome button near the tool's nose or lever at the power switch). You'll probably need to rotate the spindle by hand as much as one full turn as you do this, to get the lock to drop into place.
With the spindle locked, use your supplied wrench to turn the collet nut counter-clockwise (as seen from the cutter end) about one full turn. The collet should now be plenty loose enough to release the cutter / wheel / drill.
Mar 26, 2014 | Craftsman Variable Speed Rotary Tool Kit
I have a rotary tool single speed chuck does not
Number: 2615294309
Weight: 0.18
Mar 16, 2010 | Craftsman Single Speed Rotary Tool
Coupler between motor and chuck disintegrated, where can I get a replacement coupler for a craftsman rotary tool model# 572.610011? Thx
As of 5-18-2010
The following is available from http://www.searspartsdirect.com
Flex coupling
Part Number: 2615294309
Weight: 0.18
$2.57 In stock
Sep 09, 2009 | Craftsman Single Speed Rotary Tool
The variable speed switch on my demel is burnt out, will a layer of solder on top of it fix it?
I wouldn't recommend using solder in an attempt to recoat the electrical traces of the variable speed switch, rather, I'd get a replacement switch for it and do the repair correctly.
Trying to jerry-rig the switch like that could cause a more serious issue, like burning up the drive motor, etc.
Here's a place that has replacement parts (and a nice exploded drawing of the tool too) that should help you out. If the part isn't currently available from them, you can search elsewhere for another supplier.
http://www.ereplacementparts.com/dremel-400-xpr-variable-speed-rotary-tool-parts-c-15440_15456_15610.html
The switch part number is 2610920711.
Hope you find this Very Helpful and best regards!
Aug 21, 2009 | Dremel 400 Xpr Rotary Tool
Need new variable speed switch for dremel 395 type 1
Someone else recently asked the same question and got the following solution;
http://www.fixya.com/support/t1515699-variable_speed_switch_dremel_395_get
Jan 29, 2009 | Dremel Variable - Speed Multipro Rotary...
The variable speed switch on my dremel 395, can I get rep. parts
The part number you need is 2610945681 variable speed switch. I checked a couple site with no luck but I suggest you call Dremel at 1-800-437-3635 and order direct. Good luck
Jan 09, 2009 | Dremel Variable - Speed Multipro Rotary...
Variable Speed Does Not Work - Model 395
It probably can be replaced. For info on this tool call 1-800-437-3635 (Dremel) and speak with customer service about a replacement part. Hope this helps
Oct 12, 2008 | Dremel Variable - Speed Multipro Rotary...
Craftsman Single Speed Rotary Tool Logo
108 people viewed this question
Top Craftsman Tools & Hardware - Others Experts
Dusty Ryan
Level 1 Expert
Mike
John Trevino
Are you a Craftsman Tool and Hardware - Other Expert? Answer questions, earn points and help others
