Question about Breville Coffee Makers & Espresso Machines
Hi. On the Breville CG10 coffee grinder, is the higher the number the finer the grind or the other way? Thanks.
Yes, 1 is finest and 9 is coarsest.
From the manual: 8 - 9 Percolators 4.5 - 6 Espresso Machines - Steam System 3.5 - 5 Drip filter coffee makers 2.5 - 4 Espresso machines - pump system 1.5 - 2.5 Espresso machines - semi automatic pump system
Posted on Dec 28, 2010
Why does it brew weak coffee?
can depends many factors, try to grind finer coffe powder and warm well the machine before starting to brew coffee. If the grinder does not make finer coffe powder then you must contact the service, check if blades are in place before calling them...
Jan 19, 2016 | Saeco Vienna SuperAutomatica Coffee...
To make coffee stronger do i set the grinder higher or lower
Should set lower it will grind little finer and let espress under pressure absorb more ofbthe flavor, the corrsor it s the faster water flows through grounds, and less flavor.
Jun 11, 2011 | Saeco Royal Digital Plus Coffee...
Coffee grinder is producing large granules
Adjust grinder to finer, if there are numbers on the adjustment knob, it is still possible to go past 0.
Apr 27, 2010 | Wega Mininova EPU Espresso Machine
How do I adjust the grinder to make the coffee grind finer? ie. the coffee is pouring way too fast and giving no crema.
Depending on the model and make on the grinder you just have to turn the adjustment collar clockwise for finer, that is the case with most grinders.
Nov 11, 2009 | Coffee Makers & Espresso Machines
Breville Die Cast 800ESXL Espresso Machine: Problem... Watery espresso. My machine worked great for a year, then all the sudden, the espresso is watery and the basket where the grinds are is full of water...
Personnaly, when I use the big filter, the grinds are dry after the extraction, but for the small filter, it's all soggy. If you look at the documentation, ( http://kitchen.manualsonline.com/manuals/mfg/breville/breville_coffeemaker_product_list.html) they say wet coffee grind after extraction is normal.
But did you change the coffee brand ? Or the grinding level ? How do you grind your coffee ? I had big troubbles once with a commercial grinder at my grocery store, it's when I decided to buy my own Breville grinder.
Good luck,
JF
Oct 16, 2009 | Breville Die Cast 800ESXL Espresso Machine
The coffee comes out in little logs or clumps. The coffee is weak- no crema.
HI
There are 2 things that can cause this. Either the burrs are bad and need replacing or you grinder is out of adjustment and you need to turn to a finer grind. If you have taken it apart, you are not adjusted close enough so your burrs can't grind fine enough. Readjust the burrs closer together.
Oct 11, 2009 | Rancilio Rocky Electric Burr Grinder
In which direction do you turn the barrel to make finer coffee?
HI
Clockwise is the direction for making the grind finer, but make sure that the machine is running at the time you turn the hopper. If its not running, you trap beans under the burrs and jam the motor, which could do damage. There are numbers on the bottom of the hopper, but they are just a reference to go by.
Jul 29, 2009 | Rancilio (RAROCKYND) Grinder
Why is the grind from my Breville BCG450XL in the finest position coming out like a drip grind with a fair amount of dust mixed in? I have an old Solis with exactly the same conical burrs which is grinding...
The Breville was designed to be used with Pressurized Portafilters, which most Home Espresso Machines have. These filters use a courser grind, so when it says Espresso on the Breville, it's really closer to Drip. The Turkish setting is barely fine enough for Espresso. There is a limiter on the Breville that prevents the user from going any finer, if you crack it open and remove the limiter, you can go as fine as the Solis. Becareful though, the burs can come so close to each other that they can chip and break.
Feb 20, 2009 | Breville BCG450XL Manual Burr Grinder
Grinder setting for the Rocky SD In setting the spacing of the grinders:where are the "grinders" located? (I am assuming that they are under the plastic cover at the bottom of the bean container-right?)....
Your assumption is correct.
But you do not have to (and you can not) see the grinder wheels to adjust the grinder. The numbers on the bean container indicate the level. All you have to do is to push down the release lever (on the right side) and then turn the container -- towards right for finer grindings (lower number) or to left for coarser coffee. Around 12 is usually suitable for espresso machines.
Willy
Nov 15, 2008 | Rancilio Rocky SD Grinder without Doser -...
Breville cafe roma
Obviously the problem is with your grind, not the Breville. SImply adjust your grind to finer.
Nov 14, 2007 | Breville ESP8XL Espresso Machine
Coffee Makers & Espresso Machines Logo
632 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Steve
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
