How do I access the motherboard in a asus 1005HAB ? I got a bogus power supply and I think it smoked a trace on the motherboard
  • 4,924 Answers
Remove battery and all the screws in the back ...
after that remove the hdd if it has one in the side...cause will be a couple of screws in that compartment too ..
after you remove the screws in the battery compartment and in the hdd ... remove the hinges cover by unclick it from the hinges side with the laptop display closed...just insert some sharp object like a wide screwdriver ..and twist it to unclick ...
After that you have to open the display wide..and from the F1 and f10 (or 11) ..insert that screwdriver and twist to snap off ...after that will go inch by inch ...and will get out )the lid that cover the hinges and the front side under the display ..I will link you for images into a better understanding ..)
than you remove any screws that hold the keyboard..and the keyboard will slide about an inch toward the display ..than will get out It is also snapped in place ...remove it ..and you will have al;l access to all screws to open it ...by the way ...remove the display from the hinges screws and from the plug of the ribbon ..
Here is some links about this operations..
if it is a EEE model it will be a little different cause you do not have to remove the hinges cover ..
just watch this video cause it is very precise ..and acurate ..
http://www.youtube.com/watch?v=yehHh0GmnU0&feature=search
http://www.laptop-repair.info/take_laptop_apart.html
Posted on Aug 21, 2010
Will not turn on
I would remove all power, including battery. Remove the HDD and RAM. Power it up with the power it up with the power supply. If you get a screen, add stuff until it fails. It may not fail.
Dec 25, 2013 | ASUS Eee PC 1005HAB Netbook - Intel Atom...
Asus N53JQ-SX252V smoke came out vent then later screen went blank no go. I presume another motherboard is required. Can you advise the Part Number of a motherboard and where available?
You need to identify the source of the short/smoke before you can assume the motherboard has failed.
It may only be the switch mode power supply that has failed.
If you cannot see any charred marks on the motherboard then try another switch mode power supply in your computer.
You maybe lucky if it boots up.
Mar 06, 2013 | Computers & Internet
The charging pin in the port of my eee pc 1005HAB broke off. I looked online for replacement parts but they do not look the same. Are they the same, and how would I go about fixing it?
You will have to take the laptop apart and pull the motherboard out to fix it.
The part is called a DC Power Jack and you can find them on ebay.
http://www.ebay.com
Below is a direct link to some on ebay.
http://www.ebay.com/sch/i.html?_sacat=See-All-Categories&_from=R40&_nkw=asus+eeepc+1005hab+dc+power+jack&rt=nc&LH_BIN=1
May 13, 2012 | ASUS Computers & Internet
What is the type cmos battery for the asus eee pc 1005hab
Hello alaskavet77,
i found this website where in they are selling batteries for all of the units/systems maybe it will resolve your question
http://www.battery-center.net/asus-eee-pc-1005ha-battery.html or you may wanna check this website
http://www.global-laptop-batteries.com/asus-laptop-battery/Asus-Eee-PC-1005HAB-Battery-Black.html
thanks :D
archiecruz30
Apr 05, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
My ASUS Eee 1005HAB does not boot automatically.I have to press F1 or F2 to go to Windows ... Can you help me solve this non-automatic booting? Thank you..
What is the message that you are presented when you see the "push f1 or F2 buttons" ? A lot of times it is just a dead Bios battery that retains the configuration information on your motherboard. Do you have to set the time on your clock all the time by chance?
Feb 17, 2011 | ASUS Eee PC 1005HAB Netbook - Intel Atom...
How do I check for faulty DC socket (power jack) in my asus eee pc
1) Start out by removing all power to the laptop.
Of course you probably have the AC adapter (Charger) removed, but also remove the Battery.
See if you can gently wiggle the Center Post.
Also look to see if it seems that the entire DC Power Jack is moving around.
You may have to scrutinize pretty close to see any perceptible movement.
There should be No perceptible movement at all.
This is an example of a DC Power Jack for an Asus Eee 1005HAB Notebook PC.
It may, or may not, be The DC Power Jack you will need, but is used here for an example of the DC Power Jack construction,
http://www.rolta.co.uk/new-asus-1005hab-laptop-power-jack-pin-socket-dc-connector-165mm-29396-p.asp
You can click on any of the three views shown, and have all three views enlarged.
Click to enlarge.
Looking at the view on the far left, the Front view. You will see what appear as three pins sticking up.
These are Prongs.
Shown again in the Back view, which is the middle example.
These two views show the DC Power Jack upside down, in relation to how it sits on the motherboard.
The Prongs go down through holes in copper circuit traces on the top of the motherboard, and are soldered to the motherboard on the bottom side.
A) From accidentally bumping the AC adapter's plug while inserted into the DC Power Jack, the solder joints may have cracked. This can also happen with just normal usage from plugging, and unplugging the AC adapter.
Solution for this is to re-solder the cracked solder joints.
Sounds easy, but in reality the entire laptop has to be disassembled down to the bare motherboard in your hand. No Processor on the motherboard, no Ram Memory, no nada, but the bare motherboard.
Soldering can ruin a Processor, Ram Memory, or associated hardware components still installed on the motherboard.
B) The DC Power Jack may be broken. The Black body of the DC Power Jack that you see in the examples, is made of plastic.
This entails de-soldering the Prongs of the DC Power Jack, removing it, properly cleaning the area, (area around the copper circuit trace holes in the motherboard), re-tinning the area around the circuit trace holes, then installing the new DC Power Jack, and soldering it into place.
This is a basic example of DC Power Jack replacement,
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
C) The motherboard area that the DC Power Jack is soldered to, can be compared to a 'Peninsula'.
A small strip of motherboard that sticks out away from the main body of the motherboard.
This 'peninsula' can crack at the area where it meets the motherboard.
This will result in stretched broken circuit traces.
[Think of a circuit trace as being a very flat, thin, copper wire ]
If this has occurred toss the motherboard.
[ In regards to the DC Power Jack repair guide in the link above;
1. You don't need a soldering station. A soldering iron around 40 to 50 Watts with a No.2 chisel tip, and well tinned, will work just fine. Have a very damp sponge nearby to constantly clean the tip with.
2. I advise using Desoldering Braid instead of a Desoldering Tool. The braid is laid on the solder joint to be removed. The tip of the soldering iron is laid right on the braid, above the solder to be removed. The copper braid will 'soak up' the solder.
A lot handier than a Desoldering Tool IMHO.
3. Isopropyl Alcohol is EXTREMELY FLAMMABLE! Do not use near the soldering iron, and use in a WELL ventilated area with NO sparks or flames present!
4. If you are rusty with your soldering/de-soldering techniques, practice awhile before attempting this procedure.
Do Not overheat the copper circuit trace area around the holes. This will burn the area, and it won't accept tinning. (Tinning: Applying a light coat of solder) If it will not accept tinning, toss the motherboard at the cat. It's junk.
Overheating can also lift the copper circuit trace right off of the motherboard.
Make SURE you make a pretty, clean, solder joint. A cold solder joint will result in you starting all over.
It's a pain in the keister to disassemble the laptop in order to repair a cold solder joint.
Make sure the soldering iron tip is clean, and well tinned before you start.
Clean the tip often by wiping it across the damp sponge ]
The center pin of your DC Power Jack may be 1.0mm in diameter, or it may be 1.65mm
Make sure you obtain THE correct DC Power Jack.
The one's that are advertised around $2 to $5 may be junk, and no where near the actual DC Power Jack you need.
This place may be the one to go to. Don't know, haven't tried them, and not advertising for them.
I do like how they want you to send a photo in, and they also ask questions BEFORE you purchase.
IMHO it seems as though they may be professionals in their area of expertise,
http://www.laptopsockets.co.uk/
If you wish to have a Service Manual I do not see any online links to give you, except for one that details how to disassemble down to the Harddrive.
From there it would be a guide to an Asus Eee PC that is fairly close IMHO.
Plus guidance from me.
Have questions mtrunner53 please post in a Comment.
Regards,
joecoolvette
Dec 13, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Hello there, I got Asus PC-DL Deluxe UAYZ motherboard and would like to connect to ATX 300W 20 pin power supply. Do you think it works, or should i wait till i find 24pin power supply. thanks for your...
This motherboard is designed to be used as a workstation or server. This mother board will need a specific power supply designed for this board as it can use 2 Xeon CPUs. Setting this board with the incorrect power supply will cause the system to not power up or at worse result in damage to the CPU, motherboard, memory, video and other devices including possibly the power supply. I suggest obtaining the proper power supply for this motherboard
The manual for this board states that the motherboard requires a 24 pin ATX power supply that also has an 8 pin 12 volt connector. The manual from ASUS recommends no less then a 300 Watt power supply. I would professionally recommend 500 watts or more if the system will use 2 CPUs and many hard drives in a RAID array.
A suitable power supply can be found here at Newegg http://www.newegg.com/Product/Product.aspx?Item=N82E16817163111
The manual is here at ASUS's support site at http://support.asus.com/
Feb 24, 2010 | ASUS PC-DL Deluxe (90-MSV290-G0UAY)...
ASUS EE 1005HAB with Malware issue - Cannot access wireless
Avast is the best solution.Just you unplug the net connection and run the avast scan(from boot scan)
Copy the exe of avast from your pen drive and save it to your local PC.RUN it
Dec 15, 2009 | ASUS Eee PC 1000H Laptop
PC powers on and dies after 2 seconds. I hope it is the power supply because that is an easy fix. I hope it is not the motherboard (Asus P5WD2). This never happened to me before so I am not certain. I have...
I DO NOT THINK IT IS A POWER SUPPLY PROBLEM, TO RULE IT OUT JUST PUT ANOTHER PWR/SUPPLY ON IT AND SEE IF YOU GET THE SAMED RESALTS I THINK YOU ARE GOING TO GET THE SAME RESULTS AGAIN,
DIS CONNECT ALL WIRES GOING TO THE MOTHERBAORD EXCEPT THE POWER ONE.
I THINK IT IS THE POWER SWITCH IT SELF
IF NOT CONTACT ME AGAIN AND I WILL HELP U
CANDYMANGANDY
Jan 27, 2009 | ASUS P5WD2 Motherboard
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
